Question about Lexmark X502N All-In-One Laser Printer
Printing problem work is being sent to printer but won't print unless we press 1 as it is saying paper change then underneath plain paper A4 (1) continue. please can you help to change it back to printing without having to press number 1 everytime we print
  • mandy994 May 29, 2009
    thanks for this but can you tell me how to change the paper from tray 1 back to A4 on the paper settings?
    Sniper:
  • 67 Answers
Adjust your document settings page/paper format to match the printers paper format. this should do the trick.
Posted on May 29, 2009
Unexpected paper size message
go to the printer preference settings and change the paper size to A4 if you are using A4 and paper type to plain paper. and do the same on the printers settings menu.
Nov 12, 2013 | HP LaserJet 4050n Printer
Printer cartridges wont align says alignment failed and then paper too narrow
I request you to perform the steps below to align the cartridge:
1. Load letter or A4 unused plain white paper into the input tray.
2. Press Setup.
3. Press 6, then press 2.
This selects Tools and then selects Align Print Cartridge. The HP all-in-one prints a print cartridge alignment sheet and aligns the print cartridges. Recycle or discard the page.
Bypass the alignment :
Press and hold the Enter button, and then press Menu
Mar 14, 2010 | HP OfficeJet 6110 All-In-One InkJet...
Hp laserjet must manually push button to print
Please print a configuration page from the control panel of the printer
- Menu > Information menu > print configuration.
- Check for paper handling details.
Following setting should reflect.
Tray 1: Any size / Any Type
Tray 2: A4 size / Plain Type
If the above settings are not reflecting in the configuration page, please change accordingly by browsing on the control panel of the printer to:
Paper Handling Menu >
Tray 1 Size: Any
Tray 1 Type: Any
Tray 2 Size: A4
Tray 2 Type: Plain
Let me know if that helps to solve the issue.
Regards,
Nikhil.
Jun 14, 2009 | HP LaserJet 2420 Printer
Paper does not feed from Tray 1.
Check your printer settings.
Sometimes if your printer or the program you are printing from has the paper source set to "Letter" it waits for you to press the continue key on the printer which allows you to insert headed note paper before printing.
If it is set to letter, change it to A4 and this should solve your problem
You may need to change this in both the printer settings and/or each program from which you are printing
Jan 12, 2009 | Lexmark C532dn Laser Printer
CD label (Neato) printing problem
Try to change your paper type to plain paper - it could be because it is a bit glossy that it thinks it's photo paper that is not inserted correctly.
Jan 04, 2009 | HP Photosmart C8180 All-in-One InkJet...
Problem printing on matte photo paper
no thats why it is not working the right way you have to use the semi gloss paper thats what it requiers
Jan 03, 2009 | Brother MFC-3240C All-In-One InkJet...
Somebody has messed with the settings and now whenever we print we have to press "Select" for each page
The tray 1 is same as manual tray, it opens in front of you.
normally (in windows) you need to configure printer driver from printers => properties => printing preferences.
Oct 14, 2008 | Lexmark T632 Laser Printer
HP P3005 Will not pull from Tray 1
Click File > Print > Properties to check your settings.
To verify that tray 1 is working, put paper in tray 1. Press green check until you see Information Menu. Scroll using arrows until you see Print Menu Map then press green check. If it prints from tray 1, your problem is not with the printer, but with the PC settings.
i has follow this step, but need to press green check button to resume print menu map.
tray 1 manual feed set to A4 paper plain size
manual feed is on.
there is paper on tray 1
ps setting tray1 manual feed is A4 plain size paper.
send print to tray1 manual feed even there is paper at tray 1
i still need go to the printer and press green check button to resume print
Sep 23, 2008 | HP LaserJet P3005n Printer
Paper Tray Settings
You have Auto Tray Switching acticated (ATS). Unless you specify each tray/paper with different settings it will switch.
Go in to the utility menu and you can find this in the paper tray settings area I believe.
You can turn this off completely to avoid this in the future.
If you look around you can even just tweak the settings for this, but in your case i would just shut it off.
May 30, 2008 | Konica Minolta bizhub C250 All-In-One...
Lexmark X502N All-In-One Laser Printer Logo
109 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Roopesh S
Roopesh S
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
