Question about Toshiba 1360 Black and White Copier
Toshiba 1360 I have a Toshiba 1360 copier which doesn't work at all, the red wrench light on the control panel is blinking.
  • William VITULLO Oct 25, 2007
    After pressing down the clear/stop and 8 keys, the copier shows C7 error.
    New Friend:
Toshiba e studio 181 control panel light blinking
Posted on Aug 11, 2014
  • 87 Answers
You should be able to retrieve a code for a malfunction by pressing down the clear/stop and 8 keys. then let me know what you get, and we will go from there.
Posted on Oct 24, 2007
  • Scott Yeoman Oct 27, 2007
    That is correct ,it is the fusing section.Check to see that there is not a lot of build up on your thermister.Otherwise it will be your thermo-fuse.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Toshiba Master
  • 1,362 Answers
TOSHIBA 1210 C7 Fusing unit warm-up error, defective thermistor, fusing lamp or thermofuse
Posted on Oct 26, 2007
Wrench light on will not photo copy
You most likely have an internal error. Bad news is that your 1360 is a little beyond obsolete and chances are parts are unavailable. You may indeed be very much out of luck. Time for a new one, sorry to bear the bad news Margaret.
Feb 13, 2013 | Toshiba 1360 Black and White Copier
Just been given this 1360 toshiba copier 2nd hand. worked 1st time but not now. I have no manual & have red flashing light in shape of figure 8 with line coming out from & will not copy anything....
open the machine and lift the red fuser cover and check the exit sensor make sure that that the flag moves easly then makr sure the registration sensor flag moves easy as well the sensor is located at the black roller in the bottom of the machine there is a cutout in the plate you should be able to see the flag if not it is stuck in the open position the figure 8 is a paper jam error
Mar 07, 2011 | Toshiba 1360 Black and White Copier
Toshiba 1360 copier has a red flashing 8 with arrows or zigzags can any one tell me what this means. the copier does not work while in this mode
When that is flashing your copier is jammed or thinks it is jammed, check the paper path for any sines of paper.
Jun 12, 2010 | Toshiba 1360 Black and White Copier
Toshiba 13160 copier, wrench sign on what should i do
press the clear/stop button and the 8 key at the same time and a code will be displayed.. try that
Apr 30, 2009 | Toshiba 1360 Black and White Copier
Toshibe Copier 1360, Error light
you need service technicien to maintenance your copier, because it is full with used toner.
Nov 17, 2008 | Toshiba 1360 Black and White Copier
Toshiba 1360 Copier
"C7" Faulty thermistor, thermal fuse, or heater element
Sep 16, 2008 | Toshiba 1360 Black and White Copier
Toshiba 1360
Did you replace the cleanerblade?
Power off the machine, switch on while pressing 0 & 8, enter 200, then press the start button, the machine will run for about three minutes to adjust the Toner sensor. The machine will stop, press the interupt button to save the setting, switch off and then on.
If the older techies is reading this, please help to confirm.
May 09, 2008 | Toshiba 1360 Black and White Copier
Toshiba 1360 copier
Turn it on holding down 0 and 8. Key in 89, press start. press 0, press start. Turn it off and on.
Mar 18, 2008 | Toshiba 1360 Black and White Copier
Toshiba 1360 C7 Error Code
TOSHIBA 1310 C7 Fusing unit warm-up error, defective thermistor, fusing lamp or thermofuse
The codes are good for several models.
Oct 25, 2007 | Toshiba 1360 Black and White Copier
Toshiba 1360 Black and White Copier Logo
611 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
