Question about Whirlpool LSR5232L Top Load Washer
Whirlpool Washing Machine stops mid-cycle
I just picked up a fairly new Whirlpool Washing Machine, Model #LSR 5232LQ1 second-hand. When I ran a couple of loads through, it seemed to do all the functions--fill, agitate, drain, rinse, spin. However, the timer switch does not go through all these functions automatically. It stops mid-cycle, and the machine just sits there and hums. I have to manually advance it to the next function before it will do anything. This happened in both the Normal and Casual modes. I didn't try it in the Delicate mode. Now, it's been sitting idle for about two years according to the previous owner. So, I'm wondering whether there's a problem with the timer, and if it's something that can be reset, or does it require more than that?
  • 1 more comment
  • HiwyYa May 30, 2009
    I purchased a timer today. Will let you know how it worked out once it's installed.
  • HiwyYa Jun 11, 2009
    I replaced the timer with a new one, and it's still hanging up mid-cycle, just prior to the rinse mode. If I manually advance the dial one or two clicks the cylce resumes to completion.
  • HiwyYa Jun 12, 2009
    Nicolo,
    Thank you for these suggestions.
    I checked the power cord up to where it goes into the back of the machine. The lid switch as far as I can tell works because when I lift the lid mid-spin cycle the power cuts off and the the spin cycle ceases.
    Some more amplifying detail on the problem observed: In Normal, the machine stops just after the first Spin Hi mode. It won't start again until I manually move the dial all the way over to just before the last Spin Hi. That means Fill & Rinse, Agitate Hi, and Drain Hi are skipped over.
    When the machine is placed in Permanent Press/Casual mode, the machine stops after finishing the 1/2 Tub Drain. It will resume when I manually advance the timer knob to the final Drain step.
    This was occurring before replacing the Timer, and now still after installing the new Timer.
    President:
  • 2,187 Answers
Some washing machines stops the current function completely when there is loose connections in the power.  As a safety precaution, the manufacturers let it go into a "reset" once you set it into another mode, it would start over.  Check the power cable up until the one in the machine.  Another is the lid, the witch in there may have a problem.
Another reason could be there is an issue with the coupler and the motor.  You may hear the motor running but it not making much spin.  It may be starting to worn out.  I see this option however as the last one to check,
Posted on Jun 11, 2009
  • Nicolo Carlo Parazo Jun 12, 2009
    I suspect something in the "fill mode" is keeping you from proceeding. Can you check on the water level switch if it is connected or if it is working properly. Otherwise it could be the water valves for the inlet and the drain, pls check the connectors to it.
Doesn't work. Why does it stop mid-cycle?
washing machine stopped mid cycle, won't drain : DIY - Reddit
https://www.reddit.com/.../washing_machine_stopped_mid_cycle_...
RedditSep 3, 2014 - helpwashing machine stopped mid cycle, won't drain (self.DIY). submitted 1 ... I get home. Any ideas on how I can just drain the water out of it?
Troubleshoot - washer stops mid cycle, won't drain or spin ...
? 1:58
https://www.youtube.com/watch?v=6Gc0ZgLD6a4
Jun 20, 2012 - Uploaded by searspartsdirect
Troubleshoot - washer stops mid cycle, won't drain or spin .... I agree, this was not helpful, and did not address the no spin issue. like thanks. ... how to fix a Kenmore / whirlpool washing machine that wont drain agitate or spin ...
Washing machine stops mid cycle - White Goods Help
www.whitegoodshelp.co.uk > ... > DIY Washing Machine Repair Help
Sep 9, 2013 - Possible causes when washing machine stops mid cycle by a ... If thewashing machine can't drain the water out then it will stick on the rinses, ...
Why does my washer stop half way through cycle - Ken
Dec 18, 2015 | Washing Machines
Washer heavy duty cycle issue
Lid Switch Assembly
If the washer stops mid cycle the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Enter your model number to see parts for your washing machine.
Help me find my model number
Door Lock Motor and Switch Assembly
If the washer stops mid cycle the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Water Inlet Valve
If the washer stops mid cycle the water inlet valve cold water side may have failed. Most washers have a cold water rinse and so if they can't fill with cold water they just sit indefinitely waiting for the cold water to enter. If there is cold water to the water inlet valve and the cold water works in other parts of the cycle - or to make warm water - the valve is not the problem.
Main Control Board
If the washer stops mid-cycle the main control board might be defective. This is not common. Check other causes first such as the lid or door switch and other components.
Timer
If the washer stops mid cycle the timer might be defective. This part is often misdiagnosed, check other components before replacing this timer.
God bless youcb4af627-0171-42f5-ad0a-5f8e85e72ae0.gif6634bf88-8eca-4d0f-b59c-0e8829e5d59d.gif419f93c3-fea0-4d93-af85-2e59d98d88e0.gif
May 23, 2013 | Whirlpool AWG320 Front Load Washer / Dryer
Whirlpool duet is stopping mid cycle and beeping
F3E2 error, Wash light flashes 3 times then 2.
Took off front lower cover, Found Manual!!!
Unscrewed filter and was so full of trash, clean and reassymbled and now works just like new. Simple fix no parts at all needed.
Jan 03, 2013 | Whirlpool Washing Machines
Whirlpool washing machine gets stuck mid cycle
What is your model number? At what point does it stop?
Oct 15, 2012 | Washing Machines
Whirlpool 6th sense front load washing machine stopping mid cycle. Have to turn power off to reset & restart
I have the same problem. Stops randomly during the cycle and turning off the power for a second re-starts it.
I think it is one of the sensors is faulty - for example the sensor that detects if the load is un-balanced, or if the machine has enough water.
Seems to be a common poblem for these machines.
I'm going to try to find which one later today.
Dec 20, 2009 | Whirlpool AWM6120 Front Load Washer
My ultimate care II washer sounds like transmission is slipping
You probably need a new direct drive coupling.
Use the attached video to access the machine and check the coupling.
May 15, 2009 | Whirlpool WTW5850S Top Load Washer
Reset whirlpool front loader
Power shd be on. Right side of control panel, "end of cycle", hold this down for 3 seconds.
Mar 21, 2009 | Whirlpool Washing Machines
Whirlpool AWO3761 stuck mid-cycle
The cycle doesn't advanceWhen the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
  • Jul 06, 2008 | Whirlpool AWM6100 Front Load Washer
    Whirlpool LSR5232L Top Load Washer Logo
    273 people viewed this question
    Dan Webster
    Dan Webster
    Sal DeAngelo
