Question about Acer X223WB 22" WIDESCREEN LCD Monitor
Can't change W to H ratio
Baught new acer 22" lcd monitor. It stretches screen display and I've lost the proper screen size ratio for my graphics work, (circles look like ovals) The built in adjustments do not include Hor. or Vert. size. How do I overcome this problem? OS is win 2000.
  • 822 Answers
Use another monitor crt not LCD. adjust first the resolution. then connect again to your acer LCD. or you can auto config your acer from menu.
Posted on May 29, 2009
Connect my Acer monitor to my digital cable box.
Not sure what your cable box outputs but connect your cable box to a tv and try changing the resolution of your cable box to 1600x900 or less if there is such a setting; the monitor will not display resolutions higher than 1600x900
May 08, 2014 | Acer X203H bd Monitor
Getting 4:3 aspect ratio
off the monitor for few hours and use it
tell me what happens then
May 15, 2008 | Computers & Internet
Everything on the screen appears stretched
If you can, set the Screen resolution to the maximum native resolution your monitor supports by adjusting the slider. to 1680x1050, if you can set it to that, then Windows will automatically display at the proper aspect ratio, and the monitor will not have to stretch anything. Setting your screen resolution to match your monitor's native resolution is, by far, the preferred solution to get you the best looking display.
If that specific resolution is not available, then you'll need to try resolutions that are smaller than that, but ideally with the same aspect ratio. 1512x945, for example, would maintain the same aspect ratio. Not all monitors handle running at less than their optimal resolution well, and it may result in a slightly fuzzy display, but it won't be horizontally stretched. If this fails to fix the problem it could be a problem with your video card
Jan 03, 2010 | Computers & Internet
Acer 22'' Graphics too small
Right-mouse-click on your "wallpaper".
Choose Properties.
Click Appearance.
Change to a larger font-size.
Nov 17, 2009 | Acer B243w 22" LCD Monitor
Acer 22 aspect circle, not elipse
You'll need to change your resolution to one of the below to get the correct aspect ratio for a wide-screen display.
1440 x 900
1600 x 900
1600 x 1024
1680 x 1050
You will find these settings in Control Panel / Display / Advanced. If none of the above are options you will need to obtain newer display drivers.
Please let me know if this helps or if I can be of further assistance. Thank you.
Sep 19, 2009 | Acer 22" X223w LCD Monitor
22'' LCD monitor aspect ratio is off.
Set resolution to the native 1680 x 1050. Then, using the buttons on the monitor, go into the monitor's menu. go down to "Image Setting", go to "HDMI Mode", then select "PC Mode". This should help everything fit on screen correctly.
Mar 17, 2009 | Hannspree 22" widescreen LCD Flat Panel HD...
2 problems: 1. Is there a way to make the images on my 19 inch acer lcd monitor not appear stretched? 2. How do I get a screen resolution of 1440 x 900 (It's not one of the options in my display...
1. The only way to avoid stretching of images is by increasing the resolution. Many 19-inch monitors with conventional (4:3) aspect ratios have 1600 x 1200 pixel resolution. The 1600 x 1200 resolution is ideal for graphic artists and those who work with photos, since it's close to the resolution of a 2-megapixel digital photo.
2. You can double check by going to the display properties - Settings- Advanced tab below the screen resolution slider, choosing the Adapter tab, click List all modes and that will settle it once and for all. If 1440 x 990 isn't listed you're likely going to have to buy a graphics card that can reproduce that resolution.
Also try and update the driver for your graphics card.
Jul 06, 2008 | Acer Computers & Internet
Acer LCD AL1716W Monitor shows lines
use 1440 x 990 resolution, the ratio of the monitor is 16:10
Dec 27, 2007 | Acer AL1715 (Black, Silver) 17" LCD...
Display appearing stretched
the original image size was probably recorded in 4:3 aspect ratio...meaning your widescreen is a 16:9 ratio size screen and is stretching it outwards to fill the whole screen. If you want the image to look normal.. ie. not short and fat people.... you need to change the picture size in the settings from widescreen 16:9 to normal 4:3 tv in the settings menu most likely...Also most remotes will/should have a button for that.
Oct 26, 2007 | ViewSonic VA1912wb 19" LCD Monitor
Aspect ratio
display setting
from the desk top right click and select properties, then select the settings tab then change your screen resolution display setting
Sep 16, 2007 | Acer AL2016W 20" LCD Monitor
Acer X223WB 22" WIDESCREEN LCD Monitor Logo
382 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
