Question about Western Digital My Book Essential Edition (WDG1U5000N) 500 GB Hard Drive
USB Devices: Printer or Memory Stick freezes my XP sp2 on startup
Usb device for example memory stick or usb printer freezes Windows XP sp 2 on start up windows
  • 489 Answers
Unplug the offending device(s) from the computer and start it normally. Log on as an administrative user. Open Device Manager. In the View menu, make sure that Show hidden devices is checked. Go through the list of devices and find the problem children. Right-click and select Uninstall for each of them. Reboot the computer. Plug in the devices one at a time and let XP reinstall the proper drivers.
Posted on May 29, 2009
Computer doesn't recognise memory stick pro duo 4gb
Hello Guys,
The computer sometimes doesn't recognize the memory stick device due to corruption, there are numerous causes for memory stick corruption for example virus attack, improper removal, wrong usage of the memory stick device and many more. After such corruption scenario data are lost from these devices, but luckily you can recover memory stick files by using an efficient recovery application like Yodot Photo Recovery. Apart from memory stick the tool also recovers files from all other devices like memory stick, hard disk, iPods, music players etc. Try using this tool to recover your data from memory stick
Aug 20, 2012 | Sony 4GB Memory Stick PRO Duo Memory Card
I'm trying to move files from old computer to new computer.
The easiest way is to use an USB memory stick, plug this USB memory stick into the XP computer and copy the files from the XP computer to the USB memory stick, then remove the USB memory stick and plug it into the Windows 7 computer and copy the files from the USB memory stick to the Windows 7 computer.
Jul 14, 2012 | Computers & Internet
I have loaded photos on to a memory stick. When i put the memory stick in to the printer it says its an unsupported device. What should i do?
this is meaning that the printer do not support a usb memory stick ..and for to print them you will have to hook the printer to a computer and give the printing commends from it ..or ...try a memory card ..
or ..if you know the the printer supported the usb memory stick before see the format of the pictures to be compatible..
Jun 20, 2010 | Canon SELPHY CP780 Thermal Photo Printer
Ethernet-controller drivers for Acer Aspire 5520-5908 XP
Find a USB memory-stick, and find a computer with Internet access and an available USB port.
Put the memory-stick into the USB slot.
Browse to ACER's web-site, and select your specific model of the Aspire line, and select Windows XP, and select network-controllers, and download the device-drivers, and copy them onto the memory-stick,.
Walk the memory-stick to your Acer, and install the device-driver.
May 07, 2010 | Acer Aspire 5520-5908 Notebook
All of a sudden one day, non of the 3 USB ports on my Toshiba #A135-S2276 notebook works anymore. When I plug in a memory stick or a printer, It will show error message as "One of the USB devices...
Try disconnecting all external devices and reboot your laptop.
You must have all USB devices disconnected, memory stick, USB mouse or keyboard, Hard drives, flash cards ect.
After a reboot check your device manager for flags or exclamation marks and remove if present.
Again, re-boot your laptop and check your device manager.
Ounce you have cleared all marks from device manager and all is clear,
plugin your first USB device and check operation.
Please check your equipment manual for details on what USB ports and speeds are available for your required devices.
Hope this works for you.
Please rate ASAP
Thanks
Dec 31, 2009 | Office Equipment & Supplies
I have a memory stick with files on and for some reason its asking me to re format it, but i dont want to lose the files.
If you reformat you will definitely lose the files. Here is a protocol that may get you up and running again. If it does not, check at a local staples or other computer dealer and see if they can retreve your data as you memory stick may be a goner.
Remove the memory stick from the USB port on your computer and then reconnect it to make sure it was installed properly.
  • Step 2 Check the sides of the memory stick and see if it has a "Write Protection" tab. Slide the tab over to the "Unlocked" position if it was set to "Locked" and attempt to use the memory stick again.
  • Step 3 Remove any USB hubs or extra USB devices that are connected to the other ports on the computer in case you have accidentally gone over the maximum number of devices that the motherboard can handle.
  • Step 4 Click on the Windows "Start" icon located at the bottom-left side of the main desktop toolbar. Click on "My Computer" and wait for a new window to pop up. Check to see if there is a new drive in the list of options that corresponds to the USB memory stick.
  • Step 5 Click on the "Map a Network Drive" button located at the top of the window if the USB memory stick is not appearing in the list of options. Choose an available drive letter from the drop-down box and then click on "Browse." Find the location of the memory stick and then click on "OK." Close the "My Computer" window and re-open it to access the memory stick.
  • Oct 26, 2009 | Electronics - Others
    Computer is not reading usb from printer
    ensure that your printer is on and check  other sources like other media devices, like USB stick or memory stick, if all else fail, it could be from your uSB ports that was having a prob
    let me know
    Jan 09, 2009 | Lexmark X5470 All-In-One InkJet Printer
    How can I load windows xp onto my aser aspire one
    Print out this wikihow document and follow the steps
    http://www.wikihow.com/Install-Windows-XP
    After you're done. Download the latest drivers for your hardware from Aser's website and install them. Or use the drivers CDs that came bundled with the notebook.
    Oct 27, 2008 | Acer Aspire 5100 Notebook
    Western Digital My Book Essential Edition (WDG1U5000N) 500 GB Hard Drive Logo
    363 people viewed this question
    Top Western Digital Computers & Internet Experts
    Marcin
    Mike
    Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
