Question about Linksys Wireless-N WRT150N Router
Ipaq hx2700 not playing fair
I cant connect my ipaq hx2700 to my router dlink615 it says it there but wont connect .....Please help driving me nuts Mark
    Scholar:
  • 106 Answers
It may not be an answer but make sure you are using the proper Link G-link and N-link. Also if its a Dlink card make sure when you are installing the drivers from the disk that you DO NOT have the hardware connected, You insert the card after you run the drivers installation disk. Hope this is helpful.
Good luck =)
Posted on May 29, 2009
I cant get wireless on my handheld hp ipaq 2200
change the security settings if any in the wireless router.... use 64bitWEP password for the router and if it is a BELKIN wireless router then WiFi protected setup should be disabled in the roter....
contact router's technical support to do settings in it....
Apr 28, 2010 | HP Computers & Internet
I want to format my ipaq hx2410 please tell me how to do that
To perform a hard reset you need to press buttons 1 and 4 in addition to the reset hole. This should do the trick.
The guidelines for resetting your phone is given below
Performing a Hard Reset
Perform a hard reset only when you want to clear all
user-installed settings, applications, and data from RAM
(Random Access Memory), where data and applications you have
loaded are stored.
CAUTION: If you perform a hard reset, your Pocket PC loses all data
and programs not saved in iPAQ File Store.
To perform a hard reset:
1. Press and hold down the Calendar and iTask buttons.
2. While holding down these buttons, use the stylus to
lightly press the Reset button on the bottom of the iPAQ
Pocket PC for about two seconds.
HP iPAQ hx2410 Hard reset
3. When the Pocket PC screen begins to fade, release the
Calendar and iTask buttons first, and then remove the stylus
from the Reset button.
Note: If you simultaneously push and hold the Reset, Calendar,
and iTask buttons for more than two seconds, the battery
disconnects. To restart the device, either plug the device into the
AC Adapter or press the Reset button again.
After performing a hard reset, you may need to reinstall
applications stored in iPAQ File Store to restore shortcuts and full
functionality.
4. The Pocket PC resets and powers on.
To return your iPAQ Pocket PC to factory settings after
performing a hard reset:
1. Tap Start > Programs > File Explorer > My Device.
2. Tap the iPAQ File Store folder to open it.
3. Tap Edit > Select All.
4. Tap and hold the selected files, then tap Delete.
5. Tap Yes to delete all file in iPAQ File Store.
Apr 03, 2010 | MyNetDeals HP iPAQ hx2000/ hx2100/ hx2400/...
On IPAQ hx2700, how do I do a hard reset? I want
loaded are stored.
functionality.
Sep 23, 2009 | HP iPAQ HX2700 Pocket PC
Ipaq hx2190
hard reset for hx2190
Jun 27, 2008 | HP iPAQ hx2190 Pocket PC
Ringtone change
The ipaq is not playing large files. It only makes a small beep sound if the wav file is big. I am using a wav file of less than 800 k and it works.
Nov 03, 2007 | HP iPAQ hw6515 Pocket PC
Hp ipaq 4240
Turn your Linksys router off and back on again, then try connecting on your iPaq again. If that fails, do a soft reset on your iPaq and try again. If that fails, do a hard reset. Also, do you have any wireless security set up for the router?
Sep 07, 2007 | Computers & Internet
Doesn't start up
Hi, Based on your post/description, your iPaq 2210 will not power on. It is possible that your battery is deactivated. To reactivate, plug it to the AC power supply/adaptor, press reset at the back of the unit. Assuming no other problem, the unit will initialize back to default factory settings. It's very likely that all your previous/personal settings, files and applications will be also gone. Good luck and pls post back how things turn up. Kind regards.
Jul 21, 2007 | HP iPAQ H2210 Pocket PC
Connecting a Ipaq RX3715 to a wireless router
First, you have to be sure your ipaq has wi-fi feature is on and you can check on network connectivity option for any wrong setup there. According to your information, your ipaq is not recognized by your router and I agreed that your router is working normally. Try to reboot your ipaq and be sure to get wi-fi to turn on and try to connect it again. I have my Dell Axim also used Windows Mobile like Ipaq and it connected easily with no issue. The message in your to show me that you need first to identify your ipaq before you you can get it to connect to your network. I hope this help.
Mar 05, 2007 | HP iPAQ RX3715 Pocket PC
Trackball connection
no, neither a trackball, nor a mouse can bne used with an iPAQ. The only mouse to be used with iPAQs is a bluetooth mouse.
Sep 12, 2005 | HP iPAQ H2215 Pocket PC
Connecting RX3115 to Laptop w/ WiFi
you have to configure an ad-hoc connection between ipaq and pc if no router. otherwise, simply connect to the router and run activesynch
Sep 07, 2005 | HP iPAQ RX3115 Pocket PC
Linksys Wireless-N WRT150N Router Logo
44 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
