Question about Samsung ML 1610 Laser Printer
MY PRINTER APPEARS IDLE AND NOT PRINTING WHY MY SAMSUNG PRIENTER NOT ACCEPT PAPER?
  • 22 Answers
Your printer is out of cartridge or you install cartridge properly
Posted on May 29, 2009
Past service life message on Epson C88+ message appears and will not accept new cartridges or try to feed paper at all. Since this printer is just for home printing and it doesn't need to print...
Check if there are any objects blocking the way of the printhead or if there are objects down the paper feed area.
Is your printer placed on a stable, flat surface?
Does it happen to all the papers that you are using? Are the papers in good condition?
Try loading only 10 to 20 sheets of regular paper.
do a printer check to isolate the issue. Turn the printer off. Unplug the usb cable from the printer. Hold down the paper button while you turn the printer on. Keep on holding down the paper button only. Let go of the paper button when the power light starts blinking. If it does the same, there is an issue already on the gear of your printer.
If your unit is out of warranty, log on to support.epson.com. Click on help me find a service center to the left of the page to contact the epson local servicers near your area. If your unit is under warranty, call epson.
Oct 03, 2011 | Office Equipment & Supplies
Appear duplex jam at display samsung ML-2150
Lubricate all gears and shafts inside the machine. There is an idle gear on the top back motor "where the paper comes out" the nylon it is made of shrinks causing the gear to seize on the shaft resulting in jamming. Super glue the fuser output rollers to their shaft. the rubbers on the output roller expand and slip when heated (usually after printing a large document) printing one page then resting/cooling down the problem doesnt occur. the idle roller on the duplex feeder also breaks off.
Jan 06, 2011 | Samsung ML-2150 Laser Printer
Printer will not accept photo paper anymore.
Printing photo paper is bit to different than normal paper, Visit this link and follow all steps mentioned there to correct the problem. If needed change printing paper type to PHOTO paper, you'll find this option under Print Settings ( Step 3 under this link).
Thanks...!!
4 thumbs rating keep us motivated to answer more free questions.
Nov 26, 2010 | HP DeskJet F4280 All In One Printer InkJet
Change paper/letter appears constantly when
see in the printer menu on paper settings set it ot A4 and on the pc.should work
Mar 10, 2010 | Lexmark X342n All-In-One Laser Printer
CLP300 not picking up thicker paper
this printer only supports up to 120gsm paper,any thing thicker will get jamming errors
Jun 12, 2009 | Samsung CLP 300 Laser Printer
my printer is samsung ml 1610. it is not take print out. it showes error. why become this. please explain me
Feb 18, 2009 | Samsung ML 1610 Laser Printer
Dell 3100 CN printer...message on printer reads load tray
Cycle Power on the Printer
  1. Turn the printer off.
  2. Wait 10 seconds.
  3. Turn the printer on.
  4. Determine if the issue still occurs.
Verify There is Paper in the Tray
Verify the Paper Size
Look at the chart below to verify that the paper size meets the 3000cn / 3010cn / 3100cn-series specifications.
Verify the paper size in the tray matches the size set in the 3000cn / 3010cn / 3100cn-series printer´s operator panel.
To verify the paper size in the tray matches the size set in the printer's operator panel, perform the following steps:
  1. Press the MENU button.
  2. Press the down arrow until Tray Settings appears and press the return%20arrow%203100cn.jpg button.
  3. Press the down arrow until Paper Size appears and press the return%20arrow%203100cn.jpg button.
  4. Press the down arrow until the specific paper tray (Tray 1, Tray 2, or MPF) appears and press the return%20arrow%203100cn.jpg button.
  5. Press the down arrow to select the specific paper size, as shown in Figure 1, and press the return%20arrow%203100cn.jpg button.
  6. Press the MENU button.
*1 Denotes country-specific factory default values.
*2 Available for the optional 250-sheet cassette only.
Figure 1 - Paper Size Chart
Verify the Paper Type Matches the Type Set in the Printer´s Operator Panel
To verify the paper type matches the type set in the printer's operator panel, perform the following steps:
  3. Press the down arrow until Paper Type appears and press the return%20arrow%203100cn.jpg button.
  4. Press the down arrow until the specific paper tray (Tray 1, Tray 2, or Multipurpose Feeder) appears and press the return%20arrow%203100cn.jpg button.
  5. Press the down arrow to select the specific paper type, as shown in Table 1, and press the return%20arrow%203100cn.jpg button.
Table 1: Paper Type Chart
All media types that are not Plain 1 should be printed from the MPF only.
Verify the printing preferences on the Dell™ 3000cn / 3010cn / 3100cn / 5100cn-series printer.
To verify the printing preferences is set to print from the correct tray with the correct paper size, perform the following steps:
  1. Click the Start button, go to Settings, and click Printers and Faxes.
    The Printers and Faxes window appears.
  2. Right-click Dell Laser Printer 3000cn / 3010cn / 3100cn / 5100cn-series and click Printing Preferences.
    The Printing Preferences window appears.
  3. Verify the Paper Size drop-down is set to the correct paper size loaded in the specific tray to be printed from..
  4. Click the Paper Tray tab.
  5. Click the Paper Source drop-down menu and select the specific tray to be printed from.
    This sets the size and tray defaults.
Verify the Paper Size From the Printing Application Matches the Designated Printer Tray
To verify the paper size from the printing application matches the designated printer tray, perform the following steps:
  1. Open the application being used to print the document. (Example: Microsoft Word)
  2. Click File and click Print.
  3. Verify the paper size.
Verify the Paper Source From the Printing Application Matches the Designated Printer Tray
  3. Verify the paper source.
Do not replace any printer hardware as this is not a printer hardware issue.
Nov 12, 2008 | Dell 3100cn Laser Printer
Samsung CPL-300 Color Laser Printer Problem W/ Labels
I work in the comercial printing game, what your describing sounds like the surface finish used on these labels is only suited to black toner. Black requires the least amount of heat to set, where as colours require more radient heat the lighter the colour gets from black. Try printing a black/monotone lable and see if you still get this blistering problem.
May 07, 2008 | Samsung CLP 300 Laser Printer
Samsung ML 1610 Laser Printer Logo
88 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
