Question about Kicker KX Series 04KX1200.1 1200w RMS Monoblock Amplifier
Does a 1200W amp run 2x800W subs
Hey I'm looking for an amp for 2 800W sony xplod subs and I found a Kicker Car Amplifier 1200.1 - 1200w monoblock amp. Just wondering if this would work with them?
  • 27 Answers
Ya youll be fine 800watts is at peak power on the speakers
Posted on May 29, 2009
  • craig webb
    craig webb Dec 04, 2013
    i have 1 speaker class ab 300 w i believe
Need to know if my equiptment can push another kicker
yes you can add another sub to your amp. hopefully it has another terminal to let you do so if not you can just use one and splice the wire to each woofer. and yes get a capacitor itll save your battery alternator ect... i waited to long and fryed my heated seats from my car power surging
Dec 04, 2013 | Kicker KX Series 04KX1200.1 1200w RMS...
800w sony amp
I know i had a similar problem in my car, i ended up needing to do a battery relocation to the boot and putting a bigger battery in. Dont forget that just because the physical size is big doesnt mean it it has the amps so read the battery!
Kicker dx 500.1 keeps ruining my subs
if your sub isnt blown, i'd follow your own idea and look for a bad wiring connections, also what kind of head unit do u have? check the settings on ur head unit to see if there is a seperate setting for your amp/subs if it does have one, make sure it is set properly
if it does not have a setting like above, check the rca cable from the radio to tthe amp, and make sure that the rca cable is plugged in to " input instead of the output
Jan 15, 2013 | Kicker 2010/10 Dx500.1 Car Audio Monoblock...
Distorted sound.
try to set up again may be cable instalation not properly to set
Aug 13, 2009 | Sony Xplod 1200W Class AB Bridgeable 2-Ch....
Protection light comes on went the amp is turn on and it stays on for four seconds and then the amp turn on
Disconnect any speaker from the amp then re-power. If it still goes into protection, your amp needs serviced. Shorted output transistors most likely. And check your Sub for shorts as well. If the voicecoil on the sub is burnt, it will short any amp. If you can use a meter, check the resistance on the sub. Hope this helps
Jun 02, 2009 | Kicker KX Series 04KX1200.1 1200w RMS...
Settings for a Sony Xplod 1200 watt amp, with two 12 inch subs
What kind of subs are you running? Meaning what brand, what are the ohm, spl and wattage? I'll look up your amp while you get that info to me. Looking forward to helping you:) Thanks!
Apr 08, 2009 | Sony Xplod 1200W Class AB Bridgeable 2-Ch....
Sony xplod 1200 watt
i had the same ploblem with my amp then i found out i didnt have a good enough ground. Make sure you groung it to your weel well or some part of the frame. Or you mite be running with a fuse thats pushing to much power i use a 100a fuse 5 gage power cord to power my 1200w xplode and my 2 12" kicker comps. Or if your using two diff kind of subs then you amp is confused in why your asking for 500w on one side and 600w on the other this will also make your amp light come on.
Jan 19, 2009 | Sony Xplod 1200W Class AB Bridgeable 2-Ch....
Kicker kx1200
I am having the same issue, my kicker kx 1200 watt amp was pushing two JL Audio W6 12's and amp has power but no speaker out put, sending my amp to kicker for the thrid time. I tryed in my friends car with no luck.
Nov 20, 2006 | Kicker KX Series 04KX1200.1 1200w RMS...
Kicker KX Series 04KX1200.1 1200w RMS Monoblock Amplifier Logo
87 people viewed this question
Top Kicker Car Audio & Video Experts
hoyzee1
Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
