Question about Sherwood Audio Players & Recorders
Sherwood RD-6502 On/off standby light problem
Hey all, I have a Sherwood RD-6502 Reciever. Was working fine until recently, after turning unit on, it will stay on for 2-3 seconds before turning off and the standby light comming on. The standby light remains on. Have tried disconnecting all speakers etc from unit and powering up again with same problem. Have also checked for blown fuses without any luck. Any help appreciated! Kieran My amp does the same thing. Switches off after a couple of seconds when cold. Works fine with no speaker connected. Works fine after it's warmed up a bit but will trip if the volume is loud.
  • 31 Answers
SOURCE: Sherwood AI5010 no sound from either channel
Hi There DEKCAT
Its very unusual for both channels to blow......
I suspect that there is a blown power fuse inside the case......
There are fuses sometime located on the outside rear of the case and these can be easily checked to determine if they are blown..If you find one is blown please replace with the corrrect rated fuse,..... its current rating wil be on a small label on the case outside rear. like 1.0amp, or 1.5amp etc...
If you need to go inside the case please ensure the power plug is removed from the wall socket first.
You will find small glass fuses in the DC power supply feeds and probably one of these has blown, once again replace with the correct rated fuse.
Im not sure if your amplifier is a FET type or a large 32-40 pin IC type as if these are blown you will need a service person to do the replacement...
Please note there is a small relay that clicks 20seconds after turn on at the switch....if this click is not happening then there is problems with the timer circuit or the relay itself...
This relay controls the output to the speakers and as such stops all the sound output if its not working...so the first thing is to check all fuses, if they are OK then check the Relay operations....
Cheers From YUBEUT
Posted on Nov 16, 2007
SOURCE: Power Light off & speaker not working
I had the same problem. The screws around the perimeter of the back plate must be unscrewed and the plate must be pried off as it is glued to the box. When replacing my fuse, 2A 5x20 GMA, it blew the fuse again. Disconnecting the second circuit board prevented the next fuse from blowing, but now the question is what is wrong with the circuit board? I cannot see any damage or shorts.
Posted on Feb 22, 2008
robotek
  • 1512 Answers
SOURCE: My Sherwood RD6405 Switches on
Hi hyphen
Try a hard reset first. switch the amp off overnight and try it in the morning. If problems persist, is it covered with warranty from where you bought it? Best to go that route if it is. If not, get back to me here.
regards
Graeme
Posted on Mar 19, 2008
robotek
  • 1512 Answers
SOURCE: kenwood vr5700 standby blinking light
Hi kerrijon
Oh dear, your budding lil electrician may have gotten out of his depth:).
Shorted speaker wires often result in damage to the amps output stages. The blinking light tells us that the unit has gone into protection mode, preventing damage to the speakers from the amp. It will have what is termed a DC offset condition being generated by the channel; that got shorted. There is no easy fix for this and you have checked the obvious with fuses and removing all speaker wires and checking operation. The unit will have a blown output transistor/array, possibly driver transistors, and fusible resistors, and diodes to that channel. The bias current will also need to be set up again once repairs are completed.
There are no user serviceable parts in a unit like this. With good knowledge of electronics, a multi meter, soldering iron and experience at using all, you could fault find the channel, replace the parts yourself. I should warn you that if descrete components are used, they can be difficult to repair because of the nature of DC coupled linear stages employed. The best option is to take it to a repair man for a quote.
I am happy to try and talk someone through a repair process, but there is a degree of difficulty ascociated with not being able actually work on the amp.
The best solution for you is to get a tech to look at it. This sort of repair work can range from $80-150 depending on the parts used and the time taken to fault find and replace parts. I hope that this helps you. Your appreciation for my time spent to give you this advice is best rewarded with a FixYa.
Cheers
regards
robotek
Posted on Sep 10, 2008
  • 1550 Answers
SOURCE: I have a Denon AVR1603,
The LED flash indicates that unit goes into protection. Check the power transistors, the 0.22 ohm or 0.47 resistors in the output of the transistors.
SAM ANDERSON
Posted on Sep 30, 2008
Find remote code for sherwood rd6500 reciever
The only place you will find those codes, are in the back of the owner's manual. There is usually a general procedure to find a code that works, if they don't show the make and model number in the manual.
If you don't have the manual, I'm sure it on their website.
Feb 28, 2015 | Sherwood RD-6500 Receiver
I have Sherwood rd-6106 amplifier and when i turn him on it goes back to standby after few seconds. can anyone help?
bad fuse, something is sending it to sand by to keep from ruining the rest of it, have it looked at by a pro technician
Feb 02, 2015 | Sherwood Audio Players & Recorders
RD-6506 sherwood back to standby mode after 3 second when attemting to operate the system, any help please.thanks and God bless
Hi,Need more info. Was the unit working then failed? tell me anything you noticed, this sounds like a fault in the audio output or power supply stages,I have had other receivers do this for variou reasons
Feb 27, 2014 | Sherwood RD-6506 Audio and Video Component...
Sherwood
does a code pop up like f20 or just any code
Mar 20, 2013 | Audio Players & Recorders
No sound from tv when connected to sherwood 7505
try pressing the aux button on the front of the reciever while the reciever is linked up to the tv ,if that dont work connect a red and black banana plugs into your aux on the back of the reciever and on the other end of the lead must be a head phone pin check size of headphone socket. to plug in to your tv head phone volune then u can control the recievers volume through the tv using the remote.go to menu then tv set up then scroll to the sound note icon press enter scroll down click on head phone and turn it up then you should have sound through the speakers from the tv.
Jan 27, 2013 | Sherwood Rd-7505 Home Theater Receivers
How do I reset the defaults on my Sherwood RD-8108 AV receiver?
I just got a tip from Sherwood tech support on resetting my Sherwood receiver, and it solved my problem perfectly. It's not the same model number but here's what I did: Put the receiver on Standby. Press and hold the Setup button for 3 seconds. When you see the model # on the display, press Enter. The word "Cleared" should show on the display. Hope it works for you also.
Feb 03, 2011 | Sherwood RD-8108 6.1 Channels Receiver
Can I hook the reciever to mm bose subwoofer and 5
if bose unit has built in amplifier .Then your sherwood would have to have a variable RCA output jacks in order to work with sub.Then bose audio input RCA cable would connect there.If bose unit does not have built in amp .Then you would connect sherwood left/right speaker outputs into bose left/right inputs .Then other bose speakers will connect to bose unit
Jul 30, 2009 | Sherwood RX-4105 Receiver
CANT GET SUB WOOFER TO WORK WITH MY RECIEVER!!!!!
See step 9 for turning the subwoofer output ON
HERE
Part of the original link i gave you to your online manual.
Thanks for using FixYa - a FixYa rating is appreciated!!
Feb 13, 2009 | Sherwood RD-6108 Receiver
System lights up when plugged in but stays in stand-by mode
if it is wet please remoove the cover and dry it by using hair dryer .after that still the same it can be bad solder joints.
can you resolder the printed circuit board.
nuwan....
Jan 12, 2009 | Sherwood RD-6500 Receiver
184 people viewed this question
Top Sherwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Josh Whitehead
Josh Whitehead
Are you a Sherwood Audio Player and Recorder Expert? Answer questions, earn points and help others
