Question about Sony Handycam DCR-TRV140 Digital Camcorder
Error code c:31:22. beeps. flashes eject sign
My camera is showing error message c:31:22 What the heck? I have the same error...happened out of nowhere. Everything on it works...even have 2 tapes for it and i use it all the time even though it's old.
  • 3 Answers
This is a very common problem with many of Sony cameras. Please tap the camera at its bottom and left side a few times after removing the battery. I am sure that its going to work for you.
I have this problem repeatedly coming up for my cam and I solve this by this home made remedy !
Posted on May 29, 2009
C:31:23 code with flashing icon for eject,with a beeping sound
The error message indicates that the Camcorder has detected an issue that may require a power reset.
Step 1:
Try to reset the Camcorder and check if it helps to resolve the issue. Locate the RESET button behind the LCD screen of the Camcorder.
Step 2:
Turn off the Camcorder. Remove the battery or disconnect the AC power adapter for 60 seconds. Insert the battery or reconnect the AC adapter.
Step 3: If still unresolved Service may requires.
Jul 17, 2009 | Sony Handycam CCD-TRV318 Camcorder
URGENT NEED HELP WITH C:31:23 CODE ON DISPLAY SCREEN
Try first removing the battery and see if this clears the error.
Aug 24, 2008 | Sony Handycam DCR-TRV350 Digital Camcorder
Flashing code C:32:11
Remove the battery. Re-attach the battery, and power up the camera. Should retutrn to normal.
Jun 03, 2008 | Sony Handycam DCR-TRV140E Digital...
Sony Camcorder DCR-TVR140 NTSC does not recognize tape in camera
daer
this error C:31:23 is related to the s reel and this occurs only when the tension of the tape is more,
solution:
1 st try to change the tape
if the problem persists then u need to take it to the service center as the tape path of the mechanical section is to be adjusted
as you are telling that your camcorder is not showing remaining time (time code ) then head assy. also need to be cleaned ..try to use cleaning tape for 10 sec. not more then that .
Jun 24, 2009 | Sony Handycam DCR-TRV140 Digital Camcorder
SONY DCR TRV350 C31:23 and C31:22 flashing code
Hi Jeany,
Please see the detail below for the said error codes C31:23 & C31:22
According to the symptom and self diagnostic system the problem is in mechanical section (tape loading section) Therefore camera just need mechanical adjustment and will work fine again. This problem aries when the insertion of the cassette is improper or forced insertion.
Thanks for using fixya.
Jun 15, 2009 | Sony Handycam DCR-TRV240E Digital...
Error message C32:11 Sony Digital Handycam
Error 32:11 means, unloading mechanism time out. It is bit technical term.
its remedy is to remove battery / charger from camera and attache again and try to eject tape.
still no joy, let me know to help you more..
Dec 16, 2008 | Sony Handycam DCR-TRV460 Digital Camcorder
Eject Error
Does your camera make a buzzing sound as if it trying to eject? Or if you listen carefully can you hear the very faint sound of a motor free-spinning? I have just repaired a friends camera of a very similar model to yours with the same problem. There is a tiny motor in the tape compartment which comes loose from its "pathetic" mounting. This causes the gears to disengage and in turn renders the eject mechanism useless. The motor is in the bottom left hand corner (looking in as if loading a tape) right underneath the Player, off, camera selector. The motor simply needs to be repositioned to engage the gears. I then added some glue to stop it happening again (be extremely careful though as ANY overspill of glue will ruin the camera completely).
Aug 15, 2008 | Sony Handycam DCR-HC42 Mini DV Digital...
Digital 8 handicam trv340 ntsc
Its error message of some thing wrong with mechanism and you need to eject the cassette ( if its ejectable)
Aug 12, 2008 | Video Cameras
Eject is flashing with fast beeps. Won't eject tape or open compartment.
sad to say that the problem of your camera is the timing gear is already damage....it need to disassembly the camera to fix the timing gear....go to the qualified service center for fixing or replacing the timing gear..
Jun 15, 2007 | Sony Handycam CCD-TRV37 Camcorder
Sony handycam CCD-TRV43 troubleshooting
Some part in the cam is broken and i want to repair it. where should i go in Navi mumbai India?
Aug 08, 2006 | Sony Handycam CCD-TRV37 Camcorder
Sony Handycam DCR-TRV140 Digital Camcorder Logo
510 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
