Question about Gateway DX4200-UB001A Desktop Computer
The connection was never completed it says try again.
The internet wasnt connectred from know on
  • Tim Hudson
    Tim Hudson May 11, 2010
    Huh?
    One more thing to add...if the ip address that shows up in ipconfig is 169.254.xxx.xxx, then Windoze has assigned the APIPA since it cannot connect. This is a clue---the problem will very likely be connectivity at this point, and not a physical NIC/driver problem, etc. At this point, you can ping the loopback to verify TCP/IP stack integrity. This is a common misnomer, actually, since ICMP is layer 3, and TCP is 4, and the internal loopback is already bound to the MAC, so is THAT L2 or L3? Who cares...
    Please clarify your problem, though.
    HTH
    TIMMAY!
  • gambit3rogue
    gambit3rogue May 11, 2010
    Is it boardband, wireless, DSL, dial-up. If it came with an installion disks, run that first. make sure you have an ip address. best way to find out is to go to:
    RUN: when prompted enter ipconfig then press ENTER a screen will display your address. If none is shown go back to Run
    enter ipconfig /release then press ENTER if this does not change then your problem might be one of two things
    1. PCI Ethernet card might be bad or missing the drivers
    2. You don't have it properly set up.
    Hope this is helpful
    Good Luck =)
  • 98 Answers
The ethernet drivers might need updated inthe divice manager.on nrtwork adapters .in the control panel.click system,hardware,device manager. see if anything is in yellow.it must be turned green
Posted on Jun 09, 2009
I have an active internet connection on my Dell Vostro 200, and try to install a program just saved and it says there's no connection to the internet, try again.
if your internet connection is working, like you can access web sites, try to uninstall the program, run disk cleanup and delete temp internet files or browing cache/history. afterwards, make sure the program is not blocked by ur firewall or anti-virus if any as long as you are sure it is safe and legit. afterwards, install the program again. if it fails during installation again, try to download the set up file again as it may not be complete or it is corrupt. if it fails when it tries to load after installation, check program help documents if it has a internet setting that you need to adjust to make sure it will connect through your connection method,.
Nov 27, 2013 | Computers & Internet
Firefox cant find server
Because your disconnected from the Internet. Or using a proxy and configurations are faulty. Check your internet connection make sure your online and try again. Reboot the computer and try again. Most likely it is your internet connection issue if any.
If this is the case just go and power it all off wait about 10 seconds or so and power on again make sure before you power off the modems or routers or wireless connect that you completely power down your computer or computers first. Start the Internet by powering it all back on again. Then once power on is established, then turn on your computers let everything settle in for about 3-4 minutes depending on your connection speed.
That should work itself out. John
Apr 13, 2012 | Acer Aspire Computers & Internet
Cant connect to psn. But i can to internet. :(
One reason this may be happening is having the media sharing option on. Some routers can't handle all the requests the ps3 sends while having this option on. You're using a wireless connection right?
Mar 31, 2010 | Sony Playstation 3 (PS3) Console
Lost internet from a System restore
check the settings of your router to be sure it wasnt tampered with.then if your internet runs with a software check to be sure if it wasnt eliminated after the restore was done.i encounter that problem a lot. just a recommendation.
Sep 11, 2009 | Belkin (F5D5231-4) Router
My internet is connected but I cannot view internet pages. I have tried various browsers to no avail. I have done a system restore that also made no difference.
sounds like a fire wall issue... do you have zone alarm or windows firewall turned on or norton internet security or mcafee?? try disabling them completely .... then you will have to go back and fix the rule that blocked you from getting on the internet you'll have to look through all the rules created recently
Jul 24, 2009 | Computers & Internet
Sansa connect
This is a very basic respond but I hope it helps. I had the same problem until I tried this...
Hold the power button on top down for about 15 to 20 seconds... the screen should turn white and you sansa connect should shut off completely. Wait a few seconds and turn it back on. This did it for me and I was able to locate my sansa connectr on my computer. Good Luck!
Apr 02, 2009 | SanDisk Sansa Connect MP3 Player
Dont know how to configure
I have no internet connection
Mar 30, 2009 | Computers & Internet
Can't Connect to the internet.
Hi!
1. I think your connection is temporarily blocked by university. (Have you used P2P clients like bittorrent, Vuze. Usu. Uni block ur account because of excessive data usage). Call them and make sure they didnt clock ur access.
2. Mosttimes installation of new antivirus, firewall mess up your connection. so then you have to uninstall and then reinstall your firewall again.
3. Can you please go to one of your friends place and try to log in using non Uni/ school network. If it works it again prove your account is suspended.
4. Go to HP website using other computer. under hp customer support you can find latest Wireless and Lan drivers for your laptop. Then download it and install it to your computer. Then It will sove your problem.
If non of these dint work please let me know.
I will try my best to help!
Mar 06, 2009 | Computers & Internet
Disconnection problem
have you configure your netgear wg111v2
Oct 02, 2008 | Computers & Internet
Internet
if u want to use internet in ur handset itself than u have to get it activated from SP and than do have to do some settings as well,
and if u want to connect with PC or a laptop u have to choose a connectivity medium first than it depends on ur connectrivity medium what the steps to be followed,
1) If u are conencting with a cradle than u have to install the drivers of the cradle on PC, than switch on the modem from ur handset after that put ur handset on cradle it will detect the modem than create a dialup connnection from  control pannel>> network connection>> create a new acc. and than dial the connection the drivers u will get from the IMate site itself...
Thanx & best of luck.
Sep 01, 2007 | i-mate K-JAM Cellular Phone
Gateway DX4200-UB001A Desktop Computer Logo
82 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
