Question about Dell Dimension 2400 PC Desktop
The control panel has no security center in it.
After installing xp i tried to download sp3 but i couldn't. So i tried to open the control panel and enable the automatic updates, and there was no security center in the control panel. How do i get the security center back in the control panel?
  • pete201 May 29, 2009
    I will have access to the dimen 2400 saturday, that's when
    I'll try the solution you sent me. I went through the procedure
    on my optiplex 320 and I saw the security center. saiki006,
    thanks I hope it works.
    saiki006 I gave you the wrong info on the solution for the
    security center. I did not get the security center when I
    went to start - run - and typed in services. I didn't a scroll
    down menu. Sorry about the mistake.
  • 453 Answers
I guess you have turned off the security center in the system.
Not to worry. You can get it back by performing these simple steps:
Click Start.
In that, select Run.
Type Services.
Click on Ok.
Now you get a services dialog box.
Scroll down to the Security Center option
Check the status. It must have been turned off.
Double click on Security center. A dialog box will open up.
You will have 4 tabs namely General, Logon, Recovery, Dependencies.
Choose General
Choose Startup Type, and change it to Automatic.
Change the Service Status to Start.
Apply .
OK.
Now go back to control panel. You will see the Security Center Option.
Good luck !!!
Posted on May 29, 2009
  • Sai Kiran Camsarapalli May 29, 2009
    You'll have to type Services in Run and then press Enter.
    After this you'll get a new window named Services.
    If that doesn't work Try this.
    Start -> Control Panel -> Administrative Tools -> Services
    In this you will have an option called Security Center.
    Still you don't get it post another comment. I'll give you another method to access the same.
Skype kernel32
Skype v6.6.0.106 is the last version which supports XP SP2. If you try install newer version, you will need SP3 installed, or you will get the kernel32 problem "Failed to get proc adress for getLogicalProcessorInformation (KERNEL32.Dll)".
If you don't want to install SP3 for your XP, here is a work around for you to run Skype with XP SP2.
1. Download Skypesetupfull.exe v6.3.30.105;
2. Uninstall your current version of Skype from Control Panel;
3. Block the website download.skype.com in your router or in the
Host file;
4. Delete any auto downloaded skypesetup.msi in %Temp%
folder;
5. Install Skype v6.3.30.105.
Done.
Aug 04, 2013 | Microsoft Windows XP Professional SP2
Download OS Cd for emachines E728
which operating system??????
try downloading the operating system again
SP3 is the third and final service pack released for Microsoft Windows XP, and it eliminates many of the security holes that previously affected XP. While Microsoft recommends that users download SP3 using Windows Update, some users are unable to do so. However, it's easy to create a Windows XP SP3 installation CD; it requires only that you download the pack from the website and burn it to a CD-R/DVD-R using an ISO burner program.
Download the SP3 installation ISO by visiting the first link listed in the "Resources" section of this article. Save it to your Desktop. Download ImgBurn and save it to your Desktop. Double-click the installation executable for ImgBurn and click "Next." Follow the remaining onscreen prompts and click "Finish" to complete installation of ImgBurn. Insert a blank CD-R/DVD-R into your DVD drive. Open ImgBurn by going to "Start," "Programs" and "ImgBurn." Click "File," then "Browse for a source file." Navigate to your Desktop and select the SP3 ISO file. Click "Open." Click the blue "ISO to CD" button located on the bottom left of ImgBurn. The program will begin creating the Windows XP SP3 installation CD. This process may take anywhere from 10 to 20 minutes to complete depending on the speed at which the CD-R/DVD-R is being burned. Click "OK" once the CD-R/DVD-R has finished burning. You've successfully created a Windows XP SP3 installation CD.
http://www.microsoft.com/downloads/details.aspx?FamilyID=2fcde6ce-b5fb-4488-8c50-fe22559d164e&displaylang=en XP PRO SP3 ISO Download the iso also download the imageburn http://www.imgburn.com/
http://windows-xp-pro-startup-disk.soft32.com/ http://support.microsoft.com/kb/322389 http://windows-xp-pro-startup-disk.soft32.com/free-download?gclid windows xp pro start up disc
Apr 10, 2013 | Acer Computers & Internet
Not download xp
Step 1:
Feb 22, 2013 | Computers & Internet
Need xp download for usb boot
Step 1:
Feb 20, 2013 | Dell Inspiron 2600 Notebook
Windows\system32\config\system file is missing or corrupt
Step 1:
Feb 13, 2013 | Microsoft Windows XP Professional for PC
Firewall client on xp sp3
Hi there.
Try disabling Windows firewall first by going to the control panel, security center and disable the Windows firewall.
Then try install the firewall you have.
Good luck and thanks for choosing FixYa!!
Jun 02, 2009 | Microsoft Windows XP Professional SP2
Problem in office 2007 setup
HI Deb,
You will need to update windows to service pack3 first. Then once completed click "start" and open "control panel" and then "Add Remove programs-software" Scroll through list of installed software and identify all and only the office related components "select" each component individually then click "remove/uninstall" Remove all previous installed office components, starting with the smallest sized file to the largest, once completed restart your machine and try the office install disk again. See below for service pack three download info and links:
Download the service pack manually You can use Windows Update or the Microsoft Download Center to obtain Windows XP SP3 online. Check for updates on Windows Update loadTOCNode(4, 'moreinformation'); To check for updates on Windows Update, follow these steps:
  1. Visit the following Microsoft Web site: http://windowsupdate.microsoft.com (http://windowsupdate.microsoft.com)
  2. Click Express (Recommended).
  3. If your computer is up to date, Windows XP SP3 will be one of the updates that is automatically selected. Click Install. If your computer is not up to date, Windows Update will offer some other updates that you have to install first. Install those, and then repeat steps 1 and 2 to obtain Windows XP SP3.
  4. For Windows XP SP3, review and accept the Microsoft Software License Terms.
Windows XP SP3 will be downloaded to your computer, and the Windows XP Service Pack 3 Setup Wizard will help you install it.
Download the latest Windows XP service pack from the Microsoft Download CenterIf you have problems obtaining the service pack from Windows Update, you can download the stand-alone update package from the Download Center. This page will say that this installation package is intended for IT professionals and developers. However, you can safely download this file. The following file is available for download from the Microsoft Download Center:
Download the Windows XP Service Pack 3 package now. (http://www.microsoft.com/downloads/details.aspx?FamilyId=5B33B5A8-5E76-401F-BE08-1E1555D4F3D4)
Jan 23, 2009 | Microsoft Office Professional 2007 Full...
Install XP/sp3 on toshiba portege R500
Do you have XP or Vista installed on your laptop?
Does you laptop boot up into Windows?
What steps are you doing in trying to install the Service Pack?
You have to install the correct Service Pack for youe laptop, these were released in 2008.
SP3 is for Windows XP.
The service pack for Vista is SP1
Jan 02, 2009 | Compaq Armada E500 Notebook
Uninstalled SP3 to get mouse to work.
Right click on my computer, click properties, click on Automatic Updates and select Turn Off Automatic Updates.
Open Control Panel, open Security Center. Then click on Change the way Security Center alerts me, Uncheck all three check boxes.
And now see if your problem cures
Nov 25, 2008 | Microsoft Windows XP Professional With...
Window XP Home SP3
go to control panel, administrative tools, computer management, services and applications, services, look for themes - if it is not started, start it - if it works, goto the properties of the theme service and set to automatic
G'luck
Oct 24, 2008 | Computers & Internet
Dell Dimension 2400 PC Desktop Logo
643 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
