Question about Canon IXUS V2 Digital Camera
Black screen - Canon IXUSi
I have Canon IXUSi but when i turn it on everything goes black,i can still go to menu to set settings and go functions to set settings.When I move the camera to a more bright place,it shows show reaction [abit of white] but there is no picture on the screen .
Help?
    President:
  • 1,223 Answers
CCD FAILURE!
Call Canon for Free Repairs it is a known manufac fault in thousands of cameras , dont worry just call them see this for info on this problem
SEE THIS
Kindly Rate me WELL !
this applies to all products with same problem dont worry u r included just call them and tell them abt BAD CCD !
Good Luck !
Posted on May 29, 2009
When I push '-' to make image smaller screen goes black
Check your setting in "Custom Functions". Sounds like your "-" (or more specifically your "*" button) has had a feature enabled. I had my "*" button set for focusing - under Focus Settings in Customs Functions. If in doubt reset all Custom Functions to their default.
Mar 05, 2014 | Canon EOS 40D Digital Camera
How can i set black instead of full color to my canon 3220
Hello Laney,
Please go the operator control panel. Touch the icon that allows you to select full color, single color black and white. Select black then go to the :additional functions button located to the right of the screen. It is a "hard "buttin as opposed to the on screen "buttons". When u select additional functions you will get a menu of tabs . At the upper right top is copy settings. Select it. Scroll down to the "STANDARD SETTINGS " tab select it You now can store or initialize. Press store. You will see a confirmation of the settings you are about to store. Press ok. Baby you be fixed. Take care. Let "FIXYA " know I helped you please.
Mar 14, 2011 | Canon imageRUNNER C3220 Color Copier
When I turn on my camera the shooting setting display menu comes up, but after I take a picture the screen just goes black. I can still take pictures and everything. I have a Canon EOS 1000D by the way...a
Okay, there are a few possibilities and things to check out if you haven't already found a solution to this problem.
First, it sounds like you've turned off the display by hitting the button. Page 42 of the manual describes hitting the , which toggles the display between being off and on. So, try hitting that button and see if that fixes your problem.
One other thing to check out is the LCD Monitor Off/On setting, which is described on page 115 of the manual. If you're still having problems with your display after toggling the button then check this setting and make sure that it is on the [Shutter btn.] option.
Finally, it's possible that one of the custom functions is affecting the behavior of the display. To get to the custom functions just hit then use the arrow buttons to select [Custom Functions (C. Fn)] under the second to last menu item along the top, as shown in the next picture from page 152 of the manual.
From there choose C.Fn-11 for "LCD display when power ON" and make sure it is set to 0: Display, which will turn the display on when the camera is turned on, instead of 1: Retain power OFF status, which will keep the display off when the camera is turned on.
Since it's been a while I imagine you may have already solved this issue, but if not, then I hope these troubleshooting tips will solve your problem.
Good luck and have fun. :)
Mar 09, 2011 | Canon EOS Digital Rebel XS / 1000D IS...
Canon eos rebel xsi screen is black when taking a picture but shows picture afterwards..Menu works also so screen works but just black when trying to take a pic..
Set the shooting mode to a Creative Zone mode. Press MENU to enter the menu. Under the Setup tab, select [Live View function settings] then press SET. Select [Live View shoot] and press SET. Select [Enable] and press SET. Press MENU to exit the menu. Press SET. The image should now appear on the LCD instead of through the viewfinder.
Refer to "Live View Shooting," Chapter 5 in the manual for more details and the limitations of the LiveView mode.
Dec 26, 2010 | Canon EOS Rebel XSi Digital Camera
Viewfinder is blank, but the camera works normally.
Iris or Aperture not working its all time off so that you can not see through camera.You need to change Iris cable.
Mar 31, 2010 | Canon PowerShot SD430 / Digital IXUS...
LCD not working on Canon S3IS
When you press the DISP button the screen will light up. But there is a power save function that will turn the screen off after 1 minute. This value can be changed if you press MENU, select the tools tab and then look under Power Saving. Check what this is currently set to, it may have been changed to be less than a minute. You can make the time period longer.
Mar 18, 2010 | Canon PowerShot S3 IS Digital Camera
How do I recent my Canon Digital Camera?
To reset factory defaults. Turn the dial to P (program). Turn on the camera. Hit the menu key. You will now see the extended menus. (if you don't turn to P you only get basic menu). Go to the last tab which is the second tools menu. Look down the menu and you'll see a "clear settings." Select this and you have two choices "clear all camera settings" and "clear all custom functions." Select "clear all camera settings." The "clear all custom functions" only applies if you've created custom functions which few people do. I hope this helps.
Jun 18, 2009 | Canon Rebel XT / EOS 350D Digital Camera
When camera is switch on the menu shows but no picture/image
Your camera seems to have ccd chip problem. Image chips goes bad sometimes and when you play recorded image it is ok but when you want to turn on the camera to take picutures, you'll see scrambled image or no image at all. The remedy for this symptom requires a replacement of ccd chip. The average repair for ccd problem is $100-$130 in the repair market. -James
Mar 27, 2009 | Canon Cameras
Black box in center of screen
The Panasonic call center helped us with this one. Our Closed Captioning had been turned on through the TV settings. This made us have a black box with everything besides our cable. Turning off CC on our TV Main Menu solved the problem for us.
Jul 24, 2008 | Panasonic VIERA TH-65PV500 65 in. Plasma...
Turn on camera but the lcd sceen is black
Have you checked the display mode you're in? If you have the display set to off (to save power) and also the picture review time set to off, then you'll just see a black screen. Try pressing the 'Disp.' button below the screen when the camera is on - it should cycle through different settings with each press: Off, On, On with picture info. Similarly, in the playback mode this will show you more or less info about the picture you are viewing.
Even if the display is switched off, if you have your 'review' option in the menu set to anything other than Off (i.e. 2 seconds), then you should see the picture you've taken appear on the screen straight after taking it.
If it's not that, then I don't know the answer....
Oct 17, 2007 | Canon PowerShot S500 IXUS 500 Digital...
Canon IXUS V2 Digital Camera Logo
95 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
