My phone is set to pulse dialing and i need it to tone dial. i can't find the setting in the phone menu to change it to tone dialing
SOURCE: Tone Pulse
1)Make sure the phone is OFF (not in TALK MODE) 2)Press and hold the PROG buton until you hear a beep. The TALK button will flash while in this mode 3) Presd the TONE (*) button to select Tone Dialing or press the PAUSE (#) button to select Pulse Dialing 4) Press the PROG button again. The unit beeps to confirm.
SOURCE: ge 900 MHz cordless phone set on rotary dialing
Lisa, If the 900MHZ phone is Model 26928M programming for rotary dial usually goes like below, can't hurt to try on any model. TONE/PULSE DIALING This adjustment allows you to select tone (touch-tone) or pulse (rotary) mode dialing. The phone is pre-set for touch-tone use. To set to tone or pulse dialing: 1. Press and hold the program button for two seconds. You will hear a beep. 2. Press the *tone button to select Tone Dialing or press #pause to select Pulse Dialing. 3. Press the program button again. You will hear a confirmation tone.
SOURCE: how can I set tone/ pulse so I can dial out
Press menu and use the arrow down to goto Global setup and press select. Use the down arrow and goto Dial Mode and press select. Use the down arrow to select your dial mode and press select
SOURCE: setting for pulse dialing
Once you find T/P DIAL MODE, press OPTIONS, then press the DOWN arrow.
SOURCE: changing from pulse to tone dial
All phones have a sliding switch either at the bottom or sides of the instrument. The same is marked with "P" & "T" on either side of the switch, meaning Pulse or Tone. Shift the sliding switch to T for Tone or vice-e-versa.
