Question about Acer Aspire 9410-4317 Notebook
Trying to remove MB to fix ac connection
I am at the point where The case is just held together by something in the middle of the case. I don't want to force it apart. I am afraid that I might crack something. What would be holding the case together at this point? I would like to remove the top so I can remove the MB to access the broken power connection.
  • meteshadow May 11, 2010
    what you need excally? tell me i will help you
  • Acer Master
  • 4,806 Answers
Hi there.
You've probably missed a screw under the laptop base near to the WiFi compartment.
If you want full instruction with pictures you can download the service manual here >>>>>>>>>>>>>
http://rs60.rapidshare.com/files/38725771/SG_AS_9420_9410_7110_TM_5620_5610_5110_Merom_BOOK.pdf
Go straight to chapter 2 for instruction on disassembly.
Good luck and thanks for choosing FixYa!!
Posted on May 29, 2009
    Scholar:
  • 106 Answers
The case is being held by either the wiring that works the screen and any other functions that the top consists of notably a built in web cam for instance. Hope this was helpful
Good Luck =)
Need to remove base on nAXA Model NTD-1354
I needed to do this as well. The round part comes off but the stem does not come out of the TV. I don't mind taking things apart so I removed the screws on the back all around the frame. There are two screws right above all the hookups that you don't have to remove. After removing the screws, carefully separate the two halves. They snap togetther together on the middle of the sides. It takes a little effort to unsnap them I just kept running my fingernails up and down the seam until it popped apart. The screen half come off and is connected with some wires so don't pull it to far apart. At this point you can access the two silver screws that hold the stem in place. Remove the screws and the stem can be removed. Now snap the two halves back together (being careful not to pinch any wires) and re-apply the screws. I saved all the parts for the base in case I needed to put it back together. Last note, opening anything like this may void any warranty.
Aug 14, 2013 | Naxa 13.3" NTD-1352 12V HD LED AC/DC...
Umbro watch instructions
Start with watch in normal clock mode. press and hold bottom right "lap reset" - alarm time appears. Keeping "lap reset" held, I can then toggle the alarm on and off using top right "start/stop".
Qiu:Circle segment lights up (only a black point in the middle, NO ALARM)
Circle segment with a black section on the above middle point, ALARM ON.
Jul 15, 2013 | Watches
How do you remove the tab set
You probably have the L. margin set there. Return to that point, press but don't hold the MAR REL key, backspace to desired location, press L. MAR key.
DickyO
Oct 24, 2011 | Nakajima AE-740 Typewriter
My ge microwave wes1450dn1bb has started beeping and saying keypad shorted ...Is there anyway of fixing it?
To COPTAB/ GE Microwave WES1450DN1BB
Mine too! I solved it, and hopefully you can too. I hit the clear/off button and held it down for several seconds with the door opened and closed. It cleared it up and it works again, hopefully forever.
Mike
Aug 25, 2011 | Microwave Ovens
Toshiba Laptop not Taking Charge
ya the solder connection connecting the ac power input onto the transformer is probably weak. aside from taking the case apart and resoldering the connection, not much else you can do.
Jun 18, 2009 | Computers & Internet
Opening acer aspire 5050
The top and bottom covers are also held together with plactic catches.
After you remove the battery, CD/DVD drive and hard drive etc.
start near an openning and gently pull apart the top and bottom cases, you should hear a click as a catch releases, then continue to work around the edge fron this point.
Mar 05, 2009 | Acer Aspire 5050-3242 Notebook
Toshiba Satellite A105 no power
try looking at the DC input. My brother's 1st laptop had that same problem. All we need to do is solder it. Remember-1st dc connection, not the one on the MB.
Jul 30, 2008 | Toshiba Satellite A105 Notebook
Need to fix AC adapter plug in
I'm trying to repair the same thing right now.
to get the case apart, the hangup screws are under the keyboard. to remove the keyboard, you must remove the small plastic (1"x8") strip that has the power button and indicator leds on it.
to remove it, go along the top of the keyboard, closest to the screen, there are 5 plastic tabs to be released, then pop only that side closest to the keyboard up, then, slowly work it around until it comes free. flip the keyboard towards you, and carefully remove its ribbon cable by first popping up the sockets (on the mb) retainer.
then you can get those last screws out and have at it.
peace!
May 19, 2008 | Averatec C3500 Tablet PC
Screen shakes and it freezes
i suspect a possible loose contact between the ribbon connecting the motherboard module to the LCD display module. if you can open up the laptop, check if the both the ends are snug and tight.
Mar 19, 2008 | IBM ThinkPad T42 Notebook
Toshiba Satellite Laptop Power Failure (A105-S1013 System Unit)
How handy are you with a digital multimeter? If the laptop is still disassembled, find the solder connections on the motherboard where the mini power cable enters the board from the jack. Plug the AC adapter in. Check to make sure you have the proper DC voltage at those points (should be about 19V, although the AC adapter should say what it's DC output is).
If you don't get any DC voltage (or too low), check the DC plug of the AC adapter. The inside of the plug should be + and the outside should be -. If you are getting voltage there, but not the motherboard, chances are it's the jack or the mini power cable on the motherboard. These can be replaced, it just depends on how confident you are about doing it yourself :).
Mar 11, 2008 | Toshiba Satellite A100-S8111TD Notebook
Open Questions:
Acer Aspire 9410-4317 Notebook Logo
79 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
