Question about Acer Travelmate 2200 Notebook
Looking for replacement CD Rom Model SR43T1" - Acer Travelmate 2200 Notebook
  • trcybass May 30, 2009
    Acer travelmate 220/260 series
    SN - 9149SO1K05225001BAK000
    Model -220 series
    No.MS2109
    *Error msg- No hard disk found A:\>
    I've never added any hardware
    CD ROM - Model SR43T1/MITSUMI brand.
    Why is it difficult to get repalcement parts thru acer?
  • trcybass May 31, 2009
    Yes - my laptop has been broken for 2 yrs - I dont know what to do
    President:
  • 1,223 Answers
It seems like a laptop drive to me pls confirm and proceed further u cant find drives with model number u need to tell me the laptop model and make and then proceed read below if it is laptop drive
look cd rom i am not sure if it is available but u can fit a dvd burner in ur laptop it is cheap and easily available but u have to look for 2 things
1. the shape shud be same as ur cd drive it shud be it is a standard in all models of all manufacturers
2. Front Bezel Cover if u dont get the same u can easily swap the bezel and u can use ur old Bezel with new drive and then u can easily fit and run it is plug and play with no drivers u can get plenty of dvd burner drives for laptop pretty cheap on ebay around 50 $
go for brands Toshiba NEC OPTIARC do not buy Matshita panasonic in any case
u can ask me for more help on this i am here to help u
PLS RATE ME WELL more questions are welcome
Regards
Zohail
Posted on May 29, 2009
  • Shoaib Rais
    Shoaib Rais May 31, 2009
    hey it is not cd drive error it is hard disk failure u need to buy anew hard disk drive compatible with ur notebook u want me to guide u in this let me know
I do not have a cd rom only usb so looking for software
If you have Internet access then you don't need a CD ROM drive.
You can download the printer driver from the printer manufacturer's WEB site. I cannot give you the link to the printer manufacturer's WEB site because you have not provided me with the make and model of your printer.
Feb 07, 2011 | Office Equipment & Supplies
Dell D600 cd rom replacement instructions
There should be a screw on the bottom holding the cd rom in place. Unscrew the screw and then with one end of a paper clip put it in the small hole on the front of the cd rom and the door should open. Now go ahead and pull the cd-rom out.
Now you can go ahead and put the new cd-rom in place and put the screw in and then turn on the laptop and let it boot up into windows and windows might redetect it. Go into my computer and you should see your cd-rom in there.
Jan 23, 2010 | Dell Latitude D600: Pentium M 1.6GHz,...
I want to replace my acer laptop Cd rom , from where can i remove old one
Here are the steps on how to remove your old CD-ROM so you can replece it.
Remove all power sources from the laptop. This should include not only the AC power adapter but also the battery.
Locate and remove the screw that locks the CD-ROM in place. Some laptops may have two screws that serve this function. In addition, many will also have a sliding switch that needs to be moved in order to remove the drive.
Slide the drive out gently. It should easily come out and does not require excessive force.
Replace the defective CD-ROM drive by sliding the new one gently into place in the laptop bay, the same way the old one came out. Again, excessive force should not be applied. The drive will only fit into the bay one way.
Secure the CD-ROM drive in place by replacing the screws that were removed previously. Reconnect all power supplies to the laptop and power it on. If the replacement CD-ROM is the exact same make and model as the previous one, the system will probably recognize it right away. If it is a different make or model it will prompt you to supply the appropriate software and drivers to optimize the use of the new CD-ROM drive.
Jan 22, 2010 | Acer (91.49C37.001) CD-ROM Drive
Does my laptop have a dvd burner
Can I have your laptop model number.
You can also confirm the same by looking at the drive externally
If it has DVD-RW and DVD-RW DL on it then it can read and write CD/DVDs
DVD - R ROM then it can read DVDs but cannot write.
CD-ROM/ CD-RW cannot read / write DVD
Aug 08, 2009 | Acer Computers & Internet
I can't insert any cd's.
Maybe the laser eye is jammed. It tracks back and forth reading data from the disc.
You may either replace the drive or have it repaired.
I had one on my PC do the same vibrating, clicking noise. It only cost 40.00 to replace.
But for a laptop, you're looking between 60-100 dollars to replace.
You can see how much it would cost to repair first, but my guess is it would be cheaper to replace.
Jul 12, 2009 | Dell Dimension 5100 (D51L1) PC Desktop
I have Dell Inspiron 5160 laptop. I want ot replace the CD-RW/DVD with a CD burner. What should I be looking for or is it better to go with an external DVD burner?
Well a CD-RW/DVD ROM is a CD burner so you really dont need to replace it. Unless you meant replace it with a DVD burner then...
The best thing you can do is go to the Dell website and search your notebook/model number and look for the upgrade drive and buy it from them. If its to expensive search ebay or the web with the info you found on the Dell website (combo drive name + model number) and find one for a cheaper price.
Jan 04, 2009 | Dell Inspiron 5160 8X DVD+RW, IDE - R5024...
Looking for.....
You will need a low profile dvd. Do you want a part and vendor?
Worldvet
Jun 21, 2008 | HP Compaq Business d530 Ultra-Slim PC...
Cd rom
Where can I get the driver for my CD-ROM?
Visit our hardware download section to obtain a generic CD-ROM driver (oakcdrom.sys) and mscdex.exe if needed.
If you are looking for a specific driver for your CD-ROM drive or a Firmware update, please see our CD-ROM driver page.
Dont for get to Vote / Merry Christmas.......Good Luck!
Dec 06, 2007 | Computers & Internet
Acer Travelmate 2200 Notebook Logo
96 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
