Question about HP LaserJet 3330MFP All-In-One Printer
Printer is printing two smudge marks on my documents.
My HP 3330 mfp laser printer is printing two smudge marks on my documents. How do I solve this?
  • 1 more comment
  • stephany_and May 29, 2009
    Thanks so much. I am not sure what a fuser is though.
    Thank you for taking the time to explain this to me. I am most appreciative for your advice and support. You get a 10 in my book.
    Since you are such a guru, do you give advice about printer purchases? I am a mobile notary and ideally, would like a printer with 2 inputs for regular and legal size paper. I don't want to break the bank and I was thinking about another multipurpose printer such as an HP 2727mfp. Do you have any other ideas?
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 80 Answers
Two parts of the printer can affect this.
1) the toner cartridge
2) the fuser
Testing can be done to determine the problematic part.
Do a print using manual feed. Once the last bit of paper goes into the machine, open the printer door.
Remove the toner to check if smudge is there.
Replace toner cartridge if there is smudge, replace fuser it not.
Posted on May 29, 2009
  • Tualiapz
    Tualiapz May 29, 2009
    You can check out what is a fuser from below link
    http://www.answers.com/topic/laser-print...
    "The paper passes through rollers in the fuser assembly where heat and
    pressure (up to 200 Celsius) bond the plastic powder to the paper.
    One roller is usually a hollow tube (heat roller) and the other is a
    rubber backing roller (pressure roller). A radiant heat lamp is
    suspended in the center of the hollow tube, and its infrared energy
    uniformly heats the roller from the inside. For proper bonding of the
    toner, the fuser roller must be uniformly hot.
    The fuser accounts for up to 90% of a printer's power usage. The
    heat from the fuser assembly can damage other parts of the printer, so
    it is often ventilated by fans to move the heat away from the interior.
    The primary power saving feature of most copiers and laser printers is
    to turn off the fuser and let it cool. Resuming normal operation
    requires waiting for the fuser to return to operating temperature
    before printing can begin."
    Unless you are an authorized service provider you
    will not be able to get the fuser yourself as it is not a customer
    replaceable part.
    Give the troubleshoot steps a try, 9 out of 10 the issue is with the toner cartridge.
    Please give me a rating if it works for you. Thanks
  • Tualiapz
    Tualiapz May 30, 2009
    sorry I am not familiar with each brand of printer. So I could not really give you any good recommendations. I just fix MFP at my work place.
HP LASERJET 100 COLOR MFP M175a PAPER JAM
I suggest you some points like clear the dust in the printer, proper set paper in paper place, adjust the paper line etc..
If More Support visit this link. I hope solved you problem..
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c02622145&tmp_task=solveCategory&cc=us&dlc=en&lc=en&product=5076465
Jan 15, 2014 | HP LaserJet Pro 100 color MFP M175A Laser...
NEED TO REPLACE LASER PART
That's a job for a professional. There are too many parts to disconnect and remove to get to it. Trying to re align some of those parts is impossible without the correct tools
Jan 13, 2014 | HP Laserjet 3330 Mfp All-in-one Laser...
NOT PRINTING LASER NOT WORKING
Replace the laser unit or replace the printer..... It may cost more to fix the printer then to buy a new one?
My HP laser jet M1120 MFP is repors error message when printing
Re install the tonner and then go to Printer & Faxes settings and delete the all kinds of pending documents and the go to print a new document and after taht send me the result...........what is happening.
Oct 01, 2012 | HP LaserJet M1120 MFP All-In-One Printer
HP LaserJet 3330 will not print multiple copies
Does this happen only with some documents/software? I have a different HP printer (a LaserJet) that does the same thing only with PDFs printed from another program. (This happens with PaperPort and browsers using the Adobe Reader plug-in, for example.) If I open Adobe Reader and then open the document in question, I can print multiple copies correctly.
I hope this helps.
Jun 14, 2012 | HP LaserJet 3330 All-In-One Printer
I have a HP Color laser jet 2600n printer. I have tried different Glossy paper, marked for laser jet, but still get bad smudges on my prints. these smudges are still visible on the next ordinary prints...
You need to ensure that you are telling the printer that and your print driver that you are using glossy paper as this will change the speed that the printer prints at and ensure better bonding.
May 23, 2011 | HP Color LaserJet 2600n Printer
I have misplaced my printer software cd ....how do i acquire a copy as i have changed my pc and need to downlod the software.
Hello Julian,
Below is the link where you can go and download software and drivers for your HP Laserjet 3330 All-In-One Printer.
-http://www.howtodrivers.com/model29955.html
Enter the code and you will be able to download the software
Please let me know if you have any further questions or concerns.
Thanks.
Apr 30, 2010 | HP LaserJet 3330 All-In-One Printer
Poor quality smudge and ink blotting marks in the centre of any printed document
Try performing a test by printing a test page from Tray 1 and open the top cover as soon as the paper is 60% inside. The paper would jam below the toner cartridge before it reaches the fuser. Remove the toner cartridge carefully and verify if the smudges occur. This would eliminate the fuser. If the print quality is fine, then you need to swap the fuser.
Oct 30, 2008 | HP LaserJet 4250n Printer
Xerox Phaser 8560 mfp Printing issue
That really sounds like you need to replace the maintenance kit.
The white roller most likely is black and has depleted itself of lubricant a bit prematurely.
May 21, 2008 | Xerox Phaser 8560MFP Laser Printer
HP LaserJet 3330MFP All-In-One Printer Logo
1,703 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
