Question about Whirlpool AWM8163 Front Load Washer
Dirty marks on white washing
Could be on all but does not show on coloured could this be from door seal
  • 82 Answers
Do you do any boil washer 95 wash if you dont there will be a sludge type of paste on the door seal pull it back a bit between the drum and the seal if there is put it on a boil wash with no powder,conditioner or clothes and put in about half a mug of soad crystals staright in the drum and this should clear up .
Posted on Jun 27, 2009
Dirty door seal
You can first try cleaning out the drum of your machine. Run it without anything in it, using 1/2 gallon of Vinegar instead of soap. Hot water will work best. Most hardware stores, or bestbuy,sears,etc. Have packets of cleaning agents you can use instead of the vinegar. You can also use brake fluid for cars on a rag and wipe down the door seal to clean it, then run it through a whites cycle to remove any leftover residue.
Hope this helps!
Dec 17, 2013 | Washing Machines
Dirty marks on laundry caused by dirt or fungus inside folds of door seal
What you probably have is a build-up of scrud in the machine as a result of an interaction between the fabric softener and the detergent. This flakes off and marks the clothing.
Buy a commercially available cleaner for your machine for this purpose of do one or two cycles using a bottle of white vinegar in the tub without detergent. Clean the machine out doing another cycle using baking soda directly in the drum. Repeat this process if there are still any indications of scrud.
Take care that you use the correct amount of detergent in your machine according to load and water level and do a cleaning run about every 25 wash cycles to clear away any excess detergent that was not caught by the rinse.
Apr 30, 2011 | Zanussi Washing Machines
Black marks appearing on towels. Look like marker, smudged.
hi.
it could be the seal on the front of the drum starting to break down.
clean the seal at the front of the drum that seals the door. then rub a white cloth/towel around the seal
if there are any marks left by the seal then the rubber compouds are starting to break down and the seal needs to be replaced.
please feel free to ask for detailed instructions on changing this seal if you need them
Apr 13, 2011 | Frigidaire GLTF1670A Front Load Washer
Dirty grey streaks on light colours, white streaks on dark
need to replace the door ring, " boot ".  new ones made of better materials and chance of any odor greatly decreased..
Jul 21, 2010 | Whirlpool Duet GHW9150P Front Load Washer
The rubber on the inside front of the washer ("the door boot") gets very dirty, slimy and is all stained. As I pulled the rubber back to clean it, it was digusting ! It is starting to leave marks on the...
at this point and time the best thing to do is replace the door seal.and then make sure after each wash cycle you dry out or leave the door open somewhat in order to help keep it dry and clean
Jan 27, 2010 | Frigidaire ATF6000ES Front Load Washer
Hotpoint Aquarius WF740 My washing is coming out with dirty marks and bits of slimy dirt. I wonder if it is from the door seal as this is dirty or could it be something else? I used the persil gel filled...
Your pipe to the water pump exit is probably blocked with bits of old fluff or missing sock, i found that the clothes had slimy bits on mine, i tilted it up and removed the rubber water exit pipe from under neath, cleaned out all the rubbish and works a treat now.
Oct 19, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Dirty washing
what this could be is your bearings check if there is any amount of movement from the drum by opening the door place your palm onto the front of the washer so its on the bodypart of the washer now place your fingers into the washer facing down so you can grab the drum with them now pull up and if there is any movement then its confirmed bearings need replacing m8 get the warranty company out its a big job some companys just replace the washer m8.It will be the bearings though what those black marks are is the grease out of the bearings cause the seal has gone ive done hundreds of bearing jobs let me know how u go on m8
Jan 23, 2008 | Washing Machines
Marks on white clothes
if the machine has become more noisy of late, the the oil and greease out of the bearing has done this. Which means a heavy bill. appliance doctor
Jan 28, 2007 | LG WM-1832C Front Load Washer
Whirlpool AWM8163 Front Load Washer Logo
196 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
