SOURCE: infoprint 1412 on windows vista
I have the same problem with my 1412, if you find a driver please emial me.
SOURCE: IBM Infoprint 1532
There is probably a small piece of paper in the back of the printer in the fuser. Shutdown the printer and wait a few minutes as this part is hot. You may need to remove a few screws to take off the back cover and check inside the fuser.
SOURCE: IBM infoprint 1312 toner and error light.
If both Lights are solid, it means that the top cover is still open and the toner is low. Please make sure the top cover is closed all the way. If the toner light is blinking and the errror light is solid, it means there is a toner cartridge error. Please try a new cartridge. If that solves the issue, then you should return the damaged one.
SOURCE: Ibm infoprint reseter
Here is a procedure I would like you to do to reset the light:
1-Power the printer on and get it to the Ready state (i.e. the light on the operator panel is on)
2-With the printer on and in the Ready state, open the front cover
3-Press and hold the Cancel button until all of the lights begin flashing up and down.
4-Release the Cancel button and close the door. The photoconductor count should now be reset
To confirm that the photoconductor page count has been reset, it is recommended that you print a
menu settings page and check the photoconductor level. Do the following:
1.With the printer at the Ready status, press the Continue button once. The Ready
light will begin flashing and one or two pages will print out.
2. Look for a section labeled Cartridge Information and locate the word Photoconductor
under this heading.
3. Confirm that the photoconductor level reading is either OK or close to 100%.
4. If the reading is low, try printing 10 - 20 pages.
5. Print the menu settings page(s) again.
6. Confirm that the photoconductor level reading is OK or close to 100%.
7. If the photoconductor reading is still low, there is a second, more detailed, procedure you
can perform to reset the count.
8. If the reading is still low after both procedures have been attempted, the printer may require service
SOURCE: i want to have the driver for ibm infoprint 1412
You can download the IBM InfoPrint 1xxx AIXPrint Driver from their supportWEB site.
Please click on this link and select your model printer to download:- http://www-01.ibm.com/support/docview.wss?rs=95&context=SRATEW&dc=D400&uid=psd1P4000313&loc=en_US&cs=utf-8&lang=en
