Question about Magellan RoadMate 2000 GPS Receiver
Roadmate 2000 power supply over-voltage
My Roadmate 2000's Car charger was dipped in a bucket of water.It was later used in the GPS unit. The GPS unit did not worked but a burned smell came out from the GPS unit. Upon checking the output of the charger, it was found to be 12Vdc.
Can I buy a replacement PC board to replace my burned PC board? Would be cheaper to just toss away the broken GPS and buy a new Roadmate 2000 instead?
Thanks,
Jacx
The roadmate operates on five volts dc. Look at the back of the unit and it says so there. Inside the cig lighter plug that comes with the roadmate 2000 is a transformer that converts 12 v dc to five v dc. You used the wrong charger and put twelve volts across a unit that only handles and requires five volts.
Check to be sure that you used the correct charger. it sounds like you did not. It may be possible that the charger was still wet or was damaged when wet and that it shorted out.
Radio shack sells a charger for the car that is made for magellin roadmate 2ooo. It includes several different tips including the one that fits this gps unit and the output is five v dc. It is possible that what you smelled was the charger cord and not the gps unit itself.
I used the wrong charger on mine and had a similar problem. I bought this charger and all is well. radio shack cat no is 20-151. Get it soon because it is on sale for about thirteen dollars and is discontinued. As of today, sat jan 12, 2008 they still have them in stock at most stores. You can call ahead or look online and it will even tell you which stores have them, or you can order online as well.
No, if it is the gps unit titself, do not try to mess w the circuit board. Its cheaper to buy a new one. good luck to all w similar problems and ALLWAYS check to see that voltage and ac or dc symbols, as well as polarity, match up. If not bring your electronics to radio shack Before powering up and they can check all of this ffor free if you are unsure.
Posted on Jan 12, 2008
Gps 1412 will not charge
Have you check the voltage output on your power/charger cord? It's easy to test if you know how to use a multi-tester or take it to a small electronics shop like a Radio Shack.
If there is no voltage output from the charger, then simply replace the cord. I have found that those charging cords can break real easily but it's hard to physically see any damage.
Otherwise, if you've already tried a new charger, you may need to send your GPS in for service.
Mar 31, 2012 | Magellan RoadMate 1412 Car GPS Receiver
I was having problems with the car charger CA-051, then, I used a T-Mobile charger, at first time worked, after that, the GPS Maagellan was dead. Is it possible that I have to order a new battery? or I...
Using non standard chargers is probably the problem. If the battery has suddenly become sogged since using this charger then it may have done more damage than you want to know about.
Was it the correct polarity +ve Tip? was it the right amperage?
Magellan are specific in recommending you only use their charger and with reason, its correctly made for it.
You can try the new battery angle, but get advice on the charger.
As a small note.. Car chargers do NOT fully recharge batteries in GPS. Use an AC or USB charger. The car charger is a maintenance power supply. Always fully charge the unit prior to use and do not plug to car power until engine has been started.
These are standard rules with all non hard wired GPS and phones, ( but not always in the manual, have to have service and new sales someway!)
Please rate my help++++Thanks for using FIXYA
Aug 11, 2010 | Magellan RoadMate™ 1212 Car GPS Receiver
Roadmate 2000 will not turn on. charger light is lit. No response from unit. I turned it off and stored it for a few days, but now it is dead.
its possible it needs a new power port (very common problem on this and many other magellan gps) if your sure the charger is working..you said the light was on, then its working..
plug it in again to the charger, then press and hold the power button for up to 10 seconds.
if that fails, let me know and ill give you something else to try
bill
Mar 08, 2010 | Magellan RoadMate 2000 GPS Receiver
I have a legacy item (Roadmate 800). The battery was dead so I ordered a new one. The new battery powers on the unit but when I plug in ac charger I don't get a solid orange light, but a flashing green...
This is very common problem with this and many model of magellans.
Try the car charger.
Make sure
green light is on the car charger and let it plugged in for awhile, then hold the power button (up to ten seconds) until it starts..if that fails
The following Magellan 2000, 2200t, 2500, 3000, 3100, 3140, 3000, 3050, 4000, 4040, 4050, 5310 and the 6000 are known to have faulty dc connectors...if your Magellan
gps is not charging or will not power up, its most likely the dc power port...
You can
buy the port or get it repaired, HERE
if the links dont work or If you need further help, just let me know.
Feb 07, 2010 | Magellan RoadMate 800 GPS Receiver
It does no power on, can i charge it in tne phone charger
no, the magellan 2000 can not be charged with a phone charger (usb connection) you have to use either the car or house charger that was provided with the 2000 when it was bought or you can buy a replacement off sites like ebay.com
magellangps.com also sells them, but they cost double if not triple what you can get them for on ebay.com
if your having power issues with your 2000 and you have a car charger for it and the charger light is on, then the problem is probably in the power port inside the gps.
Make sure
You can get it repaired,
here
Or buy the port here
Jan 01, 2010 | Magellan RoadMate 2000 GPS Receiver
GPS doesnt turn on with power cord adaptor or 12v lighter socket
if you can verify that the car charger is ok, try plugging it in to your computer using the usb cable. the 1412 should charge with the usb cable. if it still doesnt turn on, try and reset the unit,little pin hole on the side.
Jun 08, 2009 | Magellan RoadMate 1412 Car GPS Receiver
Output voltage
Hello rcgibson, output of charger for (if this is correct 'Roadmate 800 GPS unit) AC wall power supply or 12/24 volt DC is 5 volt at 455 milliamp.
Oct 24, 2008 | Magellan Universal Ac Wall Power Supply...
Car Power Unit
I'm not sure that there is a car charger available for the GPS 310. There is no external port where you could plug it in, the only thing you can do for power is take extra AA batteries with you.
Jul 02, 2008 | Magellan GPS 310 GPS Receiver
Magellan roadmate 2000
I Reset the unit by switching reset switch on and off.
The switch is on left side of my gps.
Mar 02, 2008 | Magellan RoadMate 2000 GPS Receiver
Your best bet is to contact Magellan directly. Their website is not the easiest place I've ever navigated. I did not see a specific listing for the Roadmate 2000, but when I queried them about upgrades for your unit, the response was Roadmate 2000/2200T. Manuals are available, but again nothing was noted about supporting the 2000.
I've provided their phone # is below. Good luck.
800-707-9971
Feb 29, 2008 | Magellan RoadMate 2000 GPS Receiver
Magellan RoadMate 2000 GPS Receiver Logo
143 people viewed this question
Top Magellan GPS Experts
Marvin
Marvin
Will Halftowaite
Are you a Magellan GPS Expert? Answer questions, earn points and help others
