Question about HP LaserJet 1022 Printer
Noise in the Laser Jet 1022 Printer
Tarak Gole
I have one Laser Jet 1022 Printer. When I Give a Print option, Printer print documet complict, but there are some major noice in printer so Plz give me solution.
    Problem Solver:
  • 5 Answers
Try and check for broken gear- tooth on one of the sides of the machine
Posted on May 29, 2009
How do l download hp laser jet 1018 to mac book air.
The 1018 is not supported by HP with the Mac OS Mountain Lion. I found this on an HP forum and it worked for someone else. You could try this:
Thank you for posting,
Unfortunately, HP laserjet 1018 is not suported in Mac OS X 10.8 Mountain Lion. How evere you can use the builtin drivers that goes along with the operating system and select teh driver of another printer and check.
Connect the printer to the computer and then go to System Preferences and click on Print and Fax. In the Print Fax window, lick on the Plus sign and you will find the printer, please select the printer and then under print using click on the drop down and click on "Select print Software" and in the list, please select HP Laserjet 1015 pr HP Laserjet 1022 and check.
If you don't find these printers in the list, please download and install the latest print driver version 2.12 from the apple web site using the link below.
http://support.apple.com/kb/DL907
After downloading and install the update, please try the steps given above.
Mar 02, 2015 | HP LaserJet 1018 Printer
Usb light link
HP LaserJet 1022 is a "host-based" printer so it must be connected to a PC. Load the driver on PC first and connect the USB cable when software tells you to do so.
Will not work on a Linksys print server.
LaserJet 1022N & LaserJet 1022NW have "special" HP print servers that can support HP host based printers.
Nov 27, 2013 | Linksys Wireless-G WPS54GU2 Print Server
HP laser Jet 1022 only prints one page at a time
Jan 2013 Installed this new printer driver and all my HP 1022 problems disappeared; now printing perfectly back as usual!
HP Printer Drivers v.2.13 for OS X
Click on the link above or copy and paste the following address into your Web browser to view the article:<http://support.apple.com/kb/DL907?viewlocale=en_US>
Mar 05, 2012 | HP LaserJet 1022 Printer
My boss want to replace the black ink cartridge for one that prints color. Can this be done with the HP 12-a cartridges? HP Laser jet 1022
Unfortunately laser printers don't work this way. The laserjet 1022 was designed for black and white prints only. In order to do color printing with a laser printer you will need to purchase one that is designed to print in color. The laser printers work a bit differently than the inkjets - the laser printers have 4 toner cartridges, one each for Cyan, Magenta, Yellow, and Black, that work together to print a full color page. With the old inkjets you could just replace a black cartridge with a color one.
So, short answer: Sorry but no you can't make a laserjet 1022 print in color. :)
I would recommend looking at an entry level color laser printer from hp, such as the CP2025 (http://h10010.www1.hp.com/wwpc/us/en/sm/WF25a/18972-18972-3328060-15077-236268-3673580.html) if you are looking into purchasing a color laserjet.
Hope this helps
Please rate this post, thanks!
Mar 09, 2011 | HP 645A Magenta Toner Cartridge (C9733A)...
LaserJet 1022 Printer: After installation Hp laser 1022 printer itts show...
Make sure the cable from your printer is properly connected to the CPU
Make sure it is well recognized.
On start menu, click printer and faxes..
you will see your printer model.(if you said its offline then the image of your printer is blurred...right?)
Now right click on the printer model.. and click the "Use Printer Online"
After that you will see that the image of your printer is clear with the word "ready"
Try to print again.
May 16, 2010 | HP LaserJet 1022 Printer
Is the ricoh afocio 1022 a color printer and copier and how much is this machine worth used
This is a Black and White only copier. The value will vary depending on what options it has, how many copies are on the machine as well as condition. Is it used as is or is it a refurbished machine? These are questions that affect value but I will give you a ballpark. Figure around $250 for a base machine with no options and as is, as long as it makes good quality copies. All the way up to around $1,000 for a print/fax optioned machine that has been gone through and carries a warranty.
May 05, 2010 | Ricoh Aficio 1022 All-In-One Laser Printer
Our hp laser jet 1022n will not print jobs they just sit in the queue
if the printer in ready mode then please follow this instrution from the below URL
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00601512&cc=us&lc=en&dlc=en&product=439323
MAKIE SURE THAT THE PRINTER IS ONLINE
AND IT IS SELECTED AS ONLINE
THE PRINTER IS SET AS DEFAULT PRINTER
hope your issue gets resolved
thanks
regards
hamid
Feb 19, 2010 | HP Hewlett Packard LaserJet 1022 Printer
Not printing in foxpro 2.6 dos to hp laser jet 1020
You write "type the above line at command prompt". I dont't know Where exactly to write? Can you tell me!
Feb 05, 2009 | HP PSC 1610 All-In-One InkJet Printer
Printing problems - i can only print manual feed...
the manual tray is the is the one above the tray,
1-either your tray is set incorrectly must be set to Letter/Plain
priority is tray 2 not tray 1
tray one is the by-pass / manual
since this printer does not have a screen on it everything is setup through the PC.
print a configuration page and you will see all the settings
Aug 05, 2008 | HP LaserJet 1022 Printer
HP LaserJet 1022 Printer Logo
256 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
