Question about Avaya Definity 6408D Corded Phone
Change extension numbers
I have recently have clients moved desk is there a way I can change their extensions from their handset without repatching them in the comms room?
  • mannyregus Dec 10, 2007
    I have a luent 6408D+ phone how do I programme an extension to the phones to make it live after I have patch it through the voice panel,the main system is Definity but handset are either lucent or definitiy.
    New Friend:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 46 Answers
Everything you need to know about setting up this feature is explained in this cool users manual. It really helped me a lot, hope it will also helps you. Good luck! :)
Posted on Dec 09, 2013
    Problem Solver:
  • 8 Answers
For above answer Please check with the following commands
1. TTI should be enabled in your system
display system-parameters features Page 3
Terminal Translation Initialization (TTI) Enabled? y -- should be set to 'y'
2.display feature-access-codes Page 4
Terminal Translation Initialization Merge Code:
Separation Code:
needs to set the above TTI codes by using change commands.
Then only u can use above method to change their extensions from their handset
Posted on Jan 14, 2008
From the phone dial #66xxx (where xxx is the extension) to turn off that phone.
Then dial *66xxx (with the correct extension) to turn on that phone.
Hope this helps.
Posted on Nov 06, 2007
Relocate Extension to New Handset Location
Walking extension
dial*727 extn number then the pin
Feb 10, 2014 | Panasonic KXDT343 Phone
I have panasonic kx-t7730. How to set the intercom name and number?
Changing the name and extension number can be done through system admin programming from a phone extension allowed by the class of service assigned to that extension by the phone system installer. Typically the attendant phone is allowed this ability. From the programming phone press **1234(1234 is the default password) to access programming. Once in programming dial 003 for extension numbering then press . Enter the current extension number of the phone you want to change followed by the new extension number then press . Lift the handset to end programming. Access programming again by pressing **1234. Dial 004 for extension name programming then press . Enter the new extension number you programmed then enter the name for the extension. Press then lift handset to end programming.
It is possible that your phone has not been assigned an extension number, in that case system installer programming would need to be accessed to assign the port an extension number. The port number the phone is connected to would have to be determined. This could require tracking the wiring back to where it is connected into the phone system. If this is the case I advise calling a qualified service technician.
Dec 08, 2010 | Panasonic KX-T7730 Corded Phone
How do i Names to Extention numbers on the Panasonic KX-T7636
If you are using this phone on a Panasonic KX-TDA 30/100/200/600 system. From the Switcboard / Main telephone or Managers phone with the handset on the cradle/hook press Program * * or Program * # followed by the system password ( default is 1234). Now press 004 and then ENTER. Enter the extension number you want to change. Now enter the name (the same way as texting on a cellphone) To save the changes press AUTO DIAL / STORE. To go to the next extension press NEXT on the screen. When you are done lift the handset and put it down to exit program mode.
PLEASE rate/vote this answer if it was helpfull.
Nov 09, 2009 | Panasonic KX-T7636W Corded Phone
How do i change the phone extention number - Panasonic KX-T7665
It depends on your phone system, the smaller ones, 50, have modular jacks to distribute the extensions and you can simply move the pluged in extension wiring on the control unit, for instance if you are 102 and the other phone is 103, simply swap the plugs on the main control unit. The larger Panasonics have direct wiring so you need a punch tool and some cross wire to move an extension.
Oct 01, 2009 | Panasonic KX-T7633 Corded Phone
Moving extention number
you must change the number by programing the PBX or phisicaly change the jack in the PBX.Both solutions must be done by authorized personal.check who is serviceing your pbx and make a request.
Sep 15, 2009 | NorStar T7316E Corded Phone
Port moved but old extension still shows - how to update the hand
Try this link to download your model 2420 with either version 3 and earlier, or version 4 and later software .pdf reference guide.
Hope this helps.
Jul 10, 2009 | Avaya Definity 6408D Corded Phone
Nortel M7310 Phone moved to another jack, now no incoming calls
you need to go to your previous location and get the jack number, than go to the new location and get the jack number. now go to the phone system closet and look for these cable numbers on the 66 blocks. Swap the cross connect of the jacks and wallah your phone will be your s again!
Jan 20, 2009 | NorStar M7310 Corded Phone
Change/reprogram extensions
The easiest way to do this is move the cross connect in the closet. Get the jack number from each location and swapped the cross connect(wire). You could change the extension number in MB4-10 but it depends on the type of system you have.
Nov 18, 2008 | NEC DTU 8-1 Corded Phone
Station (extension) names
From extension 10 or 11
Feature 00
Left intercom
Left intercom
Right intercom
enter the extension you want to modify
press the left intercom
Enter the name.
When finished, press feature 00 to exit programming.
Nov 11, 2008 | Lucent PARTNER18 Corded Phone
Nortel norstar m7310 phone caller id problems
to find out your phone's extension dial
Feature *0 Intercom
May 08, 2008 | NorStar Meridian M7310 Phone
Avaya Definity 6408D Corded Phone Logo
1,252 people viewed this question
Top Avaya Lands Phones Experts
Oloyede Monsuru
Shehu Pro
Shehu Pro
Are you an Avaya Lands Phone Expert? Answer questions, earn points and help others
