Question about AOpen XC Cube EZ65 Barebone
Computer will not boot with second hard drive
Once I disconnect the second hard drive (SATA2) from my XC Cube edition, the computer boots fine. With it connected however, it stalls on the XC Cube logo upon startup. There is a single beep on startup, and then it just hangs on th logo.
I did start getting a Delayed Write Failure with the second drive about a month ago, but the problem just went away without me doing anything and it was fine for several weeks up until now. Please help!
The second drive is a Seagate Baracuda 1 Terabyte.
  • kpdigital May 29, 2009
    HI,
    Are  you saying try to add a different hard drive in place of the suspect drive and see if it works? Good idea.. Is there any other way? I dont have a third SATA hard drive.
  • kpdigital Jun 15, 2009
    The computer boots with the primary hard drive alone in either SATA slot. When the second HD is plugged in, the computer seems to never boot completely, but rather hang on the XCCube logo screen. There is a looping mechanical sound that I can hear..sounds like the whirl of the first HD, then a small "click" sound, then the whirl again and a click.. over and over again endlessly. Also, LEAD 3 on the motherboard keeps flashing forever. During normal startup, LEAD 3 flashes for a while during startup, but then stays solid, but again, while the second HD is plugged in, LEAD 3 flashes forever.
    Is this a mobo problem? I dont have a 3rd Sata HD to test.
    Thank you
  • 489 Answers
It look like harddisk problem is keep going. plug out the disk and try. if it continues and says there is not problem you can say mmotherboard is working well and you have really disk problem
Posted on May 29, 2009
  • meteshadow May 29, 2009
    put out the harddive and work without harddive the pc.  look whats going on.  i wanna sure if it is really disk problem or mainboard.
    pls rate this when you solved.
My WD 1tb harddrive is no longer showing up on my computer. When I plug it in to the USB my computer states the drivers are installed correctly but it is not showing on "My Computer" or any other...
Connect the external drive to another computer and observe if it's going to work perfectly on that computer.
Which ever the case may be, here is what you need to do on your computer;
Insert the external drive into your computer
Go to device manager.
Go to the name of the external drive.
Right click on the external drive and click 'Uninstall"
Allow the external drive uninstall from your computer.
If possible uninstall every other device under the "Universal serial bus controller (usb).
Once this is done, disconnect/remove the external drive from your computer.
Restart your computer.
Wait a while for the computer to boot computer. Also whatever you have uninstalled from the device manager, might install automatically. Which ever the case maybe, make sure your computer has finished booting or installing any device before you attempt to insert the external drive into the usb.
Now insert the external drive and wait for the computer to install the external drive, then observe if it will open this time around.
By now it should open. But if it doesn't open, please let me know so that I may direct you further on what next to do.
I wish you good luck.
Regards.
Jun 12, 2011 | Western Digital My Book Essential Edition...
Hd103uj has stopped working in my external box so I swapped it with a drive in my computer but it wouldn't boot, I switched it back to the original and it booted no problem. I only used this drive a few...
Check the jumper settings on the new drive drive,it should be set to MASTER otherwise it will not boot. Also check your BIOS settings to insure that the computer is seeing the drive.
Jan 05, 2010 | Samsung 1TB SATA2 7200RPM 32MB HD103UJ 334...
Acer Aspire 5100 will not boot
Two possible Solutions:
1) The Hard Drive has come unseated - Disconnect the Power and REMOVE all connections, Close the Screen & Turn your Laptop Upside Down and Remove the Battery, Locate the Hard Drive Access Panel and Remove the Screws from the Panel, Remove the Panel, Remove the Hard Drive. Carefully Replace the Hard Drive, Replace the Panel and Reconnect the Battery & Power Supply. See if the Computer will Start
2) The Operating System is Damaged OR the Hard Drive is Dead - You will need to slave Your Hard Dive into a Second Computer and Backup ALL you Personal Data OR RISK loosing it. If the Second Computer can NOT read the Drive, the Hard Drive is Dead (A Computer Repair Company may be Able to Help)
Once your Data is Safe, you can try to Repair the OS by Booting your Computer with the Drive in it. Begin pressing F12 or F10 at bootup (Once a Second). You will be presented with an Options Page for:
System Restore (FIX WINDOWS)
System Recovery (Wipes your Computer and Retores the Factory Software)
Hope this Helps!
Dec 22, 2009 | Acer Aspire5100 Notebook
Yea sorry, forgot that tid-bit of info. It,s the W3118 eMachine / Gateway FIC K8MC51G
This issue can be caused by any of the below reasons.
-Corrupt boot files on the computer.
-Settings for hard disk drive are not correct.
-Floppy diskette or CD in computer causing issue.
-Boot devices not set properly.
-BIOS corrupt or misc. setting not set properly.
-Connections loose or disconnected.
-Bad Hard disk drive or other bad hardware.
Solution:
If the computer has no bootable files on the drive it is attempting to boot from it is possible that the computer may halt at " verifying dmi pool data..."
To resolve this issue:
Boot from a bootable floppy diskette. Ensure that this diskette was made on the same Microsoft Windows operating system that is installed on your computer.
Once at the A:\> prompt type "sys c:" and press enter. This should report the message "File system transferred." Once transferred remove the diskette and reboot the computer.
If the computer continues to not boot attempt to re-create the master boot record by booting from the bootable floppy diskette again. Once at the A:\> prompt type "fdisk /mbr" and press enter. This should return you to the prompt without giving you any message. Once at the prompt remove the diskette and reboot the computer.
Note: The above information only applies to Microsoft Windows users. If you are running a Linux / Unix variant or other operating system such as OS/2 and the computer is freezing at this DMI message ensure that Linux / Unix has been properly installed first and/or your boot manger is not corrupt.
The computer freezing at "Verifying dmi pool data..." may be caused when the hard disk drive settings within CMOS are not set properly. Enter CMOS and verify that the hard disk drive settings are set properly and/or that it is set to Auto Detect.
Verify no floppy diskette or CD is in the computer. In some cases the computer may be trying to boot from either of these drives causing issues with the boot sequence.
The computer stopping at " verifying dmi pool data..." can be caused when the boot devices on your computer are not set properly in CMOS. First, verify that no CD or diskette is in your computer. If a CD or diskette is in the computer attempt to remove this first to determine if it was attempting to boot from it.
If No CD or diskette is in the computer and your computer still halts at the DMI message enter CMOS setup and verify that the boot options are set properly. We commonly recommend that the floppy be set the first boot device, hard drive as the second boot device and the CD-ROM as the third boot device.
If none of the above recommendations have resolved your issue attempt to reset the BIOS / CMOS settings to the factory or default settings.
If the computer has been recently moved or new hardware has been installed in the computer it is possible that a connection may be loose or even disconnected. Verify that the hard disk drive, floppy and CD-ROM cables are properly connected.
Bad hard disk drive or other bad hardware
If you computer continues to freeze at the DMI message after attempting all of the above recommendations it is possible that the computer may be freezing because of a bad hard disk drive or other bad hardware in the computer.
Before replacing any hardware we first recommend you attempt to erase everything on the hard drive and start over.
If you're unable to get to the point of re-installing the operating system it's likely your computer has a hardware issue and it's suggested that the hard drive be replaced. If that doesn't resolve the issue then have the motherboard replaced.
Oct 20, 2009 | E-Machines eMachines Desktop PC
Purchased an external hard drive for backup. When
When you first turn your computer on, during the first few seconds the screen should give you information about what is happening, AND it should tell you to press the delete key in order to get to the bios settings. Do that (press the key several times to make sure you get there). Once you get to the bios settings find the ones that control the boot disc (usually you will see 1st boot and 2nd boot, and each will allow several possibilities, including floppy boot, if you have one, as well as cd or dvd boot, etc.) Make sure your hard disk is selected as your first boot choice, then save the selection and reboot.
I think this will work for you.
Oct 06, 2009 | Western Digital My Book Essential Edition...
1TB Western Digital External keeping system from booting up
You need to go into the BIOS of your computer and change the boot order of your computer.  Your computer must be set to boot from your main hard drive only.
Mar 05, 2009 | Western Digital My Book Essential 1TB...
Vista running on AOpen Ez65
I am taking it that you currently have XP installed?  You need to boot the computer from the Vista CD.  Please note that this will erase your hard drive.  So back up any important stuff before you attempt this.
Mar 04, 2009 | AOpen XC Cube EZ65-II Barebone
2nd Hard drive not recognized
If your using IDE hard drives i would try to put them both on the same cable on the primary IDE controller. Then set you main hard drives jumpers and the second hard drive to cable select not slave. Try to boot if the boot fails your goiong to need a Windows 98 boot floppy with FDISK. You need to start up the 98 boot disk with out CD support then when it reaches a command prompt start fdisk. ONce fdisk is up format and partition the second drive. Now it should work. :) Check that the harddrive is detected in the BIOS, it may have become disconnected, it should also be the master drive on the primary IDE. If the drive is not detected in BIOS there is little chance of it working
Thank you....
Jan 29, 2009 | IBM ThinkPad X31 2672 Notebook
Acer 3690
Could be various causes just follow the information below and you should solve it.
Good luck
NTLDR is Missing
Press any key to restart
Boot: Couldn't find NTLDR
Please insert another disk
NTLDR is missing
Press Ctrl Alt Del to Restart
Cause:
  1. Computer is booting from a non-bootable source.
  2. Computer hard disk drive is not properly setup in BIOS.
  3. Corrupt NTLDR and/or NTDETECT.COM file.
  4. Misconfiguration with the boot.ini file.
  5. Attempting to upgrade from a Windows 95, 98, or ME computer that is using FAT32.
  6. New hard disk drive being added.
  7. Corrupt boot sector / master boot record.
  8. Seriously corrupted version of Windows 2000 or Windows XP.
  9. Loose or Faulty IDE/EIDE hard disk drive cable.
Solutions:
Many times this error is caused when the computer is attempting to boot from a non-bootable floppy disk or CD-ROM. First verify that no floppy diskette is in the computer, unless you are attempting to boot from a diskette.
If you are attempting to boot from a floppy diskette and are receiving this error message it is likely that the diskette does not have all the necessary files and/or is corrupt.
If you are attempting to install Windows XP or Windows 2000 and are receiving this error message as the computer is booting verify that your computer BIOS has the proper boot settings. For example, if you are attempting to run the install from the CD-ROM make sure the CD-ROM is the first boot device, and not the hard disk drive.
Second, when the computer is booting you should receive the below prompt.
Press any key to boot from the CD
Important: When you see this message press any key such as the Enter key immediately, otherwise it will try booting from the hard drive and likely get the NTLDR error again.
Note: If you are not receiving the above message and your BIOS boot options are set properly it's also possible that your CD-ROM drive may not be booting from the CD-ROM properly. Verify the jumpers are set properly on the CD-ROM drive. Additional information about checking the CD-ROM drive connections can be found on document CH000213.
Additional information: This error has also been known to occur when a memory stick is in a card reader and the computer is attempting to boot from it. If you have any type of card reader or flash reader make sure that no memory stick is inside the computer.
Verify that your computer hard disk drive is properly setup in the BIOS / CMOS setup. Improper settings can cause this error. Additional information on how to enter the BIOS / CMOS setup can be found in document CH000192.
Windows 2000 users
Windows XP users
Windows XP users
  1. Insert the Windows XP bootable CD into the computer.
  2. When prompted to press any key to boot from the CD, press any key.
  3. Once in the Windows XP setup menu press the "R" key to repair Windows.
  4. Log into your Windows installation by pressing the "1" key and pressing enter.
  5. You will then be prompted for your administrator password, enter that password.
  6. Copy the below two files to the root directory of the primary hard disk. In the below example we are copying these files from the CD-ROM drive letter, which in this case is "e." This letter may be different on your computer.
    copy e:\i386\ntldr c:\
    copy e:\i386\ntdetect.com c:\
  7. Once both of these files have been successfully copied, remove the CD from the computer and reboot.
Edit the boot.ini on the root directory of the hard disk drive and verify that it is pointing to the correct location of your Windows operating system and that the partitions are properly defined. Additional information about the boot.ini can be found on document CH000492.
If you are getting this error message while you are attempting to upgrade to Windows 2000 or Windows XP from Windows 95, Windows 98, or Windows ME running FAT32 please try the below recommendations.
  1. Boot the computer with a Windows 95, Windows 98 or Windows ME bootable diskette.
  2. At the A:\> prompt type:
    sys c: <press enter>
  3. After pressing enter you should receive the "System Transferred" message. Once this has been completed remove the floppy diskette and reboot the computer.
This issue has been known to be caused by a loose or fault IDE/EIDE cable. If the above recommendation does not resolve your issue and your computer hard disk drive is using an IDE or EIDE interface. Verify the computer hard disk drive cable is firmly connected by disconnected and reconnecting the cable.
If the issue continues it is also a possibility that the computer has a faulty cable, try replacing the hard disk drive cable with another cable and/or a new cable.
Oct 31, 2008 | Acer Aspire 3690-2196 Notebook
Beeping with no boot up
Beep codes mean something has gone wrong with the computer. Beep codes most likely happen for: Memory, Processor, Motherboard.
Try reseating the memory in the computer.
Jul 11, 2008 | AOpen XC Cube EZ65 Barebone
AOpen XC Cube EZ65 Barebone Logo
208 people viewed this question
Top AOpen Computers & Internet Experts
Matthew Spark
Matthew Spark
David
David
Gareth Cockram
Gareth Cockram
Are you an AOpen Computer and Internet Expert? Answer questions, earn points and help others
