Question about HP NW9440 CD2.16 2GB 100GB-17IN COMBO Wireless WXPP Plus 10 off w eBillme PC Notebook
How to refil HP 10 inkjet cartridges?
Carridge details.
Cyan Ink Cartridge (C4841A)
Yellow Ink Cartridge (C4842A)
Magenta Ink Cartridge (C4843A)
Black Ink Cartridge (C4844A)
  • 696 Answers
First and foremost: Do not ever attempt this unless you accept ALL associated risks.
Second: Never, ever touch the small black primer in the middle of the cartridge unless you are willing to wear the ink, which stains all but permanently.
Third: I will give you the instructions, but advise you to reconsider, and have a pro fill it.
Fourth: Do not fill these cartridges with a "Universal" Ink as no such ink actually exists despite several companies claims. Buy your ink from a reputable refilling business or hire them to do the work. Failure to use the appropriate inks WILL result in crappy printing quality and will likely damage your print heads.
Now, if you're ok with all of the above, go ahead at your own risk.
I will describe the process for the black cartridge, once you're done repeat with the appropriate colour of ink for each of the other three.
You will need: 1 pocket knife, 4 Swine needles with 10-12gauge blunt tip, 1 small set screw or eyelet screw, tape.
Cut the labels on both sides of the bottom cap, then pop it off.
squeeze the two narrow edges of the cartridge with one hand and pull up on the insert with the other. It's a tight fit so this may take a couple tries.
once you have the mylar bag and pump system out of the shell set it gently on a soft surface as the mylar is somewhat delicate.
use the eyelet screw to thead into the small black plug about 3mm, then pull the plug out by tugging on the eyelet screw.
Set this aside and load your needle with ink, the amount you need should be slightly less than the listed volume on the outside shell of the cartridge you're working on.
Insert the tip of the needle 4-5mm inside the filling hole and begin filling slowly, as you aproach 3/4 full tilt the cartridge until the filling hole is on the high side and that corner is facing straight up.
When it gets to the top, retract the needle, reinsert the plug and reverse the eyelet out of the plug. Be sure the plug is all the way in.
Reinsert the mylar and pump section into the shell and recap it, retape the bottom section.
Turn the cartridge so that the other bottom corner is now the high side and allow it to stand for abour 3 hours, continue on to the next cartridge.
When you have completed all four cartridges and allowed them to stand for 3 hours, take them one at a time, insert the needle used for that colour into the ink feed and draw up slightly, pump the primer twice, then draw up again. As long as there is air bubbling up, continue, as soon as you get a short, smooth flow of ink, the cartridge is primed.
Now reposition the cartridges in the printer and you're ready to print.
Clean up any messes you've made with running alcohol as best you can(won't clean perfectly) or with an enzyme based cleaner such as the ones used to clean pet urine(will break down the dyes).
Hope this helps FixYa,
Chris
Posted on May 29, 2009
  • HP Master
  • 32,281 Answers
There are ink refill kits on the market and the Internet. Use Google to find refill suppliers.
You can also buy non genuine ink cartridges that are cheaper.
Im using hp deskjet 2660 cartridge says INTRODUCTORY HP TRICOLOR PRINT CARTRIDGE (colors) cyan magenta yellow 60 it's not producing yellow images that i printed are in pink or purple i...
This model printer has only two slots for ink cartridges. One is for a black ink cartrigde and the other is for a tri-color cartridge which contains cyan, magenta and yellow inks.
This tri-color cartridge has run out of yellow ink, you need to replace this tri-color cartridge.
Aug 12, 2011 | Office Equipment & Supplies
Dose the printer epson stylus NX125\127 comes with a USB wire?
Yes
http://www.epson.com.au/products/multifunctional/stylusnx125_specs.asp
but you can buy one yourself for less than $5.
Jul 19, 2011 | Epson Stylus Multifunction Inkjet Printer/...
Canon MP610 Printer
You cannot switch to the larger black cartridge. You are using a CMYK (Cyan, Yellow, Magenta, Black) format for printing color images.
The larger cartridge is used for text only. The smaller black cartridge is used for color or graphic images.
If the black cartridge was not present, every time you needed black in an image, it would have to come from the composition of Cyan, Magenta and Yellow. This would greatly reduce the life of the color cartridges.
Don
Dec 12, 2009 | Canon PIXMA MP610 InkJet Printer
I need black ink for my lexmarkc540n printer
This is the worst printer! i advise everyone not to buy!! changing ink every week!!!!! total garbage!!!!!!
Nov 08, 2009 | Lexmark C540N PROD SPECS TBD Printer
Photosmart C5280. Instructions on photo cartridge 348 say remove both black and colour cartridges, then install photo cartridge in right hand cartridge holder. Printer screen then tells me to install...
Your printer uses the following cartridges:
HP 74 - Black ink
HP 75 - Cyan, Magenta, and Yellow ink
HP 99 - Photo Black, Light Cyan, and Light Magenta
You need Photo Black, Cyan, Magenta, Yellow, Light Cyan, and Light Magenta to print photos. To accomplish this you install the HP 99 photo cartridge where your HP 74 black cartridge usually goes and you keep the HP 75 color cartridge where it's at. I don't know why your printer told you to remove both cartridges, then reinstall the HP 75 color cartridge.
Oct 10, 2009 | HP Photosmart C5280 InkJet Printer
Type of catridge epson stylus R390 uses can't find
You can see the reference on the cartridge itself.
Take it with you when you buy new ones.
Jul 29, 2009 | Epson Stylus Photo R390 InkJet Printer
Error message after replacing black ink cartridge
This happened to me twice, You can possibly have no ink in your cyan,magenta and yellow , you would then have to replace them to work the set. I had to do that and it worked =]
Jul 18, 2009 | Epson Stylus NX400 InkJet Printer
Brother DPC- 115C
What error does the machine show up?
Plz give some more info in detail!!!!!
Oct 24, 2007 | Brother DCP-110C All-In-One InkJet Printer
HP NW9440 CD2.16 2GB 100GB-17IN COMBO Wireless WXPP Plus 10 off w eBillme PC Notebook Logo
122 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
