Question about O2 Xda Trion Smartphone
O2 Trion/HTC Hermes startup fault
My recently acquired unlocked O2 Trion (HTC Hermes) has developed a fault. When I tap 'Start' on the opening screen the dropdown list appears for a fraction of a second and then vanishes. The only way I can access the list is to press in the scroll wheel on the left side, I can then select the program I want but as soon as I release the scroll wheel the phone reverts back to the opening screen. I have tried both soft and hard resets and also updated the ROM to no avail. It is as if something is not latching or there is a faulty connection. Sometimes when the wnd is in the right direction it will work for about five minutes but then reverts back to the fault condition.
I trun on my phone its stay on windows mobile sceen will not do anything els
Posted on May 17, 2010
How to restore HTC One V T320e smartphone
Performing a factory reset using hardware buttons
If you can't turn HTC One V on or access settings, you can still perform a factory reset by using the hardware buttons on HTC One V.
1. Press and hold the VOLUME DOWN button, and then press and hold the POWER button.
2. Wait for the screen with the three Android images to appear, and then release the POWER and VOLUME DOWN buttons.
3. Press VOLUME DOWN to select FACTORY RESET, and then press the POWER button.
[img title="unlock HTC ONE V hard reset forgotten password" alt="HTC ONE V hard reset" src="http://www.hard-reset.com/images/htc_one_v_hard_reset.jpg" height="350" width="180">
will remove any applications you've downloaded and installed. Be sure to back up
any data and files you want to keep before you do a factory reset.
Performing a factory reset from settings
1. Slide the Notifications panel open, and then tap Settings.
2. Tap Storage > Factory data reset.
3. Tap Reset phone, and then tap Erase everything.Performing a factory reset via settings
The most convenient way to do a factory reset is via the settings.
1. From the Home screen, press MENU, and then tap Settings.
2. Tap SD & phone storage > Factory data reset.
HTC One V not responding?
If HTC One V frozen and does not respond when you touch the screen or press the buttons, you can still restart it by press and hold the POWER button for at least 10 seconds, and then release it. HTC One V then restarts.
Sep 26, 2013 | HTC One V T320e - 4gb - Grey Unlocked...
Camera on XDA trion focusses correctly for neat focus, but shows a blurred screen for distant focus. When originally switched on to the camera and '1x' focus appears by default, a blurred green...
Most likely you have activated the Macro function. Usually this function is illustrated by a flower icon. This function is used to shoot from very small distances. Deactivate the macro function.
May 07, 2011 | O2 Xda Trion Smartphone
I need ROM for my htc tytn2 (hermes)
what country rom would like?
http://forum.xda-developers.com/forumdisplay.php?f=306
go there first thing you need to install is the hermes sim & CID unlocker if you havent got HARDspl installed already. Then you can floash any rom on that specific forum, DO NOT try to flash a rom from another type of phone. A hermes is a also a 8525,mda vario II jasjam etc so any roms on that link will be fine for your device and happy flashing
If you found this info useful please vote for me
Mar 17, 2011 | Computers & Internet
Password lost to hernes htc/trion,need unlock code
When i suffered with the problem i get my unlock code from the site my friend suggested me.click here to get your unlock code.
hope this helps..
Sep 06, 2010 | HTC Computers & Internet
Xda trion turns into white screen
You need to return it to an o2 store for repair. If it's not under guarantee, I'd be very wary of spending any money on it as I had exactly the same problem and my phone has been back time and again for repair and still isn't right. Could be very costly.
Apr 06, 2009 | O2 Xda Trion Smartphone
My o2 xda trion will not sync up to my pc. any ideas???
Hiya,
the software that came with the trion is out of date, it offers microsoft active sync 4.0 or 4.2.
Go to Microsoft site and get Microsoft active Sync 4.5.
It worked for me
Good Luck
barneyyeoman
Feb 23, 2009 | O2 Xda Trion Smartphone
At&t 8525 to tmobile wing
NO you can't do that but you can unlock the CID and sim and then flash a custom hermes rom from xda-developer.com but first you need to run thi unlocker to unlock the sim and CID.
http://pof.eslack.org/hermes-unlocker/
Run this unlocker on your phone. Follow the instructions exactly. Don't unlock the CID unless you planning on installing another custom rom other than ATT on it.
Aug 20, 2008 | Cingular Wireless Cingular 8525 Smartphone
RESET phone solution.. pls help..
hi,
   u just do one thing..restart ur phone again..& when it asks u to set up ur windows..than tap on the black spot firmly ...u just need to tap on than spot only..nthing else after that leave..it will start processing..& ur phone will be on.
Thanks
Gizmo1
Oct 22, 2007 | O2 Xda Trion Smartphone
DELL LCD monitor E151FPb turn white
I also tried re-soldering joint L781 on the main power control board (see Solutions #2 and #7). It worked. My 15 inch Dell flat panel LCD is working again, white screen gone. The solder around the pin did looked different to to the other joints...a very slight gap around the pin as though it wasn't contacting properly. To locate L781, look at the bottom of the PCB (the side with the soldering) with the power plug socket at the edge closest to you. L781 is in the top left quadrant of the board, about 2 inches in from left, 1 inch down from the top. For good measure, I also tried the solution that suggested trimming a millimeter of the end of the two data ribbons that plug into the smaller control board, although I couldn't see anything wrong with the data ribbons. I did this at the same time as resoldering L781 so not sure if it made any difference.
Feb 25, 2007 | LG 37LP1D 37 in. LCD Television
O2 Xda Trion Smartphone Logo
83 people viewed this question
Top O2 Computers & Internet Experts
Computer Repairing
Computer Repairing
xxxxxx xxx
Martin Murray
Are you an O2 Computer and Internet Expert? Answer questions, earn points and help others
