Use eePC in U.K. with different power connections
Want to make sure I can use my eeePC in the U.K. without blowing it up.
    Problem Solver:
  • 5 Answers
What is the current voltage rating of your eePC and find out UK's standard voltage rating
Posted on May 29, 2009
Drivers Web Cam asus eeepc 4g Windows XP
hello,
 in 99% procent windows xp contains drivers for eepc 4g webcam, at least 10 of them that i have reinstal win xp on them, any way if when u open my computer and down after removable device is not the camera u can try to install chipset driver, here is link for all drivers that u need for eeepc 4g:
http://support.asus.com/download.aspx?SLanguage=en&m=Eee+PC+4G+Surf%2fXP&p=20&s=1&os=17&hashedid=n%2fa
advice: install atk driver is important for battery life
best regards
Sep 22, 2011 | ASUS Eee 4G Notebook
Tip
EeePC 701-sd
If you Own a eeepc 701-sd you can get it to tell you when the piggybacking router is switching you out of their network,just manually configure the settings and learn to interpret the different "not connected" pages posted, each page gives a different type of error message,mess around with the settings and soon you will be able to duistinguish the difference between the messages--Linux only!
on Sep 05, 2010 | Computers & Internet
Trying to connect to home wifi with netgear router and EEpc G2g
Chekc your security settings, it can be that Eeepc not correctly determine security settings. Try to set all security for your SSID manually.
Apr 19, 2010 | ASUS Eee PC 2G Surf Notebook
Connect tv to eeepc 701sd
hold down the keys for a few seconds ,make sure you havent pressed Fn-F1 in error as this will put the eeepc into suspend/sleep mode
Feb 01, 2010 | ASUS Eee PC 701 Notebook
Can i expand the HDD memory of my EePc 4g?
If you have the EeePC 4G (which I suspect you have, given specs, then I'm afraid the answer is no. The SSD (which is what is used as a 'hard disk in your netbook) is hard-soldered to the main board. You can, of course, add SD cards or USB Pens to increase your storage space.
In Windows, you can also set your "My Documents" folder to work from a different location, such as the SD card. This may help you too.
Aug 13, 2009 | ASUS Eee PC 4GB Notebook
Cannot connect to wifi
i had the same problem with my sisters eeepc so this is what i did
1. if u can: connect the eeepc to your router (internet box) using the Ethernet cable. the local area connection should then connect automatically if not connect through the network program on Linux.
2. if you are connected go to settings tab and then add or remove software
3. wait for the eeepc to find the new software (may take a bit of time), once it has found all new possible updates go to the settings tab in the add/remove software program and scroll down until you find Wireless update/patch or something similar.
4. click install and the ok, it will then dowload the new update (don't take long) and install it
5. once the update has completed it will ask you to reboot the eeepc do this and when you log back on click on the wireless network icon
6. find your SSID and enter any security and whatever
7. you should be online after that
Aug 03, 2009 | ASUS Eee PC 1000H Laptop
Unable to connect EEEPC 701 to BT HOME HUB 2
sometimes the best thing to do is start over.
reset any hubs, routers, switchers, etc.
then (just fro now) remove any firewalls,
or software that may get in the way.
You want to start with a bare minimum configuration and build from there.
eeepc works well with windows networks, the ethernet connection should just work, without additional software.
does eepc connect to other networks?
can other laptops connect to your network?
check all settings: ip address, dhcp or static, passwords, etc.
Try a "wired" ethernet connection, then try the wireless connection. if all else fails, use F9 (or DVD disk to reset/reload the system. i.e. start over.
Mar 26, 2009 | ASUS Eee PC 701 Notebook
Not connecting
could do with some more detailed information please
Nov 10, 2008 | ASUS Eee 4G Notebook
Can a WEbcam be installed
Most 701 models came with a web cam built in.
You can install an external one easily.. just plug it in to the usb port.
Previous poster is wrong... why would you need a Cd drive ?
You could either download the drivers from the webcam maker's website, or simply copy the file from the CD to a SD card with another computer. If you have a home network setup, you could simply copy the files via network file sharing.
If you have the linux version of the EeePC 701, then make sure you buy a compatible webcam that has drivers in linux.
Jun 19, 2008 | ASUS Eee 4G Notebook
Computers & Internet Logo
47 people viewed this question
David Payne
David Payne
