It keeps coming up with 'your ipod could not be restored becuase your firmware file is corrupt; i deleted the firmware file and downloaded the new one but it still doesnt work please help.
My Ipod ask me to restore. I restored it and it just keeps poppin up after it resets it self telling me that it need to be restored again. How Do I fix this problemMy Ipod ask me to restore. I restored it and it just keeps poppin up after it resets it self telling me that it need to be restored again. How Do I fix this problem
AnonymousDec 18, 2007
this seems to be a problem on the new ipod touch. i went through there tech support to the highest levels. it seems the have some quality control issues and/or are not addressing core problems with their firmware codethis seems to be a problem on the new ipod touch. i went through there tech support to the highest levels. it seems the have some quality control issues and/or are not addressing core problems with their firmware code
AnonymousFeb 01, 2008
firmware file not foundfirmware file not found
AnonymousMar 22, 2008
wow turdswow turds
AnonymousMar 31, 2008
my ipod classic will not let update or reload it becuse frimware is corruptmy ipod classic will not let update or reload it becuse frimware is corrupt
AnonymousNov 10, 2008
me too there are extange colors on the scream
You can't post conmments that contain an email address.
Sometimes a iPod malfunction occurs that results in the Apple logo freezing on the screen of the iPod. When this happens, toggling the Hold switch or resetting the iPod typically resolves the problem. If following the manufacturer's instructions on resetting the device fails to get a response from your iPod, however, you must troubleshoot other potential solutions. In addition, taking the time to find the cause of the problem can help you prevent a recurrence of the issue.
Battery Allowing the battery to discharge completely may unlock an iPod stuck on the Apple logo. To drain the battery, leave the iPod with the Apple logo on the screen and place it in a drawer or in another safe place. Do not attempt to use the iPod until the battery drains and the screen goes black. This may take a day or more depending on the current level of battery charge. Once the battery drains, connect the iPod to your computer or to the wall outlet using an AC adapter and charge the battery completely before turning on the device. b> Restore If the iPod remains frozen on the Apple logo after draining and recharging the battery, you may need to restore the device to original factory settings. Unfortunately, this results in the loss of all data and media files stored on the iPod. Restoring the iPod, however, does not delete the files stored in the iTunes library, so you can still get your data back onto the iPod. Follow the specific instructions for your iPod model when restoring the device. Upgrade Software Problems with the version of software installed on your iPod may cause the device to freeze. Upgrading the software may resolve the problem because the updates released by Apple often include both bug fixes and software enhancements. In addition, installing the current release of the iTunes software also may resolve the freezing problem experienced by your iPod. File Corruption Often, a corrupt file can cause your iPod to fail. If you notice that the problem recurs after playing a specific song or video, then delete that file from your iPod. If the problem occurs again after synchronizing with iTunes, delete the file from your iTunes library. Then import the original file into iTunes again or re-download the file. Typically, if a corrupted file is behind the iPod freezing, a reset temporarily restores functionality until the problematic file plays again. b> App Overload Installing apps on your iPod touch can give you more than just fun or informative software. Running too many memory-intensive apps at one time can overwhelm the device and cause your iPod touch to freeze. A single problematic app may have the same effect. Limiting the number of apps running at one time or removing troublesome apps may resolve this problem.
if you want to
downgrade or upgrade, choose the firmware you want to downgrade to, then go to
itunes and shift-click on restore and choose the firmware you want to change to.
this will restore your ipod touch
Normal
0
false
false
false
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";
mso-ansi-language:#0400;
mso-fareast-language:#0400;
mso-bidi-language:#0400;}
goto the website http://www.felixbruns.de/iPod/firmware/
and download the selected firmware for the ipod touch model you have. if your unsure if the model /
type you can goto http://www.felixbruns.de/iPod/firmware/#
and type in the last 3 numbers of your serial number to find out
if you want to downgrade or upgrade, choose the firmware you want to downgrade
to, then go to itunes and shift-click on restore and choose the firmware you
want to change to. this will restore your ipod touch
According to Apple, if you have forgotten the code, you can unlock the IPod by doing the following:
Connect your IPod to the primary computer you use it with (the first one IPod synced with), and open iTunes. When you disconnect iPod from the computer, it will no longer be locked. If you can't unlock IPod using either [the code or connecting it to the computer you use to manage its songs]. . . you can restore your iPod to factory settings using iPod Updater. Please note that this will erase all data on your iPod. Afterwards, you can add your music and data back to your iPod.
If you want to change the primary computer that your IPod is associated with, do this:
1. Restore your iPod. WARNING: The restore process cannot be undone. All of your songs and files will be deleted. Always make a backup of your important data.
2. Connect your iPod to the computer that you want to be the primary computer.
3. Open iTunes and synchronize. Apple also notes that company "representatives cannot unlock an iPod if you forget your combination. If you can't unlock your iPod and you don't have access to the primary computer, your only option is to restore the IPod, which will erase all music and data."
Good Luck, I hope this helps Please rate me... Thank You
Just follow these instructions and restore your touch.
Normal
0
font-size:10.0pt;
font-family:"Times New Roman";}
Iphone
and itouch dfu mode Plug the
usb cable into the Ipod and NOT into the computer. Hold the
Home Button down for 5 second (do not release it) Then
Press and hold the Power Button for approx 10 secs (count them out) Your iPod
will reboot. Release
the power button and continue holding the Home button for an additional 27secs. You may
see the screen go blank or not. Plug the
USB end into the computer with itunes open. Your ipod
will mount in recovery mode. Restore
it and Your all set.
If you are trying to jailbreak it, restore it with the firmware that you intend to do the jailbreak with. when you restore, press shift and Restore at the same time and chose the firmware version from you computer. I would suggest you use quickpwn to jailbreak your touch. It seems to be the most effective and relaible.
I have the same problem. But it's easy to fix. You must connect your ipod to a pc and then you must go to My computer>(select your ipod and open the folder) and then delete the folder - .Library - It's done!
Ensure that you
have an active Internet connection as new versions of iTunes and iPod
Software may need to be downloaded to your computer.
Download and install the latest version of iTunes if you do not already have it installed.
Open iTunes, and then connect your iPod to your computer using the USB or FireWire cable that came with your iPod.
After a few moments, your iPod will appear in the Source panel in iTunes.
Select your iPod in the Source panel and you will see information about your iPod appear in the Summary tab of the main iTunes windows.
Click
the Restore button. You will be prompted with one or more restore
options that may prompt iTunes to automatically download the latest
iPod Software. The 4 possible restore options are:
Restore Option 1: Restore - Restores with same iPod Software version already on iPod.
Restore Option 2: Use Same Version - Restores with same iPod Software version already on iPod even though a newer version is available.
Restore Option 3: Use Newest Version - Restores with the latest iPod Software available.
Restore Option 4: Restore and Update - Restores with the latest iPod Software available.
If you are using a Mac, a message will appear prompting you to enter an administrator’s name and password.
A
progress bar will appear on the computer screen indicating that the
first stage of the restore process has started. When this stage is
completed, iTunes will present one of two messages on screen with
instructions specific to the iPod model you are restoring.
Restore Instruction 1: Disconnect iPod and connect it to iPod Power Adapter (typically applies to older iPod models).
Restore Instruction 2: Leave iPod connected to computer to complete restore (typically applies newer iPod models).
During
the stage 2 of the restore process, the iPod will show an Apple logo as
well as a progress bar at the bottom of the display. It is critical that the iPod remains connected to the computer or iPod Power adapter during this stage. Note: The progress bar may be difficult to see since the backlight on the iPod display may be off.
After
stage 2 of the restore process is complete and the iPod is connected to
the computer, the iTunes Setup Assistant window will appear asking you
to name your iPod and choose your syncing preferences similar to when
you connected your iPod for the first time.
wow turds
