Question about Ryobi ZRTS1342L Factory-Reconditioned 14 Amp, 10" Compound Miter Saw with L
How do I replace my mitre saw blade?
The arbour on my Ryobi Mitre saw is not a 5/8" circle, it's more of a rectangle with rounded edges. Where do I get a blade for this?
  • 285 Answers
It should still easily fit a 5/8" blade. The arbor shape shouldnt have any effect on the type of arbor hole needed on the saw blade (only round arbor holes are made on saw blades. You will probably find the arbor securing nut has a shape that fits into the flat gaps between the saw blade and the arbor when fixed. So grab a 5/8" round arbor saw blade and give it a go. It should work fine.
It is the arbor nut that secures the blade onto the arbor via friction which holds it on.
Please rate this solution on FixYa!
Posted on May 29, 2009
My Ryobi 10" mitre saw stops cutting when there is approximately 1/16" inch left of board to cut. What should I do to try and fix it? This is first season I have used it.
Sometimes there are stops to be adjusted and sometimes things need to be eased with a file.
One of my mitre saws had the same problem which I cured by fitting a different blade that was just a couple of mm bigger diameter - possibly the difference between a metric blade and an imperial...
Sep 06, 2017 | Ryobi Saws
How to lower toptable of a ryobi table mitre saw tms-305
http://ryobi.co.za/product/table-and-mitre-saw-combination-1800w-tms-305/
this saw has a 2 inch capacity. if you have say a 3 inch piece you use 2 passes of 1-1/2 each
regards
sir dana
Apr 25, 2017 | Ryobi Saws
I have a new 7/1-4 ryobi battery operated mitre saw all my batteries are new and run all my tools perfect, but on the mitre saw has only slight power but cant cut anything
make sure you are getting good connection to the battery for that tool. Is the blade reasonably sharp? YOu don't say what voltage but those saws aren't that torquey anyway. Sounds like a problem with that particular tool.
Jan 08, 2015 | Ryobi Saws
I need a replacement fence for a Ryobi CSS1000 compound mitre saw.
Have you checked on Ryobi? You might want to check Kreg fence. What type of blade are you using right now? I have a saw and I got online supplier for blades , I purchase on sawblade.com , happy with them. Good luck.
Jan 08, 2014 | Saws
Jcb mitre saw
try ringing jcb on 01889590312 and they will put you in touch with a distributor that has the part.
Jul 28, 2013 | Ryobi Saws
I have a ryobi 10" mitre saw and i took the guard
I don't know but if you have figured it out let me know. I have same prroblem.
Apr 19, 2011 | Ryobi 10 In Miter Saw With Laser
How to change blades on an old Ryobi 380mm cut off mitre saw?
most of these saws have a push/lock tab on back side of motor housing that pins the shaft for blade change. if you cant find, use a 4/4 wood block to wedge old blade so you can loosen bolt.. hope this helps....chris
Jun 18, 2009 | Saws
Ryobi ZRTS1342L Factory-Reconditioned 14 Amp, 10" Compound Miter Saw with L Logo
827 people viewed this question
Top Ryobi Saws Experts
enb54
Level 1 Expert
Jim Thurston
Are you a Ryobi Saw Expert? Answer questions, earn points and help others
