Question about Dryers
No power after the start button is pressed
I have a Kenmore 90 Plus Series Electric Dryer. When we set the timer, close the door, and press the start button, there is no power. What could be the problem?
    President:
  • 1,136 Answers
Hi, Try this first. Normal 0 UNPLUG the dryer! Remove the rear panel of the dryer and locate the fuse. It is white and ¼” wide and 3” long. It is located on the blower housing. Remove the wires and check to see if it has continuity. If it does not, you need to replace it.
If it is not your model, please get me model# so I can assist you further.
Vic
Posted on May 29, 2009
Kenmore series 90 dryer(5 years old). Power ok
have you checked the start button?
Jan 30, 2010 | Dryers
Dryer won't start when start button is pressed and held
check door "close"contact button/switch usually the culprit..
Aug 02, 2009 | Whirlpool Duet 7.0 Cu. Ft. Capacity Plus...
Dryer Won't Start
Make sure it has power. Then:Check the door switch. A little lever sticking down through top right of door opening. If it is not there you will need new door switch(sometimes the little lever breaks off). If it is there and does not click when you press it in you need a new door switch. if it clicks when you close the door then you have a bad thermal fuse.The thermal fuse is found by taking the back of the dryer off. The fuse is an oblong white plastic piece with 2 wires attached.
Door switch part number 3406109
Thermal fuse part number 3392519
May 27, 2009 | Kenmore 73952 Gas Dryer
When the start button is pressed and held down the dryer will run but when the button is not being held dowm the dryer cuts off. What could that be? It is a Kenmore 90 Plus Series Even Heat Dryer
i would say that it is in the "lockup" circuit in your motor. there is a centifugal switch which moves when it senses RPM of the motor which then in turn closes a set of contacts within the motor housing, thus locking the run contacts to keep your motor running. odds are that the switch, (which moves along the motor shaft) is dry or blocked by debris (lint) that gets caught in the motor housing.
a good cleaning and then a shot of lube on the shaft usuallly solves this problem....
good luck; jay
Mar 21, 2009 | Kenmore 62622 Electric Dryer
Kenmore 90 Series Model 11060912990 Dryer won't start
check motor (you have 2.4 Kohm ) very high read
for motor must be lower.Check capacitor if hawe.
Feb 15, 2009 | Kenmore 62602 Electric Dryer
Kenmore 90 series won't start timer ticks
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Dec 03, 2008 | Kenmore Elite HE4 Electric Dryer
Dryers Logo
113 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
