Question about Samsung Cell Phones
Connections between phone and bluetooth will not connect
I had to replace my old phone with a new one (same model) and I can not get it to read my Samsung bluetooth. I think the earpiece is not set correctly. Any suggestions?
  • 225 Answers
Try resyncing the bluetooth with your phone in the phone settings if it worked for the other phone that you replaced and its the same model it should work for the new one
Posted on May 29, 2009
How do i connet my lg hbs700 from my old fone to a new fone?
Turn the bluetooth radio off on your old phone. Turn on the hbs700. Your earpiece should automatically go into pairing mode when it does not detect your old phone. Turn on the bluetooth radio on your new phone and search for your hbs700. Connect to and you're done.
Feb 25, 2015 | LG HBS-700 Bluetooth Headset
Is it possible to install a new bluetooth connection thing from a donor cell phone?
Not understanding your meaning.
Do you want to connect a bluetooth speaker in some way other than bluetooth?
Do you have a phone with bluetooth that doesn't work and you want to rip the bluetooth circuits out of another phone and transplant them into another phone?
Do you just have a really old cell phone that doesn't have bluetooth capability and want to do the same transplant thing?
Or do you have a phone that has bluetooth that probably works fine but you don't know how to use it so you're thinking you might be able to do all the connecting through another phone that has bluetooth up and running?
Dec 02, 2014 | TekNmotion Air Capsule Portable Speaker...
My new phone a Samsung Gusto is not pairing to my Plantronics 233 bluetooth? Is it compatible?
Hi, to be sure if the blue tooth wll be compactible with Samsung Gusto, you will need to use the below instructions first after trying out the instruction and still does not work,that means it's not compactible with it.
instruction:
Read the owners manual for your bluetooth device. You will need to find the code to pair your headset to your phone. This code is usually 0000 (those are zeroes) but verify before you proceed.
Enter your bluetooth option on your cell phone. These can be found in your menu under "bluetooth," "connections," "settings," or something similar.
Turn on your bluetooth headset and put it in pairing mode. Pairing mode means the bluetooth is ready to be found by your cell phone. To pair your headset, follow the owners manual for your specific bluetooth model.
Select "add device" or "search for new device" from your cell phone. Your cell phone will then search for your bluetooth. Once it is found, or discovered, you will need to enter the pairing code (most likely 0000, check your manual to verify).
Select "connect" to finalize the connection if the bluetooth headset didn't connect automatically after the pairing code was entered. Make a test call with your bluetooth in your ear to ensure it is connected properly.
Good luck..
Feb 23, 2011 | Plantronics Explorer 230 Bluetooth Headset
I am trying to disconnect my bluetooth from my old cell phone and reconnect it to my new cellphone
Unable to connect my new iphone to the bluetooth in my car.
I've turned off the blue tooth in my old phone but it only turns off the bluetooth in the car. I have tried to then reconnect my new iphone, which is searching and showing that it has located the bluetooth (blue tooth flashing in car, shows on the sceen for a second and then turns off with message 'no service' phone off. If I turn on the old phone, everything comes back on.
Any ideas?
Jan 23, 2011 | Motorola Mobility Bluetooth Hands Free...
My sony bluetooth is paired with an old phone and i want to unpair it and use it with my new phone
Just turn off the bluetooth connectivity of your old device and for your new device just turn it on and look for new paired device, make it sure that both bluetooth connectivity are activated
Oct 31, 2009 | Nokia N76 Cellular Phone
SAMSUNG BLUETOOTH PAIRING
1.Press and hold the Multifunction button in the middle of a boom headset while the headset is closed. The light will glow blue.
2.Open the boom microphone and the blue light should remain on. If not, repeat step 1.
3.On the cell phone, press Menu > Settings > Connection > Bluetooth > Handsfree > New Device
4.Select (Serched bluetooth device) once a connection is detected.
5.The passkey "0000" is now entered to confirm the connection has been made.
6.The cell phone screen will now read "Bluetooth Connection".
Tips:
1.Provided you set the Bluetooth power to "On" after the initial connection has been made, the phone will automatically re-connect to the headset.
2.To set the Bluetooth power on - Press Menu, Select Settings, then Connections, then Bluetooth link, scroll to Setup and select that. Scroll to Power and chose Change. Scroll to On and press Select. The screen should now read "Changed: Power On".
3.Test Your Connection: Close the headset and watch for cell phone to say "Disconnected". Re-open the headset and the phone should be connected automatically and will now display "Bluetooth Connected".
please give good rating if the solution works.
Thanks for using FixYa.
Dec 04, 2008 | Motorola Mobility Bluetooth Hands Free...
Getting my head set to pair
1.Press and hold the Multifunction button in the middle of a boom headset while the headset is closed. The light will glow blue.2.Open the boom microphone and the blue light should remain on. If not, repeat step 1.
4.Select your bluetooth (i dont know your bluetooth model no.) once a connection is detected.
Tips:
Nov 09, 2008 | Motorola Mobility Bluetooth Hands Free...
Bluetooth
1.Press and hold the Multifunction button in the middle of a boom headset while the headset is closed. The light will glow blue.2.Open the boom microphone and the blue light should remain on. If not, repeat step 1.3.On the cell phone, press Menu > Settings > Connection > Bluetooth > Handsfree > New Device
4.Select SCH-a930 once a connection is detected.
Tips:
Jul 31, 2008 | Samsung SCH-a930 Cellular Phone
Bluetooth problem
4.Select (serched bluetooth serched device) once a connection is detected.
Tips:
Jul 28, 2008 | Motorola Mobility Bluetooth Hands Free...
Bluetooth
4.Select HS850 once a connection is detected.
Tips:
Feb 26, 2008 | Motorola Mobility Universal Wireless...
Cell Phones Logo
35 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
