Question about Pioneer Car Audio & Video
Display reads No Disc despite all the discs checking out.
When I turn on the power, and then insert the CD cartridge, the display shows the unit checking each disc. It goes all the way through disc 11, but doesn't show disc 12, and then reads No Disc. Once the cartridge is in, and the power is turned on, all the read out shows is No Disc. Any ideas?
  • 6,784 Answers
Hi, the optical lens assembly has failed. this is triggering the (no disc) error code. you will need to replace this failed optical assembly.
Posted on May 29, 2009
Why does my CD player display "no disc"?
I had a similar problem with my DVD player. Cleaning the laser eye helped fix my problem. You can clean it manually if you are not afraid to remove the cover of the unit or you can try a cleaning disc. The eye can collect dust and prevent it from reading the ID sector of the music CD.
Jul 07, 2014 | Audio Players & Recorders
After reading toc of my Marant zcd5003 the display is "error" seeking help to find out the cause
  1. No disc. - Load a disc into the tray.
  2. Disc has been loaded upside down. Place the disc with the label side up.
  3. Disc region code does not match region code of the player.
  4. Disc type is not the correct type to play.
  5. Disc is damaged or dirty. Clean the disc or try another.
  6. Moisture may be condensed inside the unit. Remove the disc and the leave the power on for one or two hours.
follow the steps and fix it.
God bless you
May 27, 2013 | Marantz CD5003 CD Player
The display says, "insert disc",
Thank you for posting to Fixya.com and it is my pleasure to guide you.
1. The disc may be turned over. Insert the disc with the playback side facing down.
2. The disc may be dirty. Wipe it with the correct type rag.
Since you stated the display is showing then I take it the player is on and the chord is plugged in.
3. Is the disc completely centered in the tray? I have done that before.
4. Have you run the self-diagnosis function? If the Error code 'AACS ERR' shows then it is an "AACS read failure". Remove the protected disc. Then turn the unit off and wait a minute or two and back on.
Good luck and please post back that you are successful and give thumbs up if my solution has worked for you. If I can be more helpful just reply.
Jun 18, 2011 | Sony BDP-S300 Blu-Ray Disc Player
I have an acer t135 desktop and when using the recovery discs i had make it stopped on the last disc and is now not working at all and just shows the power light and a red light help neone pls
Can you put the last disc into some other CD/DVD reader, to confirm that it is readible?
Can you totally restart the recovery, to see if it stops at the same point?
Oct 10, 2009 | Acer Aspire T135 PC Desktop
Cd recorder stuck in Dealer Mode
With the unit in Standby mode (off), press and hold the Display button. The trays will then unlock.
Feb 13, 2009 | Philips CDR795 2-Disc CD Recorder
Alpine CDE-9841
Have one solution which might work.
Remove head display unit and press reset dutton usins a pin.
now connect head display unit. now insert CD. make sure the CD is in good shape.
Cheers
Alex Victor
Jul 26, 2008 | Alpine CDE-9841 CD Player
My disc is not changing and is stuck ( CHM - S620 by Alpine )
hi make sure that you cart is inserted all the way in, push the eject button why hitting the mag with the handle of ascrew driver. this may dislodge the jammed arm/lever. otherwise its down to your repair agent.
regards
Mark
www.carradiospares.co.uk
Feb 16, 2008 | Alpine CHM-S620 6-Disc CD Changer
Alpine CD Changer - won't read CD
regards
Mark
Jul 30, 2007 | Alpine CHM-S620 6-Disc CD Changer
Car Audio & Video Logo
297 people viewed this question
Top Pioneer Car Audio & Video Experts
Michael Kovalik III
Michael Kovalik III
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
