My Simpson Espirit 750 washer works intermittently. It fills up OK and stops if you turn the water level switch to reset and back it sometimes starts agitatating. It may start after 2 resets, sometimes 5 or more. You may have to pump out some of the water and refill and then reset. It is very unpredictable If you rotate the switch while pulled up it sometimes starts agitating. Any clues??
  • tmitchell293 May 29, 2009
    Hi, Thanks for the response. I have already checked over the wiring etc. It all looks in V good condition and solid. I have an electronics background but not in washers! I agree that intermittents are usually associated with loose contacts but this is strange. Any other thoughts??
    President:
  • Washing Mach... Master
  • 2,923 Answers
It has something to do with the electrical wiring or the relay inside your washing machine. You have to take off the plastic panel where the switches are located and check if there's any loose wire that is about to detach. Check also the relay that is connected to the wires.
You may need to contact a repair tech to assist you.
Have a great day!
Posted on May 29, 2009
  • Melvin Ramos
    Melvin Ramos May 29, 2009
    The only thing that I could think of is the washer's control board. It has NOTHING to do with the motor or agitator since it works (but intermittently.) Meaning, the one who's controlling the motor (control board) could be the one that has a problem.
    You may need to consult the manufacturer for the second opinion to see if you need to replace the control board. Or maybe by simply drying up or cleaning the board might help.
Washing machine, Simpson Espirit 500, won't start at all. Power is on and water, cold turned on as well.
Possibly the door switch isn't working or is maladjusted so the machine's brain thinks the door is still open.
Feb 18, 2017 | Simpson Washing Machines
My Simpson eziload 750 will not shut off the water during cycles when supposed to
Start machine as normal. After a few seconds of filling, press the pause button. Water coming in should stop immediately. If it hesitates then stops or does not stop at all you have a faulty inlet valve. Change it.
Apr 22, 2016 | Simpson Washing Machines
How do I replace the fill level controll valve in a espitit 750
Did you check the tube that comes up from the tub to the pressure switch for the fill level? A lot of the time, the tube is either clogged or has a hole in it
Oct 13, 2014 | Simpson Washing Machines
Water level
Probable causes:
Faulty water inlet valve - unplug washer, if water continues to fill
replace the valve.
Water level switch, hose or dome faulty - service the assembly.
Timer faulty - unplug washer, if water stops filling test timer.
Regards,
Dennis
Aug 22, 2014 | Simpson Esprit 750 Top Load 7.5kg
Simpson espirit 750 won't turn on
Hi, This may sound obvious, but have you checked the fuse? if the machine is completly dead this may be the problem or the ON/OFF switch is faulty. If there is life in the machine the problem could be the door switch. If the fuse has blown then there could be a fault such as heater element blown, is the most common to blow a fuse.
May 04, 2012 | Simpson Esprit 750 Top Load 7.5kg
Simpson espirit 750 manual required can't change water level
Hello
Try these links to download the manual to your machine.
laundry.manualsonline.com/ex/product/.../m/simpson/d/.../22S750M
http://www.dataentryjobs.us/67948.html
trd-techconnect.net/User's%20guide,%20Instructions%20book
www.search-document.com/pdf/.../simpson-esprit-washingmachine
www.sign.ac.uk/pdf/sign97.pdf
Feb 09, 2012 | Simpson Esprit 750 Top Load 7.5kg
Hi i have a simpson esprit and I can't stop the
If the water continuously keeps filling the tub of the washer this would be due to either you have a bad pressure switch or the hose that is connected to the pressure switch that goes down the side of the unit and connects to the tub has either comes off its connection point or has sediment or debris inside the hose itself which would cause the same issue here is also a basic video of how the pressure switch test is done click this link http://www.youtube.com/watch?v=HZZ2bDMspj8 if you have any further questions message me back and please remember to rank this opinion when our chat has fully concluded it allows me to continue helping others in similar situations in the future. Thanks again for using Fixya
Rick
Jun 12, 2011 | Washing Machines
Simpson Espirit water not Filling
try removing your cold water hose and check to see if the screen filter has a calcium buildup or some other obstruction.  if not that then possible bas inlet valve on washer.
Aug 03, 2010 | Washing Machines
Water sometimes does not shut off. flooded twice. happens intermittently.
If when the machine is flooding if you turn off power to the machine and it continues to fill: replace water inlet valve. If flooding water stops filling when power is interupted: clean out the end of the water level switch tube where it connects to the outer wash tub.
Sep 17, 2008 | GE WHRE5260E Top Load Washer
Washing Machines Logo
41 people viewed this question
Top Washing Machines Experts
