Question about Toshiba Satellite A105-S4004 Notebook
Satellite A105 LCD does not work have to use with desktop monitor
I have had a video problem with my Toshiba A105 for about a year now. The first time it happened my laptop slid off the couch and landed on the ground on its side. After this incident the LCD would not work even though it would power on. I took it for repairs and they said a wire came loose. So after that it was fine. But one day I was working on it and the screen flickered. I then adjusted the angle of the screen back and forth and it stopped flickering. But soon after it went out completely. Now the funny thing is i can connect my laptop to a desktop monitor and it will work fine. So I Im sure its a connectivity problem. This has led me to believe the same thing happened as before. A loose wire. Ive been looking for a way to solve the problem without having to replace the LCD...and thats what Im trying to avoid. I already open the case of LCD, and I try to unplug all socket and clean it up then plug it again, it's work, but the colour is becomes flikcer
  • Toshiba Master
  • 32,281 Answers
You most likely have a defective screen - a defective inverter or a CCFL lamp or simply the video cable needs reseating. After reseating the video cable and the problem is still there then :-
To determine if you have a LCD screen or video card problem, read this and follow the instructions.
Defective CCFL backlight, it may have the following symptom:
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display or appear black.
  • Picture flickering on and off.
All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
Posted on May 29, 2009
How do i repair toshiba satellite a105 ribbon cable repair
Have you tried hooking up an external monitor to it and seeing if it works? I would try that first to rule out a video card issue. If the external monitor works fine, here is a website with pictures on how to disassemble the laptop to replace the screen:
Toshiba Satellite A105 Laptop Disassembly Guide Cooling Fan Heatsink...
Jul 23, 2014 | Toshiba Computers & Internet
Display divided into 3 parts
LCD screen cracked, and Three even strips going across? Doubtful. Haven't seen it but I always have my mind open.
Three strips that are irregularly shaped? Look like glass that has cracked?
'Jagged edges'?
LCD screen is broken.
Three even strips indicates to me, that there may be a problem with the Video Cable. Then the screen Inverter is next in the diagnoses.
My money is on the Video Cable.
ALL power removed, Anti-Static Precautions FOLLOWED, I would check out the graphics chipset first.
1) Laptop OFF, monitor OFF, connect a VGA monitor to the VGA port on the laptop.
Left rear side. This is an example of a VGA Cable, and VGA connector. (VGA port on a laptop ),
http://en.wikipedia.org/wiki/VGA_connector
(Color of connector does Not matter. It is generally Blue, though)
You can use a CRT type of monitor, (Looks like a small TV), or a flat LCD screen monitor if it has a VGA cable.
2) Turn the monitor on. If a CRT type allow it to warm up.
Turn the laptop on.
There are at least 3 display options available;
1) Laptop internal monitor ONLY
2) Laptop internal monitor AND external VGA monitor
3) External VGA monitor ONLY
Press, and hold down on the Fn key, and at the same time tap once on the F5 key. (The F5 key is the Display Toggle-Over key)
No display on external VGA monitor?
Hold the Fn key down again, and tap once more on the F5 key.
Is the display on the external VGA monitor, the same as the internal monitor of the laptop?
Problem is the graphics chipset.
Display is fine on the external VGA monitor?
Problem is the Video Cable, screen Inverter, or LCD screen.
Video Cable:
A) http://www.irisvista.com/tech/laptops/Toshiba-Satellite-A105/big/Toshiba-Satellite-A105-14.jpg
Switch Cover removed, Keyboard removed. Shows you where the Video Cable plugs into the motherboard.
B) http://www.irisvista.com/tech/laptops/Toshiba-Satellite-A105/big/Toshiba-Satellite-A105-21.jpg
Palm Rest Cover you can see the white rectangular connector, for the motherboard side of the Video Cable, at the top left.
It's above the black cable, and near the screw hole.
The Video Cable leads from the motherboard, up through the left Hinge, and into the Display Assembly.
From there it connects to the screen Inverter, and back of the LCD screen.
http://www.ebay.com/itm/Toshiba-Satellite-A105-6017B0050801-LCD-Video-Cable-Genuine-OEM-Laptop-TESTED-/290754851160?forcev4exp=true&forceRpt=true
In the photo, (You can hover your mouse cursor on it to enlarge), the right side connector plugs into the back of the LCD screen.
The black connector to the far left connects to the motherboard.
The small white connector at the top with the Red, Green, Black, etc wires, connects to the screen Inverter.
(The small Black cable, that comes out from the black motherboard connector, is a Ground wire )
Due to the close proximity of the Video Cable to the left Hinge, it can be pulled on from just normal opening, and closing of the laptop over time.
This means the Video Cable connection on the motherboard side could be loose, or the LCD screen side, or both.
The diagnoses is to PHYSICALLY check BOTH connections. A loose connection at the motherboard, or at the back of the LCD screen could be so small in distance, that you will not see it with the human eye.
Could also result in damage to the Video Cable.
View the Video Cable with the Switch Cover removed, and see if there are any obvious signs of damage to the sheath of the cable.
If there is there could be damage to the tiny wires inside the Video Cable. (Stretched/Broken)
Use a multimeter set to OHMs, to check all wires inside the Video Cable for continuity, or have a 'Mom and Pop' computer store check it for a few bucks, or replace the Video Cable.
Video cable connections are tight? Video cable continuity check checks out OK?
Screen Inverter.
The test for a screen Inverter is to use a sensitive multimeter.
Read fairly expensive.
http://www.fonerbooks.com/test.htm
Not having access to a sensitive multimeter that you can use, means just replacing the screen Inverter. Seems like 'part changing', and it is, but you have to work with what you've got.
http://www.sparepartswarehouse.com/Toshiba,Satellite,A105,Laptop,Inverters.aspx
Find THE model number for your laptop, and the correct screen Inverter. A screen Inverter, and an LCD screen are a MATCHED unit.
Screen Inverter is checked out to be OK, or replaced, and symptoms are still the same, the problem is the LCD screen.
Remember, the first part of the diagnoses was to see if the divided parts were EVEN going across, or jagged and irregularly shaped.
Jagged in shape, and not even strips going across, means cracks in the LCD screen.
Replace.
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-A105/remove-replace-LCD-screen-1.htm
[ Main article for A and B links above;
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-A105/remove-motherboard-1.htm ]
For additional questions please post in a Comment
Regards,
joecoolvette
Oct 22, 2012 | Toshiba Sattelite A105-S2051 Notebook
Toshiba Satellite Laptop refuses to allow Dual Monitors
I have an A105 set up on dual screens, and it works great. As I recall, you have to do the dual screen setup in the control panel, display, settings.
Mar 17, 2009 | Toshiba Satellite A105-S4074 Notebook
LCD dark with white vertical line down it
It is the C-Board Panel Attached to the Display Panel And Is Integrated into the Screen .. You will need a screen replacement..
Your part is.... Toshiba Satellite A105 15.4" LCD Screen LTN154X3-L06
Feb 13, 2009 | Toshiba Satellite A105 Notebook
Given the fact that you are able to get a picture on another monitor obviously means there is not a driver problem. Rather it is without doubt a hardware problem inside of your LCD. Inside the LCD there are two "inverters" that supply power. If one of them went out then you would not get any picture. This is not something you are able to repair yourself because of electrical danger. I do not believe you will have to replace the LCD but I would recommend taking it in to be repaired. If they recommend it be replaced then ask them to show you "exactly" what the is the problem. Inverters can be replaced so no need to replace the monitor.
Dec 28, 2008 | Toshiba Satellite A105-S4004 Notebook
Toshiba satellite a105 screen problem
You need a new lcd, The connectors are bad...
Dec 13, 2008 | Toshiba Satellite A105 Notebook
No video
Well done, it's a great feeling when things work out
Aug 30, 2008 | Toshiba Satellite A105-S2716 Notebook
Toshiba a105 screen goes blank
Sounds like GPU failure. unfortunately its nigh on impossible to replace without replacing the whole board which can be expensive. I saw a few on ebay for around £120.
Aug 14, 2007 | Toshiba Satellite A105-S4004 Notebook
Open Questions:
See all Toshiba Satellite A105-S4004 Notebook Questions
Toshiba Satellite A105-S4004 Notebook Logo
164 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
