Agitator isnt working properly
My washing machine isn't agitating properly..the bottom of the agitater is fine but the center cylinder hardly moves...when I push down on the cylinder it works fine
    President:
  • 1,136 Answers
Hi, You will need to replace the agitator dog kit inside the agitator.
Remove the cap of the agitator and then remove the inside cap. You will need a 7/16" socket with a long extension to reach the bolt that holds the agitator in place.
Pull the agitator out and seperate the top half from the bottom half. The dog kit # is 285770.
I hope this helps you. If I can assist you further, please let me know.
Vic
Posted on May 29, 2009
Only the bottom agitator works, not the top
replace the dog ears in the upper part of the agitator not expensive and not hard to do ,,,, pop the cap off the upper agitator remove the 7/16 bolt and lift off the upper part and replace the plastic dog ears and reinstall!
Mar 08, 2010 | Kenmore 12502 Top Load Washer
The top half of the agitater does not work it just
There are small plastic parts called "dogs" that wear out. The agitator needs pulled apart and those dogs replaced. It is fairly simple to do.
Jan 09, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Agitater spinns freely
The following advice is for replacing the "Agitator Dogs" on Kenmore and Whirlpool TOP LOADER style washing machines. This simple repair can save you a fortune in repair costs as the replacement parts are very inexpensive at a cost of less than $10. The replacement kit part number is 80040. You can order on line at various appliance parts websites, or use this part number and go to your nearest appliance parts retailer.
What are "Agitator Dogs"? These are small plastic pieces (usually 4) that are located under the agitator center cap that grip the agitator and turn it during the wash cycle. They can (and do) wear out dependent upon the use of the washer. If you are in the habit of doing large load sizes frequently, or wash large items such blankets or afghans, this can wear the teeth off and reduce the life of the agitator dogs.
SYMPTOMS REQURING REPLACEMENT: The agitator fails to turn during the wash cycle, or will not turn with a heavy load. The timer will run normally through all cycles, and you will be able to hear the gearcase (transmission) engage and run. The washer will also drain normally. The only indication that something is wrong will be the agitator slipping or not turning at all. The result will be clothes that do not wash properly and will sit on the bottom of the wash tub.
To replace the Agitator Dogs, follow these steps:
1.Remove the agitator center cap by either pulling straight up or gently placing a flat blade screwdriver into a slot located in the cap.
2.If the agitator is equipped with an inner cap with a handle, remove this as well by pulling straight up.
3.Remove the center bolt of the agitator. You will have either a 7/16" hex bolt or a recessed square plastic nut. If you have the square recessed type, use a 3/8" to ½" ratchet adapter to remove.
4.Remove the agitator by grasping the bottom flange and carefully pulling straight up. Try to keep all the parts assembled while doing this, so do not pull too hard. This will make this repair much easier.
5.Place your hand over the top of the agitator and separate the upper portion of the agitator from the lower portion and turn the top half over in your hand. The agitator dog assembly will come out in your hand.
6.With the agitator dog assembly in your hand, lay the rest of the agitator aside. Pay careful attention to how the dogs are installed. Remove the worn dogs and reinstall new ones. It's that simple.
7.With all the dogs replaced and the assembly still in your hand, place the upper part of the agitator over the top of it, upside down, ensuring the inner assembly tabs align correctly.
8.Now keep your hand over the agitator top to hold all the pieces together and turn the entire assembly over (upright position).
9.Carefully align and reinsert the upper portion of the agitator to the lower portion. Again, making sure the two pieces align correctly.
10.Place the entire agitator assembly back on the gearcase shaft and reinstall center nut. NOTE: DO NOT over tighten the nut, or the agitator will not spin correctly. Just make the nut snug. Reinstall center cap and inner cap (if equipped).
These instructions should give you the basics on how to perform this repair. Since there are various agitator types in use by Whirlpool and Kenmore, assembly can vary.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Oct 11, 2009 | Washing Machines
Top of agitator does not agitate with lower agitator.(dual agitation) whirlpool model LA3860XW00
You will need to replace the Dogs. Take cap off of the center of the agitater, take bolt out of center and pull agitater up and off. Pull two pieces apart. There are four dogs that catch on gear teeth inside your agitater. The four dogs come in a hit, sometimes with a couple other pieces. Has to do with which model you have) replace these four and any other pieces that come in the kit you order. This will fix your problem.
Please rate solution
Aug 31, 2009 | Whirlpool Washing Machines
Single agitater but top part don't work
Hi, You need to change the dog kit inside the agitator. Remove the 7/16" bolt holding the agitator in and lift it off the shaft. The agitator will pull apart and then you can see the dog kit.
Please let me know if this helps you at all or if I can assist you further,
Thanks
Vic
Jul 23, 2009 | Washing Machines
Wont agitate unless you move the agitator
defective motor,,,start whindin gone ,,,replace motor
Jan 17, 2009 | Maytag PAV2300 Top Load Washer
Washing machine noise
check the dogs in the agitater
Mar 25, 2008 | Whirlpool GSC9455 Top Load Washer
Grandma's nylons wrapped around the bottom of the agitater
now you need to pull upward firmly but hard.  there are small splines holding the agitator in position. carefull if the agitator has two parts to it as there are usually plastic (dogs)inside which could spring loose if you are not careful.
Oct 24, 2007 | Washing Machines
Washer make a clicking noise
Zoobs, you could have something stuck under the agitator. The agitator will pull straight off. Grip it on each side and pull up hard, but don't hit yourself in the face. If that don't work, try slipping a belt under it and pull. Check for something caught under it. Another possibility could be the nylon suspension rod socket supports in the back. They will make a noise during agitation if they are dry. Put a little 3 in 1 oil to quite them down. Take the front panel off and check the pulley and belt, see if anything is out of whack. I also often find the motor support hitting the bottom panel during agitation making noise. Take the front panel off and observe during agitation. See if the support is striking the bottom. If so, just bend the bottom panel down. Catriver..post back.
Nov 30, 2006 | GE WHSE5240D ENERGY STAR Super Plus 3.2...
Washing Machines Logo
105 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
