Question about NEC Z1 (845625) PC Desktop
When I plug in the power and turn it on it will ask for current code don't know what the code is nothing else comes up on the screen
The problem is when I plug it in and turn it on it asks for a current code don't know what the code is
  • shia-oasis May 11, 2010
    the code it asking for, are there boxes seperated by dashes?...shia
  • 1,623 Answers
If Microsoft is asking for a code when you boot up then thats the Product Key or Activation Code for your operating system, It will be a 25 digit number located on your Intstall disc or computer tower.
Good luck i hope this helps.
Posted on May 29, 2009
Power button not working!!! This is different though....
This is a common problem that I run into. The battery will show charged when it really isn't. Take out the battery, plug the charger into the computer and try turning it on. If this works, you have a bad battery and it will need to be conditioned or replaced. If this doesn't work it could be a serious hardware issue.
Jun 25, 2013 | Dell Studio 1558 Notebook
On my 97 grand prix3.8 I have used a jumper wire in place of the fuel pump relay and the fuel pump comes on . But when I plug the relay back in and turn the igntion on the fuel pump does nothing the relay...
There is a break in the wire that supplies power to the fuse box.
You need to trace this power wire from the fuse box to find the break in this wire and fix this wire,.
Ii would help you is you have a wiring diagram of your vehicle as the wires are color coded.
Mar 31, 2013 | Cars & Trucks
I have a 40" screen colby flat screen, I'm having problems with my monitor coming back on???? I've tried leaving it unplugged for two days but when I plug the monitor up, don't nothing com
if the power indicator goes light green then turn to red, you must check the power supply board. look for a bulging capacitors.http://en.wikipedia.org/wiki/Capacitor_plague.a panasonic brand capacitors with low esr is a good replacement just look for the ratings and value must be the same when replacing. then make it sure check the polarity the positive and the negative. just let me know if you need further assistance good luck
Nov 01, 2012 | Computers & Internet
How do I reset displaylanguage to english HP C6180
You can do a reset on your printer.Unplug the power cord of the printer.Press and hold the # and 6 buttons together and then plug the power cord back into the outlet.Keep holding the 2 buttons until the display goes blank or RESET is displayed.If the printer automatically turns off, turn on the printer.The printer should start up and you will be able to select language code.
Oct 26, 2011 | HP Photosmart C6180 All-In-One InkJet...
I just bought this TV - LG -32LD350, and I plugged it in, and no lights came on, no screen, no sounds, nothing. I don't know what is wrong with it, I tried unplugging it then plugging it back in after...
Plug it then use tester to check the wire that connects from the transformer to the panel, if there is no current then The power transformer is bad, replace it and every thing will work fine.
Aug 09, 2011 | Televison & Video
Hi. Have just turned on my HP Pavillion m8000 and the screen and it does nothing. The screen is getting no signal and even though the computer is on, it isn't starting up as usual. Help!!! I've checked all...
hi
it could be that your power supply (from tower) is not working -- does the fan blow out air ?
if not replace the power supply. If the power supply is on but no video on screen showing , it could be your mainboard inside the tower, thats if no noise is coming from the tower.
what were the circumstances when you worked on he computer ? was it plugged in overnight while running or was the power cord attached to tower while plugged into wall ? if so, it mnay have experienced a power surge and blew the mainboard.. too much current going to tower could blow the power supply, causing the mainboard to have received excess current
go to this link and rewview some infromation about your PC issue(s)
http://h20000.www2.hp.com/bizsupport/TechSupport/SupportTaskIndex.jsp?lang=en&cc=us&prodTypeId=12454&prodSeriesId=3328509&taskId=110
let me know what lse i can do -- i await your reply to some of the questions above
regards.
Dec 16, 2010 | HP Computers & Internet
When I plug in my Singer Curvy 8770 and turn on the power switch, it beeps and nothing comes up on the screen.
No offense, but have you read your manual? IIt does not sound like it. If, you don't have it go to www.singerco.com and download it for free.
Aug 22, 2010 | Singer Curvy 8770 Electronic Sewing...
Nothing comes up on the screen when i turn the computer on, the power light is on but nothing shows up on the screen
Try pressing Fn + F2 key after turning the computer on. Try to perform power drain. Taka out the battery and unplug the adapter. Presss and hold the power button for 30secs. Put the battery back in and plug in your power adapter then turn on the computer.
Let me know if you will still be getting the same issue.
May 19, 2010 | Toshiba Qosmio G15-AV501/R Notebook
Korg Triton Le keyboard not working
Hello! My Triton LE did that yesterday at rehearsal room. It came on twice (by turning it off and on every time the error message appeared), I could play the auditions and demos but when i hit the keys i heard nothing.
Soon after I went home (still with sweat on my forehead and my heart pumping like a pneumatic drill) I connected it and everything was working like nothing ever happened!
So guys, everybody who has the same problem: Don´t panic! I think for me, the power plug at the rehearsal room had a problem. Who thinks of that? Nobody... So check your keyboard on another power plug...If you can, try it in a friends house. Or check your house plugs.
I assume if the Keyboard doesn´t get enough power, the error message appears. Hope that Helps!
Apr 23, 2009 | Korg TR76 76 Key Synthesizer Workstation
I hook everything up and turn it on but i get nothing
if you just built a new pc, and hooked up your power button and reset button and mixed up the possitive and negitive wires you may have fried your motherboard. If you hold the power button for five seconds and your pc does not power down, it's fried.
Apr 11, 2009 | ASUS P5WD2-E PREMIUM GREEN INTEL 975X...
NEC Z1 (845625) PC Desktop Logo
51 people viewed this question
Top NEC Computers & Internet Experts
parusdi rusdi
Level 1 Expert
Steven Wander
Steven Wander
Alun Cox
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
