Question about Philips FWC788 CD Shelf System
Tape-1 drive gets stuck when Tape-2 drive is operated
    Problem Solver:
  • 6 Answers
This is a sign of wear and the tape deck has the possiblity of going out.
Posted on Jun 22, 2009
DLT-S4 tape is stuck in Quantum drive all 3 LEDs flashing together. Eject tape button does not work, how to get the tape out?
Hello, on some of the older DLT drives, if you press the 'eject' button several times the drive firmware attempts an unload operation. I'm not sure of the number of times you have to press it though...try pressing it in and releasing it 3 times (in quick succession). If that doesn't do anything, try 7 times.
It's worth a try!
Regards
nicam49
Nov 01, 2010 | Quantum DLT-S4 DLT Tape Drive
LTO Ultrium 4 Drive/Lecteurs stuck in it
Check that 'Prevent Media Removal' is disabled
Check the Support Ticket Device Analysis for indications of a stuck tape
Run the L&TT*** "LTO Stuck Tape Test"
Try a normal eject operation--Make sure that you allow up to 10 minutes for completion
Perform an Emergency Unload
Reset the drive to reset the drive firmware
Use Library and Tape Tools (L&TT) to Upgrade your Firmware
***Download LTT from www.hp.com/support/tapetools
Jul 29, 2010 | HP StorageWorks Ultrium 960 Ultrium Tape...
Hi I need to manually remove a tape from a quantum 3 superloader. The tape appears to be stuck in the drive
Hi Adrian
I would suggest sending it to www.tape-drive-repair.com for them to fix as once the tape has been removed you will still probably have the original fault that caused the tape to get stuck.
If you do try and remove the tape yourself be extremely careful as those drives are very easy to break the load mech and tape leader assy if you dont know exactly how to remove them.
Bear in mind the tape may not actually be stuck though!
Try powering off and on the loader with it disconnected from the server just in case it is your backup software not letting the drive eject the media as this is a common issue (where the software tells the drive it is using the tape (or hasnt finished with it) and stops the eject button from accidental operation)
Aug 17, 2009 | Quantum LTO-3 (BHWCXEY) LTO-3 Tape Drive
Stuck tape
The tape won't come out when resetting the drive. Error 6 is serious.
To get out the tape you must open the drive. But IBM has a discription online (and in the user manual) how you can do this.
Jan 06, 2009 | IBM TotalStorage 3580 L33 (3580L33)...
There is a tape stuck in the LTO 3582-L23, how to takeout manually?
Its not easy to remove the stuck tape as it require you to
1. Remove the sled from the library
2. Remove the drive from the Sled.
3. The Drive Part would be more complicated.
I sugguest you send it to a tape drive repair centre and let them service it for you.
You can try sanwork.com
Dec 02, 2008 | IBM TotalStorage 3582L23 (18P9522) Ultrium...
USE OF DELL PV124T LTO3 TAPE DRIVE USING AND LTO2 TAPE USING WINDOWS BACKUP FEATURE IFY usua_ie@yahoo.com
I have DEll PVT110t LTO2 backup drive & my backup tape got stuck into it.please help me for the successful ejection of tape.
Aug 27, 2008 | Dell PV124T LTO3 16 SLOT COMES WITH 1 MAG...
Stuck Tape Removal
usually a reboot gets it out...hit eject button BEFORE windows starts up...I've seen some get stuck forever... Good luck.
Aug 22, 2007 | Quantum ValueLoader SDLT 320 Super DLT...
Philips FWC788 CD Shelf System Logo
43 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
