Question about Canon I960 InkJet Photo Printer
Canon i960 light flashing orange 5 times. Won't print.
SOURCE: Canon i9950
Five flashes: Print head not installed / Print head not installed correctly / Defective print head
Install the print head. If the print head is already installed, remove the print head and check the electrical contacts for foreign matter, then reinstall.
For the i9950 ONLY: When the CD-R tray is set in the printer, remove the CD-R tray and set the paper output tray to the paper print position, then install the print head.
After reinstalling the print head, you may need to realign it.
If this error still remains, the print head may be damaged
Posted on Jun 23, 2008
  • 14 Answers
SOURCE: canon ip4300 service error b200 green and
Try this:
Pull the power cord out of the back of the printer.
Then move the printhead to the center and pull out the ink and the printhead. Clean the printhead and examine the bottom for burned areas.
With the printhead still out, close the cover and plug the power in and turn the power on. If your printer isn't damaged, it should go through all diagnostics and give you a solic green light. This means you probably need a new printhead.
Posted on Apr 17, 2009
devdeep545
  • 137 Answers
SOURCE: why flash by 5 times the orange led?
Probably your waste ink counter should be cleaned or replaced before resetting but usually you can get away with resetting once.
1. Start with printer OFF
2. Hold down RESUME and then hold down POWER
3. Release RESUME
4. press RESUME twice, then release POWER
5. let green light blink until printhead has finished moving.
6. Select functions below with RESUME, execute with POWER
0 presses - green light - Test Print (exit service for i960)
1 press - orange light - EEPROM info print
2 presses - green light - EEPROM initialise
3 presses - orange light - reset waste ink counter.
This also applies to the i550, i560, i950, i960
Good Luck, I hope this helps?!
Posted on Aug 12, 2009
cene765
  • 787 Answers
SOURCE: My canon ip1880 printer orange light flashing 7 times.
1. Press power button while plug in the power cord – green lamp.
2. While hold the power button press resume button twice – orange blink and return to green.
3. Release the power button, Then the PC will recognize new printer install.
4. You need the software for permanent reset.
5. Run the software and select printer port.
6. Then select Set Destination
7. Click MAIN and PLATEN button to reset waste ink counter to zero.
8. Finally test print by click TEST PATTERN button.
Posted on Oct 19, 2009
cene765
  • 787 Answers
SOURCE: Canon 1560 error - orange light blinking 5 times
It's mean "Print head not installed/Defective print head".First open cover and remove the ink cartridges.Then open holder and remove the print head.Clean the contacts on printer and print head using piece of cotton and some alcohol.Then put back all again.If the problem persist you need to replace the print head.It's part number now is QY6-0064, because the old QY6-0042 is discontinued.
Posted on Oct 30, 2009
Light flashing green and yellow will not print
Hi this is only a try it may work
Start with the printer OFF
1. Hold down RESUME and then hold down POWER
2. Release RESUME
3. Press RESUME twice, then release POWER
4. Let green light blink until printer is done futzing
Select function with RESUME press POWER to execute:
presses - light color - function
Number of presses - light color - function
0 presses - green - Test print (or exit service mode on i960)
1 press - orange - EEPROM info print (plus grid nozzle diagnostic on i960)
2 presses - green - EEPROM initialize
3 presses - orange - Reset waste ink counter
Jan 14, 2010 | Canon i850 InkJet Photo Printer
Orange light is flashing 7 times, but printer ,is locked. Ink tanks do not centre when lid is opened.
Probably your waste ink counter. Should be cleaned or replaced before resetting but usually you can get away with resetting once.
3. Release RESUME
hope this helps
Sep 08, 2009 | Canon PIXMA iP4200 InkJet Photo Printer
The printer flashes orange light five times, and green once
3. Release RESUME
Sep 07, 2009 | Canon BubbleJet i560 InkJet Printer
Why flash by 5 times the orange led?
3. Release RESUME
Aug 12, 2009 | Canon PIXMA iP5300 InkJet Photo Printer
I was printing the other day and each page got lighter and lighter and now it doesn't print anything in black. There's ink in it and I turned off the printer. What else do I need to do to get it to print...
How long has it been since you printer prior to the other day ? If you do not use your printer for some time, the ink will dry out even if it's a new cartridge.
May 01, 2009 | Canon I960 InkJet Photo Printer
My canon i950 waste ink absorber is almost full
1. Start with the printer OFF
3. release RESUME
5. Let green light blink until printer is done moving print head.
6. Select functions below with RESUME press POWER to execute:
Mar 17, 2009 | Canon i950 InkJet Photo Printer
Canon i950 will not reset counter for waste tank full.....
For Canon i850, i950, S600
2. release RESUME
3. press RESUME twice, then release POWER
Jun 04, 2008 | Canon I990 InkJet Photo Printer
Canon i550 cannot print
Try the below procedures maybe the error of your printer is the waste ink counter.
Canon i550, i560, i850, i950, i960 (May work with i860, i865)
3. release RESUME
Apr 10, 2008 | Canon BubbleJet i550 InkJet Printer
Cannon copier pc940 paper jam
canon i960 -three flashing orange lights (paper jam error) but no paper is jammed. The print cartridge1.gif will not slide to center either-- I have tried to get the printer into service mode, but cannot get there because the orange lights never stop flashing.
Dec 06, 2007 | Cannon Canon i960 Photo Printer
I560
If you are lucky clean the contacts on print head or change the waste ink absorber may solve the problem , if not you need to change the print head , part code:QY6-0064 or QY6-0042, about 38 $ on Ebay.
Here is also the manual reset procedure for I560 (and other Canon printers ):
3. release RESUME
Number of presses - light color - function :
Nov 15, 2007 | Canon BubbleJet i560 InkJet Printer
Canon I960 InkJet Photo Printer Logo
2,147 people viewed this question
old marine
old marine
