Question about Zodiac BARRACUDA G3 IN-GRND CLEANER
Barracuda not bouncing or moving to clean pool
My barricuda is not moving i have ahad it checked it works in another test pool what could the problem be?
  • 106 Answers
Check suction at cleaner. Could be broken hose, bad or dirty impeller, incorrectly set valves, dirty filter, clogged line and probably a bunch more things.
Posted on Jan 14, 2010
Need to switch weed eater barricuda from blower to Vacuum but no manual
http://lawnandgarden.manualsonline.com/manuals/mfg/weed_eater/2500_series.html?idRes=15826113
Here is where you can find the manual to download for the 2500 series Weed Eaater blower/vac
Aug 29, 2011 | RTO Weed Eater Electric Barracuda 2595...
Barracuda has plenty of suction but hardly moves around the pool, goes very slowly
You likely just need a new pad on the head. When they ware down they allow the head to get closer to the surface that it's cleaning, but the additional suction makes it difficult for the head to move.
I hope this helps you!
Jan 29, 2011 | Zodiac Baracuda Zippy Pool Cleaner
Barracuda not moving
You could have too much suction, something stuck in the diaprahm, a torn diaprahm could do this or if it is sticking to the drain you will have to shut the drain down.
Jan 10, 2010 | Zodiac BARRACUDA G3 IN-GRND CLEANER
My Barracuda was working the other day before the
If your moving water it sounds like you have a suction valve that needs to be reset to the cleaner. If your main drain is plugged off as it should be with a suction cleaner, the pump will strain. Or it may be a plugged line. Check this by putting a small kitchen sponge it the skimmer and see if it gets pulled through to the pump basket. If it does not get there you have a plug.
Oct 04, 2009 | Zodiac Pacer Pool Cleaner
My boyfriend purchased a barracuda G3 2 days ago. After installing it worked really well for approx. 2hrs then the pressure increased to 20 eventhoug he had backwashed the pool and it was very clean. What...
Try backwashing again, this cleaner will pick up enough dirt in a couple of hours to clog the filter. Untill the pool is clean you need to backwash and check the baskets, (skimmer and pump pot) Probally two to three times in the first day, then once after a couple of days. After that you can get back to a regular routine.
Sep 29, 2009 | Zodiac BARRACUDA G3 IN-GRND CLEANER
Barracuda don't move
what do you hook your vacuum to in the pool? does it have suction? it may be clogged. if so you can blow it out if you have the equipment. it may be you don't have enough suction and all you need to do is adjust one of your suction side valves to fix this problem. if you don't have dedicated valves you can plug one of you other suction lines to give your vacuum more suction.
Jul 24, 2009 | Zodiac BARRACUDA G3 IN-GRND CLEANER
My Barracuda inground cleaner keeps the same cleaning path.
mine does this too. I was told that the cleaner learns a path and sticks to it. You have to switch the sections of the hose around or just twist them to a different position so it will take another path. Unfortunately, you have to do this quite often to avoid it sticking to the same path around the pool.
Mar 22, 2009 | Zodiac BARRACUDA G3 IN-GRND CLEANER
G3 is not moving, but has suction? Please advise.
I had the same problem. come to find out there was somehting stuck in the diaphram. (a piece of mulch). Once I removed it, everything worked fine. Take your Barracuda apart and check the diaphram for blockage.
Mar 21, 2009 | Zodiac BARRACUDA G3 IN-GRND CLEANER
SEAGATE IDE 80 GIG BARRICUDA DONT HAVE CYLINDERHEADS SECTOR INFO
I use gparted tool to find it. Once you boot from the CD (with the .iso of gparted on it), you can access the tool to find the cylinder by right-clicking on the desk and select ???? sorry, I'm not sure about the name of the tool. So go to gparted.com and download the program. If you need more help, let me know.
Nov 30, 2008 | Seagate Barracuda 7200.7 ST380011A 80 GB...
Zodiac BARRACUDA G3 IN-GRND CLEANER Logo
1,273 people viewed this question
Top Zodiac Pool & Spa Experts
Colin Stickland
Colin Stickland
john h
Jay Finke
Jay Finke
Are you a Zodiac Pool and Spa Expert? Answer questions, earn points and help others
