Question about Asrock 775Dual-880 Pro Motherboard
OSX86 install on a PC: Power Management issues- kernel panic
No matter what options I pick on any OSX86 distro (Kalyway, iATKOS, etc.), once the OS is successfully installed I get kernel panic during verbose boot always having something to do with the Power Management kernel extension.
I am running an Intel Pentium D Core 2 Duo 3.2 GHz on an Asrock 775Dual-880Pro motherboard.
Anyone else have success with this particular setup?
  • 1 more comment
  • SimpleText
    SimpleText Jul 12, 2009
    win xp pro 64bit with Mac OS X 10.5.2 dual boot
  • SimpleText
    SimpleText Aug 20, 2009
    currently Win XP x64 edition, but I don't see how that pertains to the question of installing a totally separate OS
  • Rommel Cana
    Rommel Cana May 11, 2010
    what operating system are you using?
I having the same problems as others with this panic situation, but when i start up my (acer_aspire 5236 series laptop), the acer logo displays and go selections of programs n when i choose ubuntu its...
One simple suggestion to disregard hardware problems, use a live CD/DVD (ubuntu or any linux distro). if everything ok then the present installation is corrupted. did you have a chance to boot into safemode (usually second option)
Nov 09, 2014 | Computers & Internet
How can we have a free OS for my laptop.
There are a large number of OSes which are available for free on the internet . Most of them are linux based , with each having a slightly different interface and a different method to install programs (also referred to as package management) . They are popularly referred to as linux distros. Depending on how old your laptop is, and you requirements, you can choose an appropriate distro . For laptops which have been bought within 3-4 years , UBUNTU (http://www.ubuntu.com/) is a good choice . For new linux users LinuxMint (http://www.linuxmint.com/) is a good option with lots of settings and applications preconfigured . In case it is a old machine and will be mainly used for internet surfing and web based applications then a netbook OS like Joli OS http://www.jolicloud.com/download is a good option. These OS offer fast boot times and good web compatibility .
To install any these , you can go to the website and download the OS and burn it to a CD/DVD . Some of these OS can be directly installed without the need to burn a CD . You can also try out these OS without installing . This is called Live-Boot .
I hope this answers your question .
May 24, 2011 | Computers & Internet
Dear Experts, I have problem in Install MAC OSX iAtkos V-7 on my PC HP DC5850 MT i have install the system and after installation it says installation successful please restart your PC or press the power...
I know that there are issues with OSX on AMD systems. Have you looked over at the OSx86 project page? I would start there if you have not.
http://wiki.osx86project.org/wiki/index.php/Main_Page
Apr 27, 2011 | HP Configurable- Compaq dc5850 Microtower ...
Mac laptop screen froze with message stating must turn off laptop
font.f1 { font: 12px Helvetica; } Thanks for asking your question with Fixya Support. I will be glad to assist you.
What you are experiencing is what is called a Kernel Panic.
A Kernel Panic, is a internal fatal error, detected by your system from which it
cannot recover from safely. Such an error can be the result of a software
function or operation failing to execute as it normally does, or halting without
warning, or even a hardware component, suddenly ceasing to operating
or simply shutting down. In either scenario, the system will display the frozen
black and white screen with the languages text listed.
Normally a simple reboot of your Macbook Pro will resolve the issue, but in some cases it can take a specific procedure to correct and prevent a kernel panic from occurring again.
So here are a few procedures you can use to resolve and prevent further kernel panics:
• First, hold in your power button for approximately 10 seconds to do a hard shutdown, if your Macbook Pro is still turned on.
• Once your Mac is shutdown, you will need to perform what is called a PRAM reset (Parameter RAM)
• Locate the following keys on the keyboard: Command, Option, P, and R. You will need to hold these keys down simultaneously .
• Turn on the Macbook Pro.
• Press and hold the Command-Option-P-R keys. You must press this key combination before the gray screen appears.
• Now, hold the keys down until the computer restarts and you hear the start up sound for the third time.
• Release the keys and allow the Macbook Pro to start up.
If your Macbook Pro starts up normally and does not go into another kernel panic, then you should be able to resume normal session activity on your Macbook Pro.
However, should the kernel panic return, then you can use an SMC Reset to correct the kernel panic:
-SMC RESET-
The System Management Controller is an integrated circuit (computer chip) that is usually on the logic board of your Mac portable.
It is responsible for power management of the computer. It controls back-lighting, hard disk spin down, sleep and wake, some charging aspects, trackpad control, and some input/output as it relates to the computer sleeping.
Shut down the computer.
• Disconnect the MagSafe power adapter from the computer, if it's connected.
• Remove the battery.
• Press and hold the power button for 5 seconds.
• Release the power button.
• Reconnect the battery and MagSafe power adapter.
• Press the power button to turn on the computer.
Once again, when you are back up to your main desktop, resume your normal session activity.
At this point there should be no further issue a the kernel panic rearing its ugly head once again.
If it does, then you will need to take more intensive steps such as inserting your Mac OS X installation disc and booting up to that disc and running Mac OS X's Disk Utility, to repair the hard drive and permissions of the Mac OS X system you are using.
I will leave you with that procedure, in the event you need to run Disk Utility:
Insert your Mac OS X Startup disk
•Reboot your Mac
•At the Apple Chime, press the C key and hold it until you see a White screen, gray Apple and eventually a Spinning gear.
• Release the C key only after you see the Spinning gear.
•Mac will boot from the start up disk to the Installer environment
• From the Installer Menu bar, click Utilities > Disk Utility and open up Disk Utility application.
• Click on on the hard drive at the top of the window in the left sidebar and
• Select "Repair Disk"
**Let Disk Utilities run this repair the disk until completion
• At the end of this process, reboot your Macbook Pro
Return back to you main desktop and again, resume your normal session activities.
Any more kernel panics after this, you may want to consider taking your Macbook Pro in for service at your local Apple retail store Genius Bar or local Apple authorized service provide in your area.
I hope this information proves helpful for you.
Regards,
-Mactechtrainer
Mar 30, 2011 | Apple Mac Book Pro 15.4" 2.53 Core2Duo 4GB...
Kernal panic
To reset nvram,
Press "cmd alt O F" at startup
Then enter:
reset_nvram (press enter)
reset_all (press enter)
A kernel panic can come from a lot of things (peripherals, corrupted file, or damaged hard drive or memory). The best is to check in the log file what caused the kernel panic, or to proceed step by step, checking one thing after the other, until the problem is resolved.
May 30, 2009 | Quicksilver Computers & Internet
MacBook Kernel Panic
To fix this problem, download and install Mac OS X 10.4.8 from - www.apple.com/support/downloads.
This should solve your problem.
Let me know how it went.
Aug 14, 2008 | Apple MacBook Mac Notebook
Delta1010 on Hacintosh
WORKING DRIVER HERE FOR M-audio PCI:
 M-Audio Delta 44 (verified)
 M-Audio Delta 66 (verified)
 M-Audio Delta 410 (verified)
 M-Audio Delta 2496 (verified)
 M-Audio Delta 1010 (works for some)
 M-Audio Delta 1010LT (verified)
 Terratec Phase 88 / EWS88MT / TS88PCI (tested only on EWS88MT)
 Terratec EWX2496
I tested on my M-audio Delta 1010 with box today and everything incl. SPDIF is working great on my osx86 v_7 10.5.8 system! The only thing not working is midi as told on website. Im submitting file for the above sound cards! Dont Forget to donate some money to this guy!!!
http://www.audio-evolution.com/drivers/
http://www.insanelymac.com/forum/lofiversi...t25145-150.html
Mar 22, 2008 | M-Audio Delta 1010 Sound Card
Kernel panic
upgrade the os
Oct 04, 2007 | Computers & Internet
Asrock 775Dual-880 Pro Motherboard Logo
5,986 people viewed this question
Top Asrock Computers & Internet Experts
David
David
Matthew Spark
Matthew Spark
Computer Links
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
