Question about Kenmore Dehumidifiers
Need a maual for my kenmore humidifier model # 25506 LO
I have lost the manual for my humidifier. I have never used it, we moved after I bought it and can not find the manual anywhere. This humidifier is a Kenmore, Model # is 25506 L0.
4 Suggested Answers
  • 184 Answers
SOURCE: kenmore dehumidifier 33 model c675-25133
that might be the wrong model #
the first 3 digits should be 580._ _ _ _ _ _ _ _
Posted on Mar 28, 2008
jyackle5
  • 8197 Answers
SOURCE: Sears Kenmore Dehumidifer Model # 580.54501700 and
You can get the manual on the link below.
http://www.managemylife.com/mmh/owner_manuals/7614/KENMORE-Dehumidifier-L0709045?brand_name_search=580.54501700+
Good Luck and please rate 4 thumbs up for your free answer.
Posted on Jun 23, 2010
  • 4736 Answers
SOURCE: Kenmore # 58052650100 this is my humidifiers model
Christian, simply put ... the lower the percentage the more moisture it will extract. The higher the percentage the less it will extract and just maintain that level.
The lowest level is what you want to use in a wet basement. If the ambient air temperature at floor level is between 40 & 60 degrees F, you want to get the dehumidifier up off the floor on to something sturdy, that can handle the weight and the vibration. The reason for this, is that most dehumidifiers will not work well at or between those temperatures. Once the water collection bucket is FULL, the Bucket Full light will come on the the dehumidifier will shut OFF. The bucket most be emptied and properly reinstalled, before the unit will turn ON again. Also, rather than run it in continual mode, run it in a timed mode. Usually either 2 hours of 4 hours.
It seems you don't have the Owner's Manual for this unit. It would be wise to get one. Since it's a Sears Kenmore, you can get it online from Sears Parts Direct. This will help you in the future in performing routine maintenance on the unit.
In the meantime, I hope I helped you understand some of the basic operation of your dehumidifier. Please let me know. Thanks.
Posted on Jun 01, 2011
I just bought a new dehumidifier. 30 pint. put it in cellar and it's not drawing any water out. why?
You probably have it on the fan setting and not the humidifier setting, which uses a refrigeration system to condense the water onto a chilled element.
May 08, 2018 | Dehumidifiers
I need an owner's maunal for a Sunbeam SWM5251 humidifier
Hi, you can purchase a PDF copy of the Sunbeam manual from TradeBit.com here for $9.99:
http://www.tradebit.com/filedetail.php/58045622-sunbeam-swm5251-um-owners-manual
Unfortunately, Sunbeam doesn't offer free downloads of their manuals online.
Dec 27, 2010 | Sunbeam Warm Mist Humidifier Dehumidifier
How much water to put in the water entering tray
dehumidifier's remove moisture from the air,so you really don't want water anywhere close, the tray in a dehumidifier is to collect water removed from the air. a humidifier is easy, you put a pan of water close to a heat source or moving air
Jan 31, 2010 | Dehumidifiers
I just bought this and it keeps leaking, why?
If the room tempature is close to 60, the coils may be frozen (completely encased in ice). If this is the case, move it where the water can drain off - about 1 gallon which may NOT run into the drain bucket.
I out mine over the floor drain.
Turn off and it will defost over night.
Only specially made dehumidifers work below a room temo of 60 degrees (the temp of a basement in winter).
Does it need to be running? A digital humidity sensot from Radio Shack is cheap and may tell you the humidity is OK - only 50% or less.
Jan 01, 2010 | Sunbeam Warm Mist Humidifier Dehumidifier
My dehumidifier is making a power surge every few minutes. why?
A dehumidifier is functionally the same as an air conditioner. It has a compressor motor, which is a fairly high current draw item.
First of all, unless you are well versed in electrical repairs, you should unplug this unit and do not use it. This is a dangerous condition and a fire or electrocution could result.
One of four things is happening:
1) You have a wiring fault in the circuit your humidifier is plugged into. There is a loose connection in the circuit, causing a voltage drop, and the humidifier therefore has to pull much more current to start it's compressor. This is a very dangerous condition, as an electrical fire could result. Try plugging the unit into another circuit and see if it does the same thing.
2) the compressor of the humidifier is going bad and is shorting out internally. Time for a new unit.
3) Many compressor motors use a 'start capacitor' to help the motor get going. If this part has failed, the motor will try to start, but it will not be able to.
4) There is a fault in the power cord or controls of the humidifier. Just like #1 above, a loose connection could cause a voltage drop, making the unit draw high current.
most of these units are standard 110V units. If yours uses 220V (like an electric dryer), then it could have 'lost a phase' which is also a similar electrical issue.
Oct 16, 2009 | Dehumidifiers
Bucket fills, doesn't stop
make sure unit is level , the cut off switch will not work if not level
Jun 07, 2009 | LG LD65EL Dehumidifier
How to clean it
check the manual, it will be described there. if you don´t have one, ask here: http://manualfox.com/link/sunbeam.htm
May 19, 2009 | Sunbeam Warm Mist Humidifier Dehumidifier
Haier HDN305 humidifier
It's on the right side under blue plastic cover.
Jun 13, 2008 | Haier HDN655E Dehumidifier
Fan
Depending on the ambient temp/humidity and how its set it could definitely run continually. If you don't hear it it's possible the blade is broken or just stuck.
Call 800-243-0000 or go to www.aic.lgservice.com
Dec 25, 2007 | LG LD40E Dehumidifier
Dehumidifiers Logo
321 people viewed this question
Top Kenmore Dehumidifiers Experts
Bill Long
Mike Squire
Are you a Kenmore Dehumidifier Expert? Answer questions, earn points and help others
