Question about Samsung Audio Players & Recorders
Dvd turns off after displaying ''protection''
In aux mode the dvd displays the word ''protection'' then truns the unit off. When we turn it back on it stays on for about 5-15 minutes then repeats.
Can you advise a solution or how we can obtain a manual for a Samsung DVD Home theater system HT-X20
  • 56 Answers
Protection error message means that your unit's fan is not working
it is a feature to keep your unit from overheating
check if there is anything blocking the fan of your unit from rotation or replace the fan
Posted on Jul 02, 2009
  • cont_fiscal Aug 04, 2011
    I have the same problem, but only wait a few seconds after On for apears PROT and OFF...
  • Michael
    Michael Sep 07, 2014
    I have the same problem and this is a new unit. there is nothing obstructing the fan
    Problem Solver:
  • 5 Answers
This may be a case of shorted speaker or speaker wires shorting check all speakers and cables with multimeter.
Posted on Jan 21, 2015
PANASONIC SA- HT340 CONTINUESLY SWITCHES ON AND OFF WHEN ON DVD/CD MODE BUT WORKS FINE WHEN ON FM/AUX. THE RED LIGHT STAYS RED AND DOES NOT GO GREEN. ANY IDEAS PLEASE
If all else fails try resetting the unit to the initial factory settings.
While stopped and "DVD/CD" is the source, press and hold [Tune=mode/FM-mode Button] on the main unit and [>=10 Button] on the remote control until "Initialized" disappears from the television. Turn the unit off and on again. All settings will return to the default values.
Nov 24, 2015 | Panasonic Audio Players & Recorders
"PROTECT" message in display.
two cables of a speaker were touching each other.
this may be the problem
Dec 29, 2007 | JVC HX-D7 DVD Compact Stereo Audio / Video...
Screen goes blank in aux mode
Check parking brake connection. Not connected properly.
Apr 22, 2014 | Pyle PLD40MU 4.3 LCD Touch Screen Car...
I have a samsung ht -tx 22 dvd home cinema system and for sometime now, the screen shows PROTECTION and it reverts to standby mode by itself.. Need help badly as sometimes it plays for 1 to 5 minutes and...
Check all your cables, connections and speakers. If they are all good, then either there is a fault on the protection circuit or the power amp has a fault on it. If the unit has a fan built into it check that is working. Sometimes the fan can get blocked up.
Sep 24, 2017 | Audio Players & Recorders
LG LHT754 is frozen in aux mode. I tried holding down buttons and unplugging and nothing.
Unplug the unit for 60 minutes, when you plug it in hold the power button for 5-10 sec which will do a hard reset. This will reset the processor and hopefully the unit will operate normally.
Mar 01, 2011 | LG LH-T754 Theater System
My stereo says" protect" everytime i turn it on. can't get anything else.
Hello grammagrisbo, hi your Kenwood head units will show "protect" when there's a problem with the speaker outputs so check to see if the impedance load meets your radio, 8ohms or 4 ohms?. having parallel two speakers on a single channel may cause this dilemma. This might also mean a shorted speaker wire, a blown speaker, or an internal defect in the head unit. Once the condition that's causing the "protect" mode is fixed, the CD player should be back to normal, the next time you turn it on.
If it's staying in "protect", then you'll definitely have to remove the stereo and do something to fix it. Many car audio stores will do system troubleshooting, for a fee. If you want to do it yourself, here's what you need to do:
Pull the Kenwood unit from the dash and disconnect all the speaker wires. power it on and see if the "protect" message displays. If it does, the stereo has an internal defect and will need to be serviced. If it doesn't, then turn it off, and re-connect one speaker only. Turn it on again and see if it will displays "protect" message.
If the radio works with one speaker connected, connect the other speaker to the second channel, you may have now the idea where the problem begun, you will identify the speaker that's causing the problem. There may be a wiring problem or defective speaker in that channel.
If it displays "protect" with a single speaker connected, then disconnect that one and try the other one. If all the speakers cause a "protect" mode, then you're probably back to a defective head unit.
Aug 31, 2010 | Kenwood Car Audio & Video
My HT-X50 front display screen has all of the LEDs lit up like they do when it is first powered up (self check). They all stay on regardless of the mode the unit is in - DVD, Aux, etc. The room the unit is...
The display is damaged. This is how this series dies. In some cases the receiver still works except you can't see the display. Samsung service center can repair it, nobody else.
Apr 01, 2010 | Samsung HT-X50 System
Once watching a dvd it wont let me change the surround that i want. How do i fix it?
Apparently, the use of the built-in DVD player doesn't allow sound field manipulation; but external sources can be modified. This subject is only discussed in this section of the manual...
"Enjoying audio form an external
source
You can enjoy audio form an external source through
your unit.
Press INPUT repeatedly to select the desired input
source. - AUX, AUX OPT, AUDIO IN
Setting the surround mode
You can select the Dolby Pro Logic II. Press
SURROUND to change surround mode repeatly...."
Mar 15, 2010 | JVC TH-G30 Theater System
When ever i turn on my engine which means my kenwood kdc237 shud come on its just flashing protect protect protect no matter wot i press nothig happens need help cant do without music.
If protect is coming up on the display, it means the system is detecting a short somewhere on one of the speakers and so is turning the amp off to avoid damage.
Check all the connections at the back of the amp to ensure they are not shorting, and at the back of each speaker, if nothing is found there, check each wire for damage, or a bare wire touching the body of the car
Jan 20, 2010 | Kenwood KDC237SA CD Player
After 20-30 minutes work in the USB or AUX mode, the unit turns off. At display panel says PROTECTION. After that this problem (when I turn on) repeats after 3-5 minutes.
  • make sure the speakers are plugged in correctly
  • if you tried that already check if your system gets hot when it turns off
  • maybe you need more ventalation on your system...
Jan 16, 2010 | Samsung HT-X20 Home Cinema 600W Theater...
1,725 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electro Med Services...
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
