Question about Samsung DLP HL-P5663W 56" TV
Replaced color wheel, now I have ghosting
I replaced the color wheel on my HLR5067 Samsung DLP. The wheel created a loud humming noise and TV would shut off.
With the new color wheel in place the TV works well except for the fact that my color keeps wshing from blue, to red to green.
I've replaced the second color wheel and same problem.
I've tried the Mute 1-8-2 power and chenged the lamp sync and the index delay no change. Please help!
Mark
    Brigadier General:
  • 3,917 Answers
Resolder the Thermal Deguassing Cube. It is usually Black, about 3/4 inch cube and will be located close to the deguassing coil plug coming from around the Picture Tube .
Also make sure there is not anything with a magnet around or on top of it .
Thank You
Posted on May 29, 2009
My Samsung DLP 5663W was making the loud humming noise. Picture was just fine, but the noise was loud. I checked both fans which seemed to be fine, so I ordered the replacement color wheel. When I replaced...
On the metal box where the two cables from the color wheel plugged look for a tiny rectangular opening in the metal shield---there is a tiny jumper plug there, remove it carefully with a tiny pair of needle nose pliers.
One of the things they do not tell you when you replace the color wheel, it is somewhat different than the original one.
SD TECH
May 06, 2011 | Samsung DLP HL-P5663W 56" TV
My first gen samsung dlp tv makes noise from back and will not turn.when it happened it was going in and out of color
Tv have a colors wheel.Colors fade in and out or flashes black and white within the picture.The tv making humming or loud motor noises the colors wheel is dying and not spinning correctly in it motor anymore.The tv must have it colors wheel replace,will solved this problems.
Jan 01, 2011 | Samsung DLP HL-P5663W 56" TV
We have 50" Samsung DLP
Yes,the tv have a colors wheel and it is the cause of these problems.Humming noises,motor noises,picture flashes black&white or colors pictures within the pictures.The colors wheel,is dying or already dead.Hire a tv tech. replaced the colors wheel,will solved ur tv problems.
Nov 06, 2010 | Samsung DLP HL-P5663W 56" TV
Hi I have a samsung hlr4667 and the set will not come on at all.. It makes a buzzing sound kinda like it makes when powering on..And the lamp light flashes but no picture just a loud humming sound...The...
This DLP tv have a colors wheel.The tv colors wheel,it dead.Have loud humming sound,motor noises and pictures flashes black&white within a picture.The colors wheel is dead and is spinning off of it axis and hitting of it sides motor walls.Tv must require a replacement of a colors wheel.Hire a tv tech. to do the job.The tv colors wheel is hard to replace.The tv colors wheel sit behind many manchanical parts,must take out even before u even can replacement the colors wheel itself.
Nov 05, 2010 | Samsung HL-R4667W Rear Projection...
Loud humming sound on with a purplish and pinkish screen on my 50 inch dlp samsung, 5 yrs old.
Hi,sounds like you might be experimenting a color wheel problem.The color wheel is a rotating disc that has a gamma of colors it spins at high rpms.The light of the lamp goes through it to create the colors on your tv.When it starts to go bad you will get color distortion ,black and white picture and sometimes you will hear humming noises.Your part # is BP96-00250A You can find it here http://www.discount-merchant.com/Samsung-BP96-00250A-ColorWheel-Assembly-p/bp96-00250a-color-wheel.htm?Click=48173 and here's the instructions to replace it : http://www.fixyourdlp.com/guides/samsung/bp96-01579a.php Have a bless one!
Apr 18, 2010 | Samsung HLN5065W 50" Rear Projection...
Tv is making a loud buzzing noise and the picture is all funny ie colurs are out and pixelated
Hi,If your tv is a dlp you might be experimenting a color wheel problem.The color wheel is a rotating disc that has a gamma of colors it spins at high rpms.The light of the lamp goes through it to create the colors on your tv.When it starts to go bad you will get color distortion ,black and white picture and sometimes you will hear humming noises.
Apr 05, 2010 | Samsung SP46L6HXX/XEU 46" HDTV-Ready DLP...
Loud humming and color is distorted
You most likely need to have the color wheel replaced,its a common problem with the samsung DLP sets.
Apr 29, 2009 | Samsung DLP HL-P5663W 56" TV
Samsung DLP color has gone Muted...Color Wheel or Bulb???
The color wheel or lamp ballast needs replaced...it would be hard to know which without being there to look at to fix the humming problem, neither part is that is that expensive if you price shop, you may want to try one at a time ot save money. Also to fix the picture you need to realigh the DMD board with the help of another person watching the picture.Hope this helps.
Dec 30, 2007 | Samsung HLN5065W 50" Rear Projection...
Tv has what sounds like a humming noise by where the bulb is
sounds like the color wheel problem.
http://www.jangro.com/a/2006/07/24/samsung-dlp-replace-color-wheel/
Dec 11, 2007 | Samsung HLN567W 56" Rear Projection HDTV
Samsung DLP R-4664_W
stll have picture?....is colors distored.. sound like a color wheel problem.. the colorwheel is a motor anything that moves eventally wears out.
Nov 17, 2007 | Samsung DLP HL-P4663W 46" Rear Projection...
Samsung DLP HL-P5663W 56" TV Logo
57 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
