Question about Baby Lock Sewing Machines
Bobbin not even
Every time I wind the bobbin on my Baby Lock Decorator's Choice Sewing Machine (model BLDC) the thread on the bobbin is not wound smoothly. I had it serviced and they said it was fine, no problems. I use the correct bobbins. What could I possibly be doing wrong? So far I haven't had any problems using the bobbins.
    Problem Solver:
  • 3 Answers
Buckmanfamil....I use my finger to keep tension on thread when i fill my bobbin.i also pusu thread slightly up & dwn to even it out on bobbin.works for mine ! I luv my Baby Lock !!
Posted on May 29, 2009
Bobbin is not feeding properly- didn't wind on evenly.
It is important that the bobbin be wound smoothly for the machine to operate properly. First, check that you are threading the machine correctly to wind the bobbin. There is a tensioner for the bobbin winder that helps wind the bobbin smoothly so incorrect threading will cause issues. Also, try to wind your bobbin slower. There is no advantage to winding the bobbin on high speed.
If you continue to have bobbin winding issues, there is a standalone bobbin winder (SideWinder) avlb at JoAnn's or even Amazon for ~$30,. They are electric or battery operated. Be sure to verify your machine bobbins will work on the SideWinder before purchasing as some bobbins are not compatible. The bobbin winder is a handy gadget since multiple bobbins can be wound quickly, plus bobbins can be wound without having to unthread the machine, not to mention reducing the wear and tear on your sewing machine.
Nov 10, 2017 | Sewing Machines
How do I wind sharing thread onto a bobbin on a LX-5500 brother sewing machine?
Generally, elastic thread should be hand-wound onto a bobbin. Hand winding allows the elastic thread to be wound onto the bobbin without any stretch prior to sewing.
Feb 22, 2016 | Brother Sewing Machines
Bobbin not winding. The machine is threaded properly. The machine makes a whirling noise that is associated with the bobbin being wound, but the bobbin is not moving. I bought generic bobbins at a...
Is the metal spool just spinning in the middle of the bobbin because the hole is not a tight fit? I would check my manual for the correct bobbin & then purchase using the specific part number (e.g. SA156). I found this number in the list of "included accessories" for my machine. There will be a part number besides the name.
Oct 06, 2017 | Baby Lock Ellure
My machine will not thread my bobbin...And I'm scared that this might be the last time i use my sewing machine.....It's either that or that my thread will not grab the bobbin thread
I could not find any information on this model, but if it is a self-winding horizontal bobbin where the bobbin remains in the bobbin case as it is being wound - it could need repair.
Re-check your manual to make sure every step is working to set-up for winding.
If it still does not work, call a machine repair professional for an estimate. It could just be the timing needs adjusted.
Feb 23, 2010 | Kenmore Drop-In Bobbin 505S-21BH...
My white thread from bobbin shows thru embroidery
flip your bobbin
when I hold my bobbib in my right hand and pull the thread with my left hand the bobbin spins counter clockwise, this is how i put it in the machine
Do you wind your own bobbins if so make sure you wind evenly
I order a box of 100 pre wound bobbins from Brother
Sep 10, 2009 | Baby Lock Esante
I need to know how to thread a bobbin?
TRY THIS, itma not be your model, but should help Title:
ac093.jpg Pre-tension disk ac094.jpg Bobbin winder shaft ac095.jpg Bobbin
1. Pull up the spool pin as far as possible, and then put a spool of thread on this pin. windingbobbin_a0991.jpg
2. Pass the thread around the pre-tension disk. Make sure that the thread passes under the pre- tension disk.
windingbobbin_a0992.jpg ac098.jpg Pre-tension disk c_b4.jpg Pulling it in as far as possible
Caution If the spool of thread is not in the right place, the thread may tangle on the spool pin.
3. Pass the end of the thread through the hole on the bobbin from the inside of the bobbin. windingbobbin_a0993.jpg
4. Put the bobbin onto the bobbin winder shaft and slide the bobbin winder shaft to the right. windingbobbin_a0994.jpg
5. Turn the bobbin clockwise, by hand, until the spring on the shaft slides into the groove of the bobbin. windingbobbin_a0995.jpg ac099.jpg Spring on the shaft ac0991.jpg Groove of the bobbin
7. While holding the end of the thread, gently press the foot controller or press start/ stop button (for models equipped with the start/stop button) to wind the thread around the bobbin a few times. Then stop the machine. windingbobbin_a0997.jpg
Note
  • If the sewing machine is to be operated using the foot controller, connect the foot controller before turning on the machine.
  • When the foot controller is plugged in, the start/stop button cannot be used to start sewing (only for models equipped with the start/stop button).
Caution Make sure you follow the instructions carefully.
If you do not cut the thread completely, and the bobbin is wound, when the thread runs low it may tangle around the bobbin and cause the needle to break.
9. Slide the sewing speed controller to the right (to set the speed to fast).
(For models equipped with the sewing speed controller.) windingbobbin_a0999.jpg ac0992.jpg Sewing speed controller
10. Press the foot controller or press start/stop button (for models equipped with the start/stop button) to start. windingbobbin_a18.jpg
11. When the bobbin seems full and begins spinning slowly, take your foot off the foot controller or press start/stop button (for models equipped with the start/stop button). windingbobbin_a19.jpg
12. Cut the thread, slide the bobbin winder shaft to the left and remove the bobbin. windingbobbin_a191.jpg
13. Slide the sewing speed controller back to its original position (for models equipped with the sewing speed controller). windingbobbin_a192.jpg
Caution Not winding the bobbin properly may cause the thread tension to loosen, and may break the needle.
woundbobbin3.jpg ac0993.jpg Wound evenly ac0994.jpg Wound poorly
Note
  • When the sewing machine is started or the handwheel is turned after winding the thread around the bobbin, the machine will make a clicking sound; this is not a malfunction.
  • The needle bar does not move when you slide the bobbin winding shaft to the right.
Sep 02, 2009 | Brother LS-2125 Mechanical Sewing Machine
Brother CS 8060 bobbin wont wind...but motor runs
no idea... did you lock thread onto bobbin so it holds to wind?
Jul 17, 2009 | Brother CS-8060 Computerized Sewing...
I need an instruction manual for the Babylock Pro II Model B15
hi!there similar bobbins winder in any brand of sewing machine uses mostly in domestic particularly in industrial manufacturing in this fig.check it out if similar to your bobbins any how itmay be he86acf3a.jpglpfull onethe bobbins winder that was a thread and shoul be clockwise rotation when coming out to bobbins case,if you to wound the thread on your bobbins winder, pull threads on spool then wind this in several times 4 to 6 rotation clockwise loop thread on top machine there is bobbins winder disc for tension put winder bobbins on shaft winder near hand wheel push the latch against bobbins winder to fit thead run machine to wind the thread.After hread wound in bobbins winder cut thread and insert winder to bobbin case as shown.
insert bobbins to shuttle hook case under needle foot holder
lift the cover plate you can see under this is the shuttle hooke415486.jpgafter set up was made on bobbins thread,set also the upper loop thead beginning at top of machine start on spool, pull thread and loop to upper disc tension then to the slot portion as in figure
insert on lever dial goes to the needle adjust tension to #8 range to #12 for cotton fabrics two layer sewing.
Mar 17, 2009 | Baby Lock Sewing Machines
Sewing machine has bobbin thread would around winding shaft
If the bobbin is on correctly try crossing the thread before going through the tensioner which should solve this problem and also a more evenly wound bobbin.
Dec 17, 2008 | Brother LS-2125 Mechanical Sewing Machine
Can't get Bobbin to wind properly
Verify that your thread path is correct when winding the bobbin. It has a distinctive path including a tensioner that helps your thread wind smoothly. Do not use a bobbin that is not wound smoothly because (as you already know) it could possibly break needles and damage the machine.
Brother CS 80 Sewing Machine Bobbin Rewind
Nov 09, 2017 | Kenmore 15208 Mechanical Sewing Machine
Sewing Machines Logo
162 people viewed this question
Top Baby Lock Sewing Machines Experts
Tally Girl
Tally Girl
Jon Piercy
Jim Goldsmith
Jim Goldsmith
Are you a Baby Lock Sewing Machine Expert? Answer questions, earn points and help others
