Home | Samsung | HLN617W 61 in. Rear Projection HDTV Tel... | Noise
Samsung HLN617W 61 in. Rear Projection HDTV Television
Problem for Samsung HLN617W 61 in. Rear Projection HDTV Television
Noise
By daguilasdv on May 29, 2009
lauder noise
Comments:
Jun 23, 2009
- nothing with the fans.......
Solution #1
posted on Jun 23, 2009
Not Rated)
Axle80
Rank: Guru
Rating: 93%, 43 votes
What?
Louder noise? As in a fan or color wheel going out, please clarify.
Comments:
Jun 23, 2009
- This will be an odd question but can you describe the noise? Is it a whirring or whining sound or a click of some sort?
Jun 29, 2009
- a whirr or a whine or even a dull buzz would be from the color wheel motor. There are only two moving parts in this set and the noise likely would be generated from either the fans or the wheel. Take the back off the set and see if you can pinpoint where the sound is coming from. If its near a fan, use your finger to stop the fan and if it goes away, you've found your problem. If the noise seems to be comming from the black housing near the lamp then the color wheel motor is on its way to the grave. If you do indeed find that to be the problem post again and I'll walk you throught the dismantle. Good Luck.
Was this helpful?
Yes
No
Popular Solutions for Samsung HLN617W 61 in. Rear
Questions and Unsolved Problems for Samsung HLN617W 61 in. Rear
Do you recommend Samsung HLN617W 61 in. Rear Projection HDTV Television?
Answer
Answer
samsung flat screen keeps turning off...sound stays on...what is the problem
Answer
What's happening is power up chime, and faint volume. I can change channels. Meanwhile, no pic,... (More)
Answer
I have a Samsung HLN 617 W and I turned it on today and it worked fine then later this evening we... (More)
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Samsung HLN617W 61 in. Rear...:
Top Projection Television Experts
Rank: Guru Guru
Solutions: 1494
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Projection Television Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
