Question about Gateway M465-E Notebook
M465-E will not turn on
My M465-E was left in standby mode overnight (AC adaptor plugged in). When I attempted to restart in the morning nothing happened; it will not turn on. Battery shows fully charged and using AC adaptor does not make a difference. I have held the on/off button for extended periods of time with no change. Any suggestions? Thanks much.
    Novelist:
  • 166 Answers
Simply your RAM or mother board is faulty. Replacing RAM is cheap but repairing Mother board modules is an expensive affair.
Rate this solution if it was helpful to you.
With Regards,
Shyny
Posted on May 29, 2009
E500i-B1 won't come on.
Suspect a failing power supply
Jan 13, 2017 | Televison & Video
Monitor will not power on
The monitor has entered permanent sleep mode. After four years of service, it probably is not worth repairing
Oct 21, 2012 | HP W2408H 24-inch Widescreen LCD Monitor
MY HD4208TIII=PDP IS STUCK ON STANDBY MODE. hOW DO I GET IT TO TURN ON?
Hello
Plug it out from AC mains, and let it be in that state overnight, and then check. OK.
Nov 10, 2011 | SVA-USA HD4208TIII-PDP 42 in. EDTV-Ready...
Compaq armada 7400 does not turn on
Please turn off the Computer and disconnect the AC Adaptor then remove the Battery. Next, try cleaning the metal contacts on the Battery and reseating the RAM modules.Then, connect only AC Adaptor to the Computer and try to turn it ON without the Battery. If the Computer doesn't turn ON then disconnect the AC Adaptor and insert the Battery then try turning ON the Computer. If the issue persists even after performing all the above steps then service will be required.
Jun 23, 2009 | Compaq Armada 7400 Notebook
Acer Aspire 2920 won't turn on, although plugged in with battery
First of all, what I'm about to tell you are general troubleshooting techniques - I make no claim that they will fix what you describe, but they may help lead you to a solution.
  1. Unplug the AC adapter and remove the battery
  2. Plug in the AC adapter and attempt to power on the laptop
  3. If it doesn't power on, see #6 below. If it does power on, but doesn't boot the OS, restart - pressing [SPACE] as the first Windows splash screen appears. When prompted, choose to delete the hibernation file and start a system boot.
  4. Shut the system down, disconnect the AC adapter, reinsert the battery, and attempt to power the laptop. If it doesn't start we know, at the very least, there's a battery problem.
  5. Plug in the AC adapter. If it shuts down immediately, or won't power back on after a shutdown. . .
  6. . . .there's a problem with the system board, probably the ciruitry associated with charging the battery.
I hope you 'see the light'. Good Luck!
Jun 15, 2009 | Acer LXA3706003 Notebook
Gateway M-6750 wont turn on suddenly.
Sounds like the motherboard may have gone bad on you. If your ac adaptor has a light on it, make sure it still has the light still illuminates when you plug it into a wall outlet. If it doesn't light up then it could be the adaptor but since you tried both just the battery and just the ac adaptor that would tell me the motherboard is bad. The only other option would be to resolder the dc jack on the motherboard back in place. It could be that the solder joints underneath the dc jack have cracks in them.
Jun 09, 2009 | Gateway M-6750 Notebook
Lexicon RV-8 wakupe failure
Did you try this....
In the event of a power outage, the RV-8 will display a BROWN
OUT!! PRESS STANDBY message. To turn the unit on, use the
STANDBY button. For more information, see “POWER
MANAGEMENT” on page 3-3....
POWER MANAGEMENT ON, OFF
"Setup" >> "Power Management"
Opens the POWER MANAGEMENT menu, which is used to automatically
put the RV-8 into standby mode during brownouts.
When set to ON, the RV-8 detects low voltage levels or a momentary
loss of power and puts the device in standby mode. In the event of a
power brown out, the RV-8 will display a BROWN OUT!! PRESS
STANDBY message. To turn the unit back on, use the front panel
STANDYBY button.
When set to OFF, the RV-8 will attempt to function during a
momentary power loss, however software settings may become
corrupt and need to be reset.
When the RV-8 is in standby mode, pressing the button turns the
unit on and activates all zones that were active in the previous
operating session.
The RV-8 does not power on.
1. Make sure the rear-panel power switch is set to the | (“on”)
position.
2. Attempt to power on the RV-8 with the front-panel Standby
button and remote control On button.
3. Examine the power cord to ensure a good connection between
the rear-panel AC input connector and the wall outlet.
4. Check the electrical circuit and breaker.
Apr 05, 2009 | Lexicon RV-8 V2.0 Amplifier
Xbox 360 Wont Read Games or DVD's
take out your hard drive and then turn it on restore factory settings and plug it your hard drive back in
Feb 21, 2009 | Microsoft Xbox 360 Console
Computer won't start
Try this; Disconnect from the AC outlet rmove the dc plug from the jack. Remove the Battery and wait for 5 mins and plug in the AC-DC adaptor without the battery. If the Laptop runs, then wait for the Windows to totally boot up and while running try to put back the battery and observe if it still charges. If it still won't boot up repeat the procedure and before connecting the power remove the memory modules first and install 1 memory at a time. Also, if you can find your way to where the CMOS Battery is, I suggest disconnect it for about 10 to 15 mins. while Battery, memory, AC source are also disconnected.
Hope this helps.
May 07, 2008 | Computers & Internet
Toshiba Satellite A60 powers up then off after 2 seconds
Did u tried in external monitor??If not so do it?It seems that a problem is VGA!
Let me know if u got help!!!
Dec 07, 2007 | Toshiba Satellite A60 Notebook
Gateway M465-E Notebook Logo
247 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
