Question about Ryobi Garden
Ryobi 2 cycle gas trimmer 705r/725r
I have a ryobi 725r weed eater. I can get it to run, for about five sec. Run the throttle and gas just spits out the exhaust, It dies after the 5 sec run time, I tore apart the carburator and cleaned it up, still does the same thing. A little help please
  • Jim Parker
    Jim Parker May 11, 2010
    Did you recently replace the fuel lines?
    Jim
2 Suggested Answers
panilling9
  • 284 Answers
SOURCE: no power
check for restricted exhaust next
some manufactuers put screens in their exhausts and they tend to plug up sometimes remove clean and put back screen.
When you removed carb. and dimantled were the rubber pieces soft and pliable? if they were not then consider a carb. kit
Be sure on the needle valve side of the carb. the diaphram side
the gasket goes first then the diaphram not the opposite. Zama or walbro the same deal
sometimes you have to dismantle the carb totally and drop it in carb. cleaner for awhile to allow to penetrate where its hard to clean and sometimes you have to replace the carb,but not always
the initial carb. setting for high and low is 1and1/4 turn and tweek from there.
Also the smallest pinhole in the fuel lines will create havoc also.
and if compression is weak or low the carb. will not work properly either.
Try these things and maybe it will help you some?
Posted on Jun 02, 2009
Why will My weed eater only run with the choke fully on and cant give throttle?
It sounds like the carb needs adjusted. Things can even happen to new weed eaters.
May 31, 2014 | Poulan P4500F 16-Inch Straight Shaft 25cc...
2 cycle 31 cc 15" model 705r curved shaft trimmer plus click link weed wacker ..seems to flood,fuel drips from air intake ,after carb adjustments still will not start cant seem to regulate fuel ,checked...
Check the metering diaphram and check valve in the carby.The valve might be leakin and the diaphrm might be hard. do a google on the make of the carby as these are fitted with a few makes manly Zamer but. DONT use compressed air to clean or automotive type carby cleaner all will kill the valve and its not replacable..
Jul 01, 2010 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Need to know how much oil to mix with gas for a 4 cycle ryobi weed eater
You only need to mix oil with gas when it is a 2 cycle engine. 4 cycle engines run on straight gas. Since you didn't post your model number, here is a site you can hopefully find your owners manual at. Hope this helps.
http://odref.com/pdf/Ryobi/
Aug 23, 2009 | Ryobi Garden
No power
Jun 01, 2009 | Ryobi Garden
Do you use mixed gas for a ryobi weed eater??
Unless it has a tag or decal on it saying it is a 4 cycle then it uses mixed gas/oil at about a 50:1 ratio. Straight gasoline will freeze the piston in the cylinder in mere minutes.
May 23, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
The pull rope broke on my ryobi 705r/725r gas trimmer. I have all the screws off but it seems to be held on by the center shaft that spins. What do I do now?
I have the same issue of clutch removal on a Ryobi 725r. Actually the clutch finally died after many years of use.
Instead of using a screwdriver to hold the piston I recommend using a piece of clothesline rope. It will be easier on the internal components and won't scratch up the cylinder walls or piston. Just be sure to leave a small amount hanging out of the spark plug hole so you can pull it out afterward.
Apr 15, 2009 | Garden
The gas nipple that come out I have...whats goes in the other hole?
Aug 28, 2008 | Ryobi Garden
Garden Logo
1,922 people viewed this question
Top Ryobi Garden Experts
Nick Olsen
Rexter1
Roland W VanLue
Roland W VanLue
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
