Question about Kenwood KAC-8103D Car Audio Amplifier
Kenwood KAC-8103D short?
The wires coming from the amp into the subwoofer got unplugged from the sub box and touched eachother.. i looked at my fuses, none were blown, but ever since then it made this heartbeat sound of a deep bass tone, then stopped, then started again like a dying heart beat " dum, dum..Dum.....dum........dum...............dum" so i looked at the inside of the amplifier, for a burned out resistor or something out of the ordinary, but nothing is showing up.. i really dont want to fork out the cash to get this repaired professionaly the same thing is happing to me what does it mean when it makes that sound and the red light flashing
  • machado_sean May 29, 2009
    is there any way to find out what he needs to change
    cuzz i have the same prob
    and it does the same thing
    Scholar:
  • 96 Answers
Probably popped a diode in the amplifier circuit. The thumping sound is most likely power feeding back through the circuit, so it will have to be replaced professionally unless you have acess to the proper soldering equipment for IC boards. Hope this helps, even though it is bad news
Posted on May 29, 2009
My light on my Kenwood Kac-8103D amp is constantly on red and nothing is coming out? How do I fix this
Check your fuse. Also make sure all your wiring and terminals are correct and not loose.
Dec 11, 2011 | Kenwood KAC-8103D Car Audio Amplifier
Kenwood KAC-8103D Power Amplifier wont turn on
it sounds to me like its burnt.but with some amps the screws that hold it in place have to be screwed into the car chassisfor grounding. be careful not to srewe into hidden wires.
Apr 14, 2009 | Kenwood Car Audio & Video
Connecting subwoofer to kac-7201 kenwood amp
from your sub connect one short piece of cable from + on one side to - on the other side using the same diameter cable as you are running to the sub from amp . this will leave you with + and - on opposite sides of speaker these will then run to the amp +to+ and - to- on the mono side of connetor which is one left + and one - right and the amp switched to bridged
Mar 22, 2009 | Kenwood KAC-7201 Car Audio Amplifier
sounds very similar to something that has happend to mine. if you check the fuses in the amp and they are fine, i recomend replacing the fuse in the power wire. if you are using the glass tube type fuses, sometimes the soldering at the endcaps melts, but the filament doesnt pop. the fuse appears to be fine, but isnt. that happend to me a few times. i had to upgrade to ANL type fuses
Jan 11, 2009 | Kenwood KAC-8103D Car Audio Amplifier
Amp light turning off and on
if you see that happen you might need to your i c sound chip or your trasistor change then and check
Dec 11, 2008 | Kenwood KAC-8103D Car Audio Amplifier
KAC-7202 Major feedback after a few minutes of running.
you might try unplugging the wires from the sub, turn it back on with the wires disconnected- if the noise comes back the amp is probably bad - if the noise doesn'tcome back -turn your head unit off and reconnect the sub- if the noise comes then your sub's voice coil could be shorted- if the noise comes back you should try a different speaker to compare- if the noise still there with the test speaker your problem is definately the amp.
If these suggestions don't help please e-mail me at Merle840@aol.com i will be glad to help. Please give me a good rating if i have been able to help you M. MERLE
Oct 12, 2008 | Kenwood KAC-7202 Car Audio Amplifier
Car sound system
You probably have a phasing problem. Reverse the speaker connections on ONE of the amps.
Sep 28, 2008 | Kenwood Car Audio & Video
Kenwood KAC-8103D 1000 watt issues
The speaker may have shorted and caused the output transistors in the amp to fail. This is fairly common. It can be repaired.
May 14, 2008 | Kenwood KAC-8103D Car Audio Amplifier
Stuck in protection mode
First disconnect the subwoofer wires from the amp, turn the car off and back on...is the amp on? If so your subs are shorting it out, either from a frayed wire, or blown subs.
If it is still in protection mode, check the fuses in the side of the amp.
Mar 21, 2008 | Kenwood KAC-7251 Car Audio Amplifier
Safety overheat fuse?
How hot is the amp when it shuts down?
Nov 13, 2006 | Kenwood KAC-9152D Car Audio Amplifier
Kenwood KAC-8103D Car Audio Amplifier Logo
337 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
