Question about 5900 SST 2-Way Security System / Remote Start System with Responder S
Viper alarm 5900 doors do not lock when alarm is active
The doors do not lock when deactivating the alarm
5 Suggested Answers
insanegtp
  • 112 Answers
SOURCE: I have a viper 5900 car alarm installed with remote start.
Look under dash for a small black box with wires coming out of it, about 2 or 3 inches rectangular.. there should be one or two screws on it. Look to see if it says which direction to turn for sensitivity. As far as not receiving, you need a new antenna, this is covered under warranty through DEI either bring back to where you purchased or look online and see where the closest dealer is to you...
Posted on Jan 29, 2009
  • 33 Answers
SOURCE: Viper alarm, lights dont flash
Sounds to me like the parking light output wire. They usually have a seperate fuse or the connection is bad. The connection on your vehicle should be behind the pass side kick panel and look for a wire to the white/purple wire and check that with a meter or light to see if it's kick out power. There is a possibility they used the negative trigger through a resister and that would be located behind the headlight switch. That will at least let you know and trace down the problem. Here is a link with that parking light info for yours. Hope this helps and let me know if you have more questions.
http://64.85.6.121/diagrams/printpage.asp?ModelID=17258&MakeID=16
Posted on Mar 02, 2009
  • 20 Answers
SOURCE: Viper 5900 remote start does not show it is off on the remote.
try a couple of things, 1) try unplugging the anntena for the alarm for about 5 minutes. 2) remove battery from remote for 5 minutes 3) reprogram the remote
Posted on May 22, 2009
  • 53 Answers
SOURCE: I press the lock door/alarm activation button and
sounds like the remote is not program try programing the remote again
Posted on Jul 12, 2009
I have a viper 5900 car alarm with the 7701 vpx remote and the lock and unlock are reversed. How do I fix this
according to Viper tech support (I emailed them your question):
Thank you for contacting Directed support!
You may need to reprogram the remote to your phone. Please use the following instructions to reprogram the remote:
To program the remote to your system please do the following:
1) open the driver door
2) turn the key to the "on" or "run" position
3) locate the valet switch (small black button under driver side of dash) and press once, release, then press again and hold
4) after the siren chirps one time press the lock button on the remote
5) the alarm will give you a unique confirmation tone
6) turn the key off (the same unique tone will be heard again)
Warm regards,
Nigel McGee I Customer Service Rep.
Viper Support
Apr 28, 2016 | Viper Vehicle Parts & Accessories
Can't disarm even with toggle switch
ususally this happens when the alarm dosent read the door being open, if the alarm dosent read that the door is open you should be grounding out the door trigger (green wire in most alarms) and repeat steps to deactivate the alarm
Nov 15, 2013 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
How to program a remote control viper 5900 for a chevy Tahoe
Should be a switch for overriding the alarm under the drivers side dash. Two wires going to it (grey black) with a push button on the end if it. Have the driver door open and turn the ignition to on not running,,,, push the valet button and let go and then push and hold valet button........ Hit lock on the transmitter one time while still holding the valet button down. You should get a chirp for entering program and then when you lock on the remote it will make another chirp. But the chirp will sound awkward. Let go of valet and and turn truck off. And test remote. If that's doesn't work you may need to follow all the same steps but instead if press once and press and hold you will need to push 8 times and hold on the 9th and hit lock on the remote. I'm pretty sure the it's sequence is for alarm security and 8 steps is for remote start only models. Food for though if my mind is working backwards. Best off luck. All else fails I'm sure a shop will do for about 20$
Oct 28, 2013 | 5900 SST 2-Way Security System / Remote...
My viper 5900 has no reaction to someone touching it nor does the horn sound when it is armed. How do I set it to the most sensitive setting along with the horn sounding off upon alarming?
If you are not getting any sound then the system may be in valet. To find out if it is in valet your status l.e.d. light should be solid and not flashing. if the light is not even on then maybe your horn was never hooked up, but if the light is on then you must take it out of valet.To take it out of velet you have to turn on the ignition of the car and then shut it off... With-in 5 seconds you have to press the valet overide button. The status light should go off when you do this. The other way of taking it - in and out of valet is to open a door and press the.... lock..unlock..lock unlock... lock butons in that order.
Jan 11, 2011 | 5900 SST 2-Way Security System / Remote...
My viper 5002 alarm i don't know witch wire's to use off the viper alarm's for the power lock's
The door lock wires for the Viper alarm are green (-)lock and blue (-) unlock. The Viper system only provides a negative lock/unlock pulse for the door locks. So, if you are working on a vehicle that has positive door locks you will have to install relays to change the polarity.
Nov 08, 2010 | 5002 2 Way Car Alarm with Keyless Entry...
My remote starter for my viper 5900 2 way trans isnt working...my battery went dead in the remote, than after i replaced it, it's not working properly
Try reprogramming the remote. Open the door, turn ignition on, press and release valet switch one time, then press and hold valet switch while pressing lock button on remote.You should hear a confirmation chirp from the alarm. Release both buttons.Turn off ignition. test.
Oct 03, 2010 | 5900 SST 2-Way Security System / Remote...
I purchased a avital 4103 remote start kit.i also have a viper 300 esp alarm system installed. my question is can i use the avital remote control to activate the viper alarm and start the car along with...
Avital and viper remotes even though they look the same, they operate at different freqs. Im a retired alarm installer i could never get them to interchange.
Apr 09, 2017 | Remote Start System
Jul 11, 2009 | Vehicle Parts & Accessories
May 21, 2009 | 5900 SST 2-Way Security System / Remote...
Viper auto alarm
Change the battery in the keyfob..
Jan 03, 2008 | Viper RCVGC022 Remote Control
5900 SST 2-Way Security System / Remote Start System with Responder S Logo
251 people viewed this question
Top Viper Vehicle Parts & Accessories Experts
Kevin Daniels
Tre Elkins
Shehu Pro
Shehu Pro
Are you a Viper Vehicle Part and Accessory Expert? Answer questions, earn points and help others
