Question about Samsung LN32B360 32 in. LCD HDTV
Reds look pink, rest of colors look dull
I just bought a Samsung 32'' LCD tv, after about 1 week of owning it, colors started to dull out, I think it's the settings, please help.
http://www.bestbuy.com/site/olspage.jsp?skuId=9230708&type=product&id=1218063831450
SOURCE: Can't use "plug&play" from TV menu
I can switch between shop mode & normal by holding down the menu key on the side of the screen, just press it till it changes.
Posted on Jan 25, 2008
SOURCE: LCD TV SCREEN PROBLEM RED HORIZONTAL LINES OF DOTS ALL OVER SCREEN PLEASE HELP
I unplugged the TV and now the picture is back.I read that the LCD's are vunerable to static build up so unless my daughter is using her TV I unplug it.
I was thinking about getting a large LCD for the family room but I'm not going to until they improve on this technology.
Good luck to everyone!.
Cheers.
Posted on May 08, 2008
SOURCE: web site for registering
please i bought 22'' samsung lcd . When i tried it the first time the standby mode could not go away, so i cannot enjoy the machine. Please help.Bye Paul
Posted on Oct 31, 2008
  • 10 Answers
This should be repairable. It may be the LVDS Cable or the Main board problem. The only other problem is the T-Con Board.
Posted on May 23, 2009
  • 21 Answers
SOURCE: Samsung 32" can not turn on
It could be a faulty power supply (capacitors). To all who are having power supply issues: Samsung is now acknowledging a problem with faulty capacitors. I called 1 800 726-7864 and they said they would repair certain out-of-warranty TVs if the problem is related to the capacitors. I just called and they are sending a service rep out to diagnose the problem
Posted on Feb 22, 2010
Proscan 32" LED TV. Picture colors are opposite of correct, mostly reds and yellow. Any movement on screen shows multiple images. Refresh is slow or not working.
The TCON board or the LCD panel is faulty. Can confirm by replacing the TCON board.
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Jun 06, 2016 | Proscan Televison & Video
How do I repair the color on my Samsung LCD TV. I can still see the picture but 3/4 of the TV goes green/purple/pink and the bottom 1/4 has normal color.
The T con Board or the LCD panel is faulty. Can confirm by replacing the TCON board.
May 28, 2016 | Samsung Televison & Video
Have a westinghouse HD lcd tv about 2 years old, about 2 weeks ago the color messed up cant get it back, the color is missing reds and its weird just the color is screwy cant seem to get it rigth, hit the...
Usually a color missing is a bent pin if you are using it as a PC monitor. Definately check your cables and see if the problems follows the input selections. If it does it most likely is a electronic component failure. Of course this assumes the settings aren't randomly messed up. You might be wanting to invite that guy that always has things taken apart when you visit...or start watching online sales...head's up on repair bills...a similar product costs $400 new, 300 refurbished.
Aug 26, 2010 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Picture has double exposure as well as curved, color also is distorted with pink at the top of screen. It is on a good surge protector. It was fine last night and just started it this evening when we...
Projection TV sets have several common problems listed below.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - TV makes a chirping sound.
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 06, 2010 | Samsung PCN5425R 54" Rear Projection...
Vertical lines after the tv is been for a minute
If you can open LCD Tv than refit all connector of Mother Board
Jan 21, 2010 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Color distortion
go to your menu select color, select user, and adjust RGB from user. same level R-60, G-60, B-60.
May 29, 2009 | Vizio L32 32 in. LCD HDTV
32 inch insignia plasma tv
Check all the cable connections while the TV is on, both at the TV, and what the cable is connected to.
I suspect the problem is in the TV, and you'll have to wait for the Geek Squad.
I doubt leaving the TV on caused this, and good thing it happened when it did.
Jan 27, 2009 | Insignia 37" LCD Flat-Panel HDTV
Lcd tv with wrong color on one pixel
LCD screens occasionally have what are called "Stuck pixels". There is a tutorial in wikihow which might help you out here:
http://www.fixya.com/manuals/w153177-fix_stuck_pixel_lcd_monitor
Try that and see if it helps. Stuck pixels are actually a slighty common problem.
Jan 01, 2009 | ViewSonic VA720 17" LCD Flat Panel Monitor
Color bad
You might want to check the component cables to make shure they are firmly seated.
Mar 04, 2008 | Samsung HP-R4252 42 in. Plasma HDTV
SAMSUNG 32 IN LCD LE32R73BDX (MASTER RESET)
* With the TV in standby, press the {INFO} {MENU} {MUTE} {POWER} buttons on the remote.
* The TV will turn On with the Service Menu displayed.
go to reset
* Press the {POWER} button to exit the Service Menu.
Feb 22, 2008 | Samsung LE32R73BD 32 in. HD-Ready LCD...
Samsung LN32B360 32 in. LCD HDTV Logo
117 people viewed this question
Henry  Thomas
Henry Thomas
