Question about Linksys Wireless-G WRT54G Router
Port forwarding with linksys router
I don't know if I have att yahoo dsl set up correctly since I have always had slow connection and download/upload with Utorrent.  So I tried port forwarding, but I don't think I did it correctly.  I don't know if I have my dns server correct for my static ip on my computer or the set up page.  If I do have it correct or incorrect how will I know.... Clueless please help me.
    President:
  • 2,923 Answers
If you can get online. Definitely, your DNS server is correct. Meaning that your DNS and your static IP are on the same range. Because if the DNS server is NOT within the same range of your static IP, you will never get online. Slow connection has something to do with either the router settings or your ISP.
Port forwarding is opening a specific port so that you could send/receive messages, so that you could allow other URL. Like https, FTP and other stuff.
If you're connected wirelessly to the router, you may need to check/cnage the wireless channel of the router. And if the Internet is still slow, you may need to verify it with your ISP. Maybe they are doing some settings on their end.
Have a great day!
Posted on May 29, 2009
How do I connect to my computer with AT & T DSL connection? I only see one ethernet port on back of computer tower.
If you just bought the router, you will need to insert the router between your computer and your ATT DSL Modem. The cable from the wall goes into the modem (should already be that way) then the Ethernet cable from the modem should now go to the source of your Linksys Router. then use one of the ethernet ports from your router into the ethernet port on the back of your computer tower.
Use the documentation that came with the Linksys for more information on setting it up.
Good Luck
May 11, 2011 | Linksys Wireless-G WRT54GS Router...
I have a Bell DSL modem Speed Streem 6520,linksys Wrt160n &16port
How to Set up the Bell DSL modem: http://www.digitalhome.ca/forum/showthread.php?t=97732
Setting up a Linksys WRT160N Wireless Router: http://www.linksysbycisco.com/US/en/support/WRT160N
(Download the Manual from this site)
Setting up a Linksys 16 port switch: There are many different switch models, however if it just your basic switch, you should be able to just plug it in and plug in your computers via RJ45 cables.
If you need any further assistance let me know....
Serge
Apr 09, 2009 | Linksys WRT160N Wireless Router
Have changed to att may I use linksys modem
Yes, you can still use the Linksys router with your ATT dsl modem. Could you provide me with the model or brand of your ATT dsl modem so I could provide you with the steps on how to setup your router?
Feb 27, 2009 | Linksys EtherFast Cable Modem with USB and...
Linksys WRT54G wireless router not compatible with Aztech modem?
Darvin, gotta love your ISP. Never fear......
if it isn't too much of a problem (knowing you have wireless setup done already), then do a factory reset on your router ** remember to copy the WEP Key if you have, or recall the PASS PHRASE so you won't have to reset all wireless devices ** Reset is located on back, you need a ball point pen to reach the reset switch.
Reset process: unplug, take ballpoint pen & insert into reset switch & plug unit back in. Sometimes tricky, but you should notice green light goes to yellow/orange upon resetting.
RESET or NOT - you want the Linksys set for ::
Connection Type - AUTOMATIC (for automatic discovery)
Router IP Address - 192.168.2.1
DCHP - ON, Addresses - 192.168.2.100 and allow 5-50 users
(for security, assign the number of DESKTOP + WIRELESS expected users +1, this way you don't get overrun without knowlege)
Take the cable from Aztech ETHERNET OUT to WAN on Linksys. (usually BLUE) (??) not 100% sure as I have the little silver pocket edition of the same Router. - power cycle (turn both DSL modem & Linksys off for 20 seconds. turn on DSL Modem, wait till it's about as ready as possible, turn on Linksys, should only take 20-30 seconds to power up & recognize.
VERIFY SETTINGS: access router - 192.168.2.1, goto STATUS. you should see IP Addressing, SubNet, DNS1 & DNS2 settings. If you do not, then you have no internet connection.
ALTERNATIVE,
Setup Linksys Router with COnnection Type: PPoE, you will need your ISP assigned ID & Password. Follow all other instructions properly.
If you still have problems, please contact me at 906-495-1707 or via Yahoo IM junodr@yahoo.com or through this website.
once
Jan 04, 2009 | Linksys Wireless-G WRT54G Router
Port forwarding
well to start, your connection would possibly be ADSL and your zyxel is set to provide DHCP address on your network, so its router capabilities could be turned on.
if this is true, you may need to rework the connection settings.
here's a recommendation:
1.set your modem to bridge mode (bridge only)
2.this will then be allowing your linksys to manage your DSL connection through PPPoE
3.after so, your linksys router should get a public IP address for an internet IP when you go to status tab (not an IP address starting with 192.168.1.xx)
after so, you may reconfigure your port-forwarding.
the reason why you will need to set your modem to "bridged" only is that if it is not, your zyxel's firewall is also turned on, provided that the linksys' firewall is always on. so even if you define which port will be opened on the router, it will still be blocked by the modem's firewall.
Jun 22, 2008 | Zyxel Prestige 660R Router (91004397002)
Internet connection
This is a firmware problem of the router so better update the firmware of the router to resolve this concern.........You can download the firmware from Linksys web site.......
Jun 09, 2008 | Linksys (R) RT41P2-AT 4-Port Wired Router...
Cannot connect with ATT modem
Connect your pc to the ATT box. If online, check the ip address of the computer. If the ip address is 192.168.1.x, then you just have to change the router ip address. The wrt54g ip is 192.168.1.1, it may be having conflict with the ATT modem. Change the wrt54g ip to 192.168.2.1
Good Luck
Mar 05, 2008 | Linksys Wireless-G WRT54G Router
I have a 2wire 2701HG-B
gateway.2wire.net... try that, it should work
Dec 19, 2007 | 2wire 2700HG-B Router (2700HGB)
Wireless network broken, access to WRT54G & Motorola 2210-02 via http.. denied
I have att yahoo dsl which I installed about a year ago. The process required bridging the ADSL Modem (in my case a speedstream 4100) and accepting dynamic IP addresses and configuring PPPoE on the WAN side of my Linksys router. The ATT support person walked me through the entire process over the phone even though I was comfortable with making the Linksys configuration changes as I had to do the same in China without technical support. The modem configuration was no more difficult than the router configuration as it was performed from a web browser too. The biggest warning was that to reverse the modem change (if desired) required use of a reset button because the web interface was disabled as a result of the configuration change. My advice to you especially if you are willing to attach the Linksys router to the telco modem is to contact the ATT highspeed DSL support line and see if they will walk you through it like they walked me through it. Reviewing your Linksys User's Guide and understanding the configuration of that device would probably be appreciated by the ATT Support person as well as assuring you can access the Linksys router to configure it during the call.
Dec 08, 2007 | Linksys Wireless-G WRT54G Router
Linksys Wireless-G WRT54G Router Logo
120 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
